KStretch55
About KStretch55
- Birthday 05/02/1960
Contact Methods
Yahoo
witenite0560
Location
Boise County
Occupation
Uncle Sam Employee
KStretch55's Achievements
Subaru Fanatic! (6/11)
10
EA82T ignition amplifier and coil Q's
KStretch55 replied to iluvdrt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Sounds like baloney to me. -
Sorry folks, but the term "rallying" implies that you are involved in a Rally. If there's no Rally happening at the time, it's just wreckless driving. Be careful that you don't give "Rallying" a bad name.
Rust proofing
KStretch55 replied to gsp4's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Your "rust proofer box" does the same thing as a sacrificial anode, which in reality isn't much, on a car. I wouldn't waste the money to have a car undercoated once it's been driven. All you'll end up doing is sealing the corrosive agents into the cracks and crannies. As someone else noted, it's best to just make sure you give it a really good and thorough fresh water rinse periodically, at least every couple of months. But, do it when the weather is warm, or you can park it in a heated garage, so it can dry thoroughly, too. One of the best anti-corrosion steps you can take is to make sure all of your bonding strap connections are tight and clean and your negative battery terminal is clean and solid. -
What "rally" were you in at 4am??
crank shaft pulley bolt
KStretch55 replied to subyfreak's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I use a screwdriver in the ring gear teeth through the timing mark hole. Sounds like your bolt is severely over-torqued. Good luck. -
Need advice on button on auto shift console
KStretch55 replied to foxgap's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You have to put your foot on the brake to shift out of park. That is a design feature. Foot on brake, push shift button under your thumb and shift. You should not need to push the interlock button that is mounted on the console. That is used if there is no battery power or key available and you need to shift it to nuetral, such as if it's been wrecked and getting towed or something. Shifting from Park to Reverse, Reverse to Park and downshifting will require you to push the thumb button. Upshifting can be done without the button. Also, a side note, you should find that you can shift from Drive to Nuetral with a firm push on the shifter. That is another design feature for safety. In a collision the momentum of the shifter should automatically shift the transmission into neutral. -
Owners manual strictly forbids putting a hitch on EA82 models. Probably for the reasons already mentioned (not enough power or brakes, as well as fairly light drive train). So, be careful! I don't think I'd pull anything much over a few hundred pounds. 1000 at the very most.
What engines are in these cars.....??
KStretch55 replied to NVBigBlue's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have a 92' Loyale wagon, AT, 4wd. I like it fine, as do my daughters. Yes, the AT would be nice if it had a 4th gear, but I only really miss it on hills. I had a '91 MT Loyale wagon until recently, too and my son preferred it. I prefer ATs just cuz' I'm a lazy driver, but both are nice. My first Subaru was a used 87' GL-10. Personally, I'd stay away from the turbos. IMO, the additional power produced is not enough to make up for the additional risk and maintenance involved due to the extra heat load put on both the oil and cooling systems, as well as the load on the head gaskets. I know a lot of folks really like them though. -
85 GL Wagon 4x4 Carburated- Won't start
KStretch55 replied to sub-dude's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Timing belt? Does the distributor rotor turn when the starter is operated? -
I've got some of my '91 Loyale wagon after my son rolled it about a month ago. As soon as I find the disk I'll put them on the gallery. He and 3 friends all were wearing belts and all were unhurt, thank God. Luckily the car ended up perched on a stump right side up. Took a lot of work to get off the stump. Had several people tell us we should just call a wrecker, cuz' we'd never get it out with my pickup. But, once we got the stump out of the way and cleared some brush, it pulled right out. I started it up and he followed me home, about 30 miles. Was a bit cold and airy, but drove fine.
High RPMs at freeway speeds, is this norm?
KStretch55 replied to 211's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Don't forget that if you have larger than stock tires you are actually going further and faster than indicated by your odometer and speedometer. So, when you figure out mileage you need to take that difference into account. I used to have a shortcut to the tire size difference calculator someone posted, but I've lost it. I think my '92 Loyale AT wagon lists 155 somethings as the stock tire and I'm running 185/80-13s on it. If memory serves me correctly that was a difference of somewhere around 8% (don't quote me). So, when I figure mileage, I have to first add 8% to my tripmeter. Makes my mileage around 25 - 26 usually.
