Ken2004LLBean
Location
West Warwick, RI
Vehicles
2004 Subaru Outback
Ken2004LLBean's Achievements
Member (2/11)
2
That would have been more work for him, lol. Now I get to do more work, rather than enjoy the car. Bummer. The car never had weird idle surges or a persistent CEL prior to the swap, but it always did seem to idle a bit high (closer to 800 rpm, than the desired 600). Anyhow, too late to get the intake off the old engine at this point. Guess I'm fooked now. I might remove the fuel pipe protectors to get more access to the fuel and vacuum lines. I read that fuel injectors have O rings that can leak and cause high idle.
Well, the mechanic who did the engine swap is no longer my mechanic, as I caught him in a few lies, including tampering with my instrument cluster to disable the check engine bulb because he couldn't figure out the problem causing it to illuminate. So, I don't take his word as gospel, and you're right, his statement doesn't make sense. Your point on not trusting wiring from junkyard engines is well taken, and a hard lesson I've learned, although if I had to do this all over again, I would have just junked the car after the original engine blew, and used the money to buy a different car, but this mechanic assured me replacing an engine was a good move, as the car is otherwise mechanically good and has a solid body. I will never swap another engine in a computerized car with all sorts of emissions crap; I would only do it on a pre-1980 American car. At any rate, I've spent too much on this car to give up now. Aside from the check engine light and idle issues, it runs and drives well, and by a miracle, passed emissions last month, so I don't have to clear that hurdle for two years. Besides being invested financially, I'm invested emotionally, not wanting to cave in from a challenge. If nothing else, it will make me a better amateur Subaru mechanic. Ken
The intake is the one that came with the salvage yard engine, although my mechanic said he kept the engine wiring harness from the old engine b/c it was in better condition. I was thinking that the dreaded fuel pump cap/O-ring issue might be starting to rear its ugly head. The car starts fine most of the time, but maybe 1 out of every 5 starts or so, I will have to crank it twice to start it; this could happen when engine is cold or hot. I will have to purchase a replacement cap and O-ring before I check this, though. I also plan to replace fuel pump as regular maintenance, since that has never been changed in the five years we've owned the car. Car has plenty of power and accelerates smoothly, though. Checking fuel pressure would be an easy thing to check. Where do I tap in with a test gage on the H6 engine?
Perhaps also worth mentioning: When I have key on, engine off, and activate the throttle, I can hear a solenoid inside the transmission pan humming/buzzing, and the more I push the pedal, the louder it buzzes. I tried this with another '04 H6 car, and it did the same thing, and from what I've read, this is normal. The mechanic did replace a solenoid in the transmission (described in the invoice as "solenoid B") following the engine swap, when the car did not shift properly. The car shifted properly since. So apparently, the TPS must send a signal directly to a solenoid in the transmission, which leads me to wonder if this going into open loop/bucking thing is a transmission-related issue? My scanner can only read the ECM, not the TCM, but the transmission light does not flash, like it did before the mechanic replaced the transmission solenoid. (BTW, I have checked and verified that the transmission fluid level is full.)
