Mallory
Location
Whitesville, NY
Referral
I used it a lot several years ago
Biography
Hobbies are kart racing, vintage snowmobiles, off-roading in my side by side.
Vehicles
2011 Subaru Forester
Recent Profile Visitors
Mallory's Achievements
Member (2/11)
0
I tried back flushing already and it didn't help. I had another thread on this, but my problem is my heater is only producing heat on the driver's side. I've tried bleeding the air out of the system too, but I didn't try it with the front of the car raised up. That idea makes good sense, so I'll try that next. I'm willing to try about anything if I can avoid pulling the heater core out!
Yes, it's single zone climate. By air in the heater core I'm guessing you mean air in the cooling system, and I need to bleed it out? Even if there was air in the heater core, why would it just blow heat on one side? It seems like the whole system would be cold. I'm not being a jerk, I'm just trying to understand. Thanks!
I noticed the other day that my 2010 Forester is only putting out heat on the driver's side, and cold air on the passenger side. It doesn't matter what setting I use for the heater, it only blows cold air out the floor, defroster, or dash on the passenger side. The driver's side seems to work fine though. I'm guessing maybe it's a broken vacuum line under the dash somewhere, assuming vacuum is what controls the heater settings. Any ideas where I should start looking?
What about this kit? They say it's all OEM parts. https://www.smartqualityparts.com/engine/79-subaru-timing-belt-kit.html?msclkid=51a2746dec001c3ed88e2832c46a2a6c&utm_source=bing&utm_medium=cpc&utm_campaign=Preferred_PLAs&utm_term=4584688612649115&utm_content=Cat_Seg#/90-awpdetails-/79-model-2003_forester_at?keyword=
El freddo - I have no idea on how much oil or anti-freeze it's using. I haven't driven it and my daughter wasn't the best at keeping track. That's why I wanted to know the main problem areas to look at first so I don't find them the hard way! My buddy has a shop and we're going to put it up on the lift and look it over close for leaks. From the posts I've read so far I'm thinking it will probably need head gaskets. What is the cam belt change interval on these cars?
