Subuhrue's Achievements
Advanced Member (3/11)
2
Thanks for the info GD! Do the throttle bodies around these years have their own dedicated relays or do they use the MAIN relays on the diagrams? So far looking through the service manuals I haven't found any information pointing towards a dedicated relay for the throttle body, but there are also a lot of diagrams to read, no doubt I could have missed something! Still a bit tripped out that I got +7V on the reference voltage wire... but I am going to put that thought to the side right now and keep looking for areas of concern.
I am having a complex issue and have done a bit of testing up to this point. Basically when I start my car I have code P2101, at first I thought my throttle body (the actuators in it) were dead so I replaced my throttle body assembly, but to no avail. I did another test and started the car again, but this time unplugged the TPS while the car was running. Zero change at all. This leads me to believe faulty wiring to the connector. But when I first made this post I was thinking it could be a relay feeding the TPS causing a short or something similar. Upon measuring the reference voltage wire on the TPS connector I got +7V instead of +5V... very odd. Anyone have ideas? I do know that my accelerator pedal is working because when I plugged in my diagnostic program the sensor read the pedal change, and if I put the pedal to the floor the motor will accelerate slowly.
Clean EA81 Wagon 4 Sale... P/S and A/C
Subuhrue replied to Al Zhiemer's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks to be a right hand drive version! Great find. -
Subuhrue replied to Subuhrue's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Good to know!! Thank you GD -
Subuhrue changed their profile photo
superpoo93 started following Subuhrue
EA81 Carb to SPFI Conversion Log
Subuhrue replied to Subuhrue's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Alright I got a bunch of parts that arrived! Intake manifold w/ SPFI throttle body, distributor, all necessary intake stuff, and MAF. All from a 1993 Loyale, quite a big year gap but we will see what happens. -
Yes they do! I think I paid $364 (?) for my pair of front CV axles. Went right in!
CVJ Axles in Colorado will rebuild your OEM axles. They sent me OEM reman'd 1984 GL front axles earlier this year, great service! All through email.
