Got a '95 Brighton Legacy with 244,000 miles for $500 ($700 after expenses) that needed a clutch. Dropping the trans wasn't bad, but going back in was another story. The 4 smaller bolts that go into the body at the rear tranny crossmember were all sorda stripped. Nothing an impact and elbow grease didn't fix. Got one bolt each side, the other 2 were too fubard. Then the larger tranny crossmember that has one larger bolt on each side gave me some trouble. The weld nuts in the body both broke loose. Using the impact I eventually got them both tight though so no big deal. Front axles, no problem. Tie rod ends gave me some crap too. I unscrewed the castle nuts so that the nut stuck up above the threads. Well, after the 4th smack with the BFH it stripped the threads out of the nut. Ok, I'll just go ahead and beat on it till it comes out and get a new tie rod end. It finally does come out, pretty mushroomed. Same happened on the other side. The vaccuum hoses under the hood were all in pretty bad shape too. Got it all together, and didn't make it 2 miles down the road and something catastrophically fell apart in the front end. I don't blame that on the car, probably something I missed working on the car in the near pitch black. My Outback was of WAY better quality. The bolts in the Brighton are of much worse quality. Is it because it's a '95 and they were cheaping out to sell them?
My Outback was a '96 and was WAY easier to work on. Even the rubber hoses in the Outback, having 10,000 more miles, were still soft and pliable. WTH????????? Oh yeah, and the transmission pops out of gear quite a bit. I ABUSED the Outbacks' trans with 3000rpm clutch dumps going up rocky hills, slamming it in reverse, changing gears without using the clutch (took some practice but I could do it pretty smoothly after a few tries) and it never showed a HINT of trouble. What gives? Should I avoid Legacies and stick with strictly Outback or is it because it's a '95?
I'm pissed. I was hoping the simplicity of the Brighton would be a nice change but this car is absolute crap. Were some of them made in USA? I'm sure if some were this is one of them.
