Island Roo
About Island Roo
- Birthday 09/03/1971
Location
Quadra Island
Occupation
auto Mechanic
Island Roo's Achievements
USMB is life! (4/11)
10
I have an intermittent speedo not working and am wondering just how to test for which part. the cheezy manual says there are 2 VSS sensors one near the front of the trans and one on the t case area, and a buffer in the cluster, are they both for the speedo, or is one used for ABS? any help is greatly appreciated, cheers!
i have some rims 18x7.5 with a 35mm offset and my buddy has tires 255/45R18 and want to know if they will fit on a stock legacy OBW rims look like this but gunmetal, I have tried calculators and searches but want to hear from others who have had these or what the max tires they have had on an OBW, or what the biggest on a stock legacy OBW with no cutting or rubbing, thanks
2.5 HGs
Island Roo replied to Island Roo's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
cool just thought I'd ask, also my replacement gaskets were subis this time, heads and intake are back on -
well i am putting in new head gaskets in my 99 OBW and they sent a thin one and the old ones were thick and like 4 plates, it only had 139,000km but when they ran it low on trans fluid the heat from slipping, low on fluid (rev and not going anywhere) went into the cooling system and it over heated, so i call Beck Arnley tech support and they call back later oh sorry buddy our fault the kit should have been labeled for a 05-07 2.5 so i had already torqued with new bolts etc and now have to re pull it all. anywho new shat here tomorrow and the parts store is going to replace the bolts and supplement gaskets under warranty. but after how hard is it to add a turbo to this motor , and where to get it, or plain old just dont bother? thanks, yes i did some searching
i looked and only saw a 4" but i dont want to go that high
I want to lift the OBW a couple inches, pis I have searched: it captioned"forester, legacy, imprezza does that mean it would lift if i and foresters in a obw? or differnet than stock legacys? and what is an anti lift? and this part and where does it go? barring that what can I do to lift it a couple inches? thanks
nice build man! looks good lifted
ok i have a 99 leg outback and of course the 2.5 needs head gaskets but also the trans slips bad in first gear, what are my options for a trans, i would really like to go to a 5 spd what bolts up to it, apparently for this year subi theres a trans break ie different trans mid year?, if not the car may have to sit until i figure out what to do with it. thanks
just reading and came across the post and lead to username lpg Brumby I was going to say run propane through your turbo my thinking would say the cool charge from the turbo cool it would it not?
Subaru wheel choices? possible new development!
Island Roo replied to blownchevelle503's topic in Subaru Retrofitting
I redrilled the rotors and drums Isuzu trooper wheels the car is gone, may it rest in piece
