mexiburger
mexiburger's Achievements
Member (2/11)
10
I think my dash broke off.....
mexiburger replied to mexiburger's topic in Historic Subaru Forum: 50's thru 70's
ya i thought you would. when I got this subaru I didn't know alot about BRATs and the title said it was and 81' and thats what I thought untill i wanted to buy a fuel filter for it(I didn't know what to think then). Then when I got the title transfered all the VIN numbers were really screwed up and after alot of phone calls I got the right title for it and now i know it's an 80'. now about the lift, I fabed it up myself and everything is the same as the newer subarus except for the rear suspension arm mounts. I figured out the angles and found that when it moves down 3in it has to be spaced out 1 and1/2 in to keep it in the right place. I used some 1 and 1/2 channel iron and welded some flat bar to the other side to do it. It's held up just fine and i havent had any problems with it. -
After looking at it alot more I have determined that it is not the dash. I have a 3in lift and I was looking at the lift blocks under the trans crossmember mounts and i noticed that the unibody looked like it was smashed in about 1/8 in. I looked on my other subaru and it was flat under the cross member. so i think the force on the leading rod was great enough to bend the unibody. Would this usually happen or is ther alot of rust in there?? should I be worried about too much rust?? -
It's an 80' brat with a standard tranny and i don't think that there is a linkage to bend....the lever is kinda L shaped and bolted to the top of the tranny. but i will be checking that... -
Ok the story goes like this: I was driving quite fast on a trail on my ranch and a very large hole in the road snuck up on me, I hit the breaks and the hole and heard a crack. then i noticed that it was in four wheel drive. I have an equalizer mounted under the dash and the 4X4 lever and now there is no room for the lever to move up so either the dash moved down or the tranny moved up. The tranny mounts look fine so i think the dash moved but i can't see any thing broken. Is there some thing that could bend that would do this? has this happened to anyone else? Thanks mexiburger
The front right cv shaft on my 80 brat is very loose on the shaft on the trans and it makes a thunk sound when i let off the clutch. I havent taken it apart yet so i don't know if the output shaft on the trans or the cv joint is worn (or both). Now, if the output shaft on the trans is worn would i be able to replace it without takeing the whole trans apart? is there any other way to fix this? Thanks mexiburger
Electrical problems
all of everything is taken out all the wires that are running to them are the positive wires I really have no idea what is going on:confused: -
Electrical problems
thanks, i will check that would this problem make all my tail lights come on when i put it in reverse? and why would they still work with the ground unhooked? -
Electrical problems
thanks would this problem make all the tail lights and the front turn signals come on when i put it in reverse? and why would they work with the ground unhooked? i messed up.... i didn't want this reply to be here -
Electrical problems
thanks for the replys i have checked that stuff and it all looks fine. I think it is something in the wires somewhere because when I put it in reverse all the tail lights come on. when I turn on one turn signal the break lights on both sides come on veary dim and the turn signal works. with the head lights on the turn signals on bth front and back come on veary dim. I was thinking it was the wire harness but why wouldn't anything other than the lights be affected? And should the tail lights be working when the ground is unhooked and i have all the wire harnesses and lights laying on the floor? any ideas? Thanks mexiburger -
I have an 81 subaru BRAT and something wrong in the wiring of the tail lights. The break lights and the reverse lights flash with the turn signals. I think all the harnesses from under the dash back are good and I cant see any thing wrong with any thing under the dash. when I unhook the the back harness every thing works fine up front so i dont think the problem is with the front lights. Is there any swich, relay or something that may have gone bad? Do the wires under the hood have any thing to do with the tail lights? Does anyone have any suggestions or advice that would help me? Thanks mexiburger
thanks for the reply, this really helps, but does anyone have a list of the parts I will need? It would really help. thanks, mexiburger
Ok i tried a search, i didn't really find any details on years. i just want to know if anyone thinks it would work. Thanks mexiburger
oh, sorry no I havent I will try
I am just wondering if it is possible to put a 5 speed (possibly dual range) trans from a 88 wagon in an 81 BRAT. i don't have the details for anything yet but may have the chance to do it. if I could what would i need for things like drive shafts, clutch or any modifactions i would need to do. Thanks mexiburger
I am just wondering if anyone has ever hurt a cylinder head by catching the exhaust on a rock or something. I just want to know if i should worry about this or not. thanks mexiburger
