Druboi
  • Location
    Athens ga
  • Vehicles
    SB9T
Druboi's Achievements
Newbie
Newbie (1/11)
  1. I had number 1 missfire.. I used an led light, you can see it blink, looking closely. Hot to battery, negative to injector wire. (Led polarity matters)Tested with working injector, then number 1, was no blinky Two things.. adding power should not and will not open injector, adding ground would.. but don't, you're shorting ecm. Instead of buying new ecm, solder board where injector wire pin is on it.. They wires all have black sheathing in last plug, easy to find.. Much cheaper, fixed as soon as you melt cold solder joint, slit second. Update it was actually this IC. SOLDER all connections.
