Scoby4wd
4
Everything posted by Scoby4wd
84’ Brat GL turbo. No start!
Scoby4wd replied to Johnsomething's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I am parting out an EA81T car that I did see running before I started stripping it (too rusty to save). I can pull this part and sell if you are interested. -
1984 Subaru GL Hatchback FS
Scoby4wd replied to spandy24's topic in Old Gen.: 80's GL/DL/XT/Loyales...
love it, wish you were closer -
Is an 85 Brat similar to a 84 Gen 2 wagon?
Scoby4wd replied to mkoch's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yes they are identical mechanically for the most part -
EA81 Dashboard Removal Help
Scoby4wd replied to Scoby4wd's topic in Old Gen.: 80's GL/DL/XT/Loyales...
wow this is fantastic advice, big thanks to both of you! I feel like I will be able to get it done now. It would be amazing if my Brat had a nice dash so I am excited. -
Hi All, I have any 85 Brat with a blue dash thats cracked badly. Luckily, this weekend I scored an 84' Turbo wagon (badly rusted) that has a perfect blue dashboard. I am looking to swap this good dash into my Brat without destroying anything. I understand there are 3 bolts by the defroster vents and know the methods to get those. There is also one on each side underneath on the sides of the footwells. Does anyone else know what else needs to be done? I'd imagine I need to pull or drop the steering columns and remove the heater vents/speedo surround? How do I deal with all the heater and vent controls? Any other tips?? Thanks!!!
Car Alarms For Old Subes?
Scoby4wd replied to Subarule's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Manual transmission is the best theft deterrent these days. -
I recently purchased an 85 Brat. One of the things wrong with it is that none of the dash board gets illuminated when you turn on the lights. Makes driving at night difficult. Gauges all work fine you just cant see them! Given, that all lights are out, I doubt the issue is a burnt out bulb. I looked in the fuse panel by the steering wheel and did not see any fuses specifically for the dash. The headlights themselves work just fine. I tried turning the brightness adjustment knob on the headlight switch but I still get no lights. Any suggestions on where to look? Are there inline fuses I am missing or perhaps a connector somewhere that is unplugged? Maybe the headlight switch is bad? Thanks
I'm going to check that on the weekend. I hope that's it, i have the tools to press in/out the joints.
Its not really a whining noise. Its more like a very low hum. Sounds kind of like a straight cut gear mesh.
CV axles look fine. I agree its probably wheel bearings I am just surprised because ever bad bearing I have had has made more of a griniding noise and mostly when turning.
I am interested if they are for sale
On my 83 Wagon (4wd, auto) I noticed a humming from the rear end that changes with speed. I pulled the drums off each side and cleaned them up, bearings looked ok and didnt make any obvious noises. Brake shoes were in great shape as well. As I said, the hum changes with speed. It does not change by turning or by pressing or releasing the throttle. I changed the gear oil in the rear end and maybe it is a little quieter but I could be imaging it. This normal?
Turns out the floormat was in the way of the pedal traveling far enough to touch the microswitch. kickdown works fine now. Glad it was an easy fix. Wouldnt have found that if I didnt know the microswitch was on the pedal assembly so thanks.
thanks alot I will check thath
sorry just saw you said fwd. the ones I bought were 4wd.
You can buy right from Subaru for around $100. I ordered a set two weeks ago and they hit my door step about a week later.
My 83 Wagon (4wd, AT) doesnt downshift when I floor it. Trans seems to work fine otherwise. Not too familiar with how kickdown works on these, anyone can offer me any troubleshooting tips?? John
83 GL Automatic runs rough until warm
Thanks for the advice and link -
You crack me up man. If I do decide to sell you will be the firsst person I contact. -
Does anyone have any tips on adjusting the choke? Or reference from a manual? Thanks -
Hi, I bought an 83 4WD GL Wagon a couple of a weeks ago. Its in pretty remarkable shape for a northeast car, with the interior near mint. Odomter reads to have about 40k miles. Interior is clean enough to be believable. PO says they rebuilt the carb but coudnt get the choke right. I believe it haas a Hitachi but I havent opened it up yet. Basically the symptoms are that it feels like it is missing until it gets sufficiently warm. It runs kind of lumpy. It doesnt really make alot of power either. Runs great once warmed up however. Any ideas?
Anyone out there have an EA81 driver side fender they can cut me a repair panel from? Would love to weld in a piece but dont have the fab skills to make one. Thanks!
Dang makes me wonder what I could get for my 86.