I've been having driveability issues and a persistent CEL since an engine swap (see link to main thread below). I noticed a weird thing while driving the car and monitoring live data. When I am maintaining speed, or slightly accelerating, and then release the throttle (either to come to a stop, or reduce speed), I noticed the car goes from closed loop, to open loop, and it bucks for a second (feels like a downshift - I have an automatic trans). Then, it goes back to closed loop after a second or so. It does this at local road speeds, and highway speeds, although if I let off the throttle at highway speeds, it does not revert to closed loop on its own; it stays in OL until I press on the throttle again. I have had surging idle speeds, and also surging when coming off-idle from a stop, and every time the engine hunts/surges in rpms, the car has been in open loop. Also, a few times while maintaining speed on local roads, when the rpm is around 1,500, I have felt the car losing power briefly (engine power, not electrical power). This is when I am barely touching the throttle, so it's at or near its lowest position. I have been trying to establish any patterns, and as far as I can tell, although I'm not 100 percent sure, it doesn't seem to be dependent on or affected by road speed, engine speed (rpm), engine temperature, ambient temperature. The one common denominator for when the car goes into open loop/surges/bucks seems to be throttle position. It acts up right around the lower edge of throttle position. My simple live data scanner records throttle position at 13.7 percent when fully closed, and about 80 percent when fully open. The car acts up in the 14 percent throttle position range. It doesn't happen 100 percent of the time, but probably 80 percent of the time. It's a very annoying phenomenon. The TPS is a brand-new OEM part purchased from the dealer. I have a second TPS that is also fairly new, which was installed by a mechanic when I was having wild idle surges. I have tried switching both TPS back and forth, but have the same issues with both. Unlike the H4 engines, the TPS on H6 engines is not adjustable. There was a TSB on the throttle position sensors on the 2001-2004 H6 3.0 Outbacks, but the part I bought from the dealer is the new-and-improved TPS. Still, I suppose it could be defective. I find it odd that this TPS doesn't show full range of throttle opening percentages (i.e., 0-100%). The one on the car now goes from 13.7 to 80 percent. My other one goes from 14.1 percent to about 81 percent. I took readings on a different H6 Outback (also a 2004), and its TPS read from 11.1 percent to 85 percent. Mainly, though, I am curious: What would cause a warmed-up engine to go from closed loop, back to open loop? Is it normal for it to go into open loop when letting off the throttle? Can anyone with a 2001-2004 H6 3.0 Outback and access to live data while driving check on this to see if it happens with your vehicle? -Ken
New to forum!
Ken2004LLBean replied to Ken2004LLBean's topic in Meet n' Greet. Your USMB Welcome Center
Okay, here goes ... Wow, that was easy! (insert Staples easy button) -
Well, per advice from another Subie forum, I cleaned all electrical connectors that would have been disconnected during the engine swap (also reset the ECM via battery disconnect). This made a definite improvement in lowering my idle speed by an average of 50 to 100 rpm. Car now idles no higher than 1,000 in park (with higher engine temps), and as low as 850 in park (slightly lower engine temps). Idle speed in drive in drive is between 700 and 800 (lower engine temps = lower idle speeds. Still had that annoying buck after going back and forth into open loop when letting off the throttle. Check engine light stayed off for a day, but it came back the day after, with my old friends, codes P0519 and P0507, after putting it in park and it started to hunt/surge. My next step may be replacing both front, and rear, O2 sensors (with Denso ones, of course).
New to forum!
Not sure how to attach a link ... I'm not too computer savvy -
Hi, thanks for your response. I have not come across an idle re-learn procedure in the FSM, but then again, I have only read a few parts of the manual, mainly DTC troubleshooting procedures relating to the codes I've had, and wiring/sensor/harness diagrams. As for the link you provided, that's some interesting information, although it looks like the IACV on the H6 engine uses a different mechanism (a rotating, slotted cylinder, as opposed to a pintle at the end of a threaded shaft). Before I installed a new, OEM idle air control valve, I tried cleaning the old one with throttle body cleaner after removing it from the TB (actually, I have two old IACVs - the one that was on the engine, and one I got from a junkyard - I cleaned both, and now I can't remember which one I reinstalled before installing a brand-new part). Either way, cleaning an older IACV or installing a new one, seemed to make no difference. I have not really done much electrical testing at the IACV harness, though, so that may be one of my next steps. I also need to find out what's causing the car to jump in and out of open loop.
