alright folk ! bought this new to me 1989 gl wagon ea82 spfi 5 speed 4wd subaru about 3 weeks ago.
First it start alright when cold but once warm up it will start idling crazy high around 2500 - 3000 rpm
after trying to clean to iacv nothing changed, so i decided to leave to the iacv motor disconnected for the moment being so i could still use the car without destroying the clutch
So i now have to give it gas to warm it up, but after warming up for 2-3 minutes at 1500rpm, it start to stumble usually it will drop 2-300 rpm and pick up again without moving the gas pedal.
It get worse if the car is under load (accelerating or cruising), to some extend it will bring to vehicular to a stop and stall and then i have to wait 20-30 minutes before i can start it again while i literally need to floor the gas pedal for it to start and then will stumble really bad until it pick up a few rpm.
it only happen when the engine is not quit warm up all the way, once the temp seems to stabilize (running temperature) it run perfectly fine and will idle around 1200 rpm (still to high per fsm wich should be around 550rpm with the iacv disconnected.
when it start to stumble under load if i floor it it stumble much harder, i have to let my foot of the gas then ease back into it it will stumble again, but by depressing, coasting for a little bit and pressing the gas pedal again it seem to help clear the engine up. but evrything wont smooth up until engine is fully warm up.
hopefully my description is not to over whelming and precise enough for people to understand lol, also ive heard alot that cts might be toast, i havent had a chance to run the volt meter to it yet but it wouldnt be suprise if its bad... i've been trying to find a new one online but they are all asking over. 100$, anychance someone could point me where to find one beside my local junkyard ? thx you everyone
