Subaru_dude
    3
Everything posted by Subaru_dude
  1. can i use the really thin sheet gasket material that comes in rolls? i can't find any parts stores or lawnmower repair shops here in town (or anywhere else for that matter) that sell thick cardboard gasket material.
  2. you don't just mean that little tube do you? the entire hole? that just seems like an awful lot of jb weld.
  3. sweet!! thanks... that helps out alot. now i don't have to wait a week for gaskets to get here.
  4. i have a redline adapter for my 32/36 weber carb (ea82) and i need the gasket between the adapter plate and the intake manifold cuz it got soaked in coolant. i've called 3 places and all 3 places have said that i'd have to buy the entire kit to get the gaskets. could i use a larger gasket and maybe just drill holes for the screws? if so... what gasket is best? maybe i haven't called enough places and this is a stupid question. let me know if it is. thanks ALOT guys. -Jordan
  5. i had to tap my holes out too. the screws that come with it were way too fat. this also answers my question as to where that coolant leak was coming from... lol.
  6. check your timing belts. sounds like one is a tooth off. no biggie, easy fix.
  7. no... not like those. i went to the wheels page and looked for them and didn't see anything that was even close. i should have pics tomorrow or tuesday.
  8. nope, there's alot more spokes and they stop short of the edge of the rim. there's maybe a good 3" of distance between the spokes and the outer bead.
  9. i'll post pics in a couple days. they're silver with spokes but not snow-flake style.
  10. i was rummaging through a subaru junkyard (about 20 miles from here) and found a PAIR of 13" ENKEIS. they looked like pretty cool wheels, but there's only 2 of em. i was wondering if anybody's ever seen them? i thought that the u.s. didn't get those. how much do you think they'd sell for? I've NEVER seen them. not even on this site. and does anybody need any special hard to find parts? he's about to start selling like crazy cuz he's got too much crap. P.S. the only thing he does not have are LSD rear diffs. he's been stashing those somewhere.
  11. I really don't think there's anything they can't do.
  12. ricers... they're so slow. http://www.youtube.com/watch?v=FRqkrNA7VSI
  13. I was visiting my dad where he was working just outside sioux city in my '87 wag and noticed a minimum mantainance road while i was out riding around in the rain one day. made it just fine through quite a bit of mud with ALOT of standing water. it was freakin awesome. cheap crap tires too. but the next day it was sunny and alot of the rain was gone... got stuck. took a very large tractor to pull me out. if this is the same road you are talking about, then that is just insane.
  14. yes, i used rtv but i only lightly coated the gasket enough to hold the gasket to the oil pump while i installed it. i'm pretty certain I didn't block a passage because I used so little... and it was making the noise before too, it was just not very noticeable from the inside of the car. but from the outside once it was warmed up, i noticed it. the last time i stood outside the car to listen for any strange noises was while it was cold... and it didn't seem to make the noise when it was cold. only when it's warmed up. and i'm using 10w-30 oil. do you think switching to maybe 15w-40 will keep it going until I can build a small shed to do engine work in? maybe a few weeks? it only has about 20 miles a day put on it. and i read somewhere that it may be possible to just pull the oil pan to do rod bearings? but i'm thinking it would just be easier to pull the engine.
  15. '89 gl ea82i think i have a knock. i just changed the oil pump cuz i was bored and my oil pressure seemed to be low. so... i'm bleeding the coolant and as the car warms up... a faint "knock knock knock" and as it gets warmer, it gets louder. at first I thought I left a belt tensioner loose so I took the covers off and checked. nope, they were fine. I find a 2x4 laying in the yard and press it against the driver side head and put my ear against it... "KNOCK KNOCK KNOCK". to make sure it was coming from the block itself, i put the piece of wood on several other parts of the engine and didn't hear it nearly as loud as through the block. the car suffered from TOD before the oil pump swap, but upon startup showed no signs whatsoever of ticking and had plenty of oil pressure. checked around the oil pump pretty gradually after letting it sit there and run for about 15 mins. no leaks. checked everything over a couple times, everything's good and tight. I hopped in the car and closed the door... and it was there, but I just never noticed it before. i guess it came kinda gradually. is my soob gonna die? if i have spun a bearing, is there any way I could fix this without pulling the motor? and if there is wouldn't it just be easier to go ahead and pull it? should I just go ej22 and forget about it?
  16. saw a white '88 gl wagon for $500 in a small car lot, needs front axles. opened the door and sat in the car, checked the mileage, 485,xxx. it didn't even puff smoke when it started, and it ran GREAT! how low should i talk em down? i'm thinkin $200?
  17. yep sounds like intake manifold gaskets... dunno why they would suddenly fail like that though, being that they're brand new... I say get rid of that freggin turbo and get a N/A.
  18. E.TN here. there's a few people in Virginia, some in Georgia, maybe a few more members here in TN. alot of the southeast folks seem to be newer generation soob owners. i'm an old school enthusiast myself.
  19. Soobmater, you are CORRECT!!!! I break crap all the time. and while it does make me sad to see a soob killed, I didn't see any dead soobs in the vids or the pics so I was a happy camper after viewing those fine pieces of artwork. and no matter how hard you thrash a soob on the trails, it'll never cause as much damage as a full size pickup with 33" swampers slowly devouring hill after hill... rutting the earth like a 2 year olds fingers through a birthday cake. it's just a soob, what's it gonna do? lighten up guys. at least they're not out commiting serious crimes. You Rock HTi.
  20. I absolutely could not resist... anyway, can you imagine a 2.2 liter hatch with 8" lift, divorced t-case, beefed up front axles (legacy?), locking solid rear, custom bumpers, winch, 29" swampers... I have a feeling one of these already exists and ran the Rubicon.
  21. how fast is that thing supposed to be? i would buy it, but it's only 2wd. but you could put the body on a 4wd Tamiya chassis couldn't you?
  22. I don't know, but every time I watch it... the only thing I can say is "he wants to die doesn't he?" haha. and the wag with the 2 camo totin' dudes on it... that's pure sweetness, lol.
  23. okay, i'm not familiar with gen 1 legacy construction... HOW DID THE RAD NOT GET MASHED INTO THE CAM SPROCKETS? my ea82 got crumpled about 1/3 as much and smashed the rad into the timing belt/oil pump/driver side cam sprocket.