Some background: Wife's car is a 2004 Outback LL Bean with H6-3.0, automatic, 153K. A sudden, massive coolant loss destroyed the original engine. Since a mechanic installed a used, replacement engine (with 100K) three months ago, the check engine light has remained on, with persistent codes P0519 and P0507, no matter what I've tried (see list below). Idle speed also high (1,000 rpm in park, 850 rpm in drive), and idle speed also sometimes surges/hunts, both in park and drive, which causes car to buck. Idle speed in park has sometimes gone as high as 1,300 to 1,500 in park, when engine is hot. Also, car does not always start on the first crank, but will always start on second crank. Surging rpm and hard starting have happened both with cold or hot engine. Anyway, I downloaded the factory service manual and followed procedures for checking codes P0519 and P0507. The most likely suspect for high/surging idle is vacuum leak, but neither I nor the mechanic have been able to find a vacuum leak (I used the carb cleaner spray method, he used a smoke test). Steps I have taken so far, with no change in solving the problem: - Replaced following parts with Subaru OEM parts: throttle position sensor, idle air control valve, PCV valve (old was was gunked) and PVC and air box breather hoses. - Removed EGR valve to check valve and passageway on intake manifold for carbon buildup/blockage, but found no blockage. - Adjusted throttle and cruise control cables. - Replace throttle body gasket and cleaned throttle body. Replace air filter (old one dirty). - Replaced ECM with unit from salvage yard. - Cleaned all ground connections I could find, and checked for loose electrical connectors. - Tested for voltage and ground at various sensors (MAP, TPS and IAT) The past few days, I have monitored live data from my basic scanner/code reader while driving, and I noticed one pattern: whenever I let off the throttle (whether from cruising speed, or acceleration), the car goes into open loop briefly and bucks, then returns to closed loop. Also, when I experience surges in rpm, the ECM is in open loop. Another pattern I've noticed is if I put the car in park, and press the throttle, I will get the surging rpm problem between 1,000-1,100, and also around 1,700-1,800 (very specific, reproduce-able ranges). I don't know if the open loop is causing these surges, or is the effect of these surges. The P0519 and P0507 codes; going into open loop going on and off the throttle; and surging rpm come back after resetting the computer by disconnecting the battery. Since I get the surging when rolling on or off the the throttle, I used a DVOM and backprobed the TPS connector. I get 0.7 volts at full closed throttle, and 4.5 volts at full open throttle, with smooth increase in voltage as throttle is opened. I don't know if it's the throttle position, or a certain rpm range, as described above, that's sending the car into these open loop spasms. Took the car back to the mechanic today to see if his expensive Snap-On scanner could reveal any smoking guns than my $40 scanner could not, but he said nothing jumped out at him, and that the fuel trims looked good to him. The car cruises and accelerates smoothly and powerfully. It only acts up when first letting on and off the throttle, in addition to sometimes hard starting and the always-high idle. One other thing maybe worth mentioning: my scanner shows emission monitor readiness status, and in the past several weeks of tinkering around with the car, the monitor for EGR has never entered ready status. My mechanic thinks it may be worth replacing the EGR valve, although I hate to keep throwing parts at the car at about $100 a pop, even though my labor is free. I've spent hours searching online and under the hood, and am growing beyond frustrated. This car is consuming me. -Ken
I personally prefer older vehicles too. I especially like the 2001-2004 Outbacks, which in my opinion, are more stylish than the 2005-up models. I prefer a throttle cable over drive-by-wire throttle. It is much easier to swap ECMs in the 2004 and earlier models (I believe 2005 is when Outbacks used an immobilizer key that must be programmed into the ECM). The intake manifolds on the 2004 and earlier H6s are metal, whereas the 2005-up H6 manifolds are plastic ....
Hey all, My wife and I bought a 2004 Outback LL Bean back in 2014 (she drives it, I maintain it). It's been a great car, and I love the H6-3.0 engine. Unfortunately, we had to replace the engine last fall after a sudden, massive coolant loss led to severe engine overheating. I had a mechanic locate and install a used engine. Since then, it's been a massive ordeal trying to figure out a persistent check engine light and weird driveability issues, so that's why I'm here ... will post more details in a different post/thread. Thanks, Ken
