LKalenda
Location
Prunedale, CA
Referral
Google, typed in Subaru Forums Outback
Biography
Really enjoy working on my OBL, right now I am converting the exterior lighting to LED. Other than that it is cooking, golfing and ocean fishing - not necessarily in that order.
Vehicles
2008 OBL 137K
LKalenda's Achievements
Member (2/11)
4
Here is what happened. I bought the correct transmission from Parts Market. A day later they replied that they did not have the part. Fortunately, I got my money back within 24 hours (buying through ebay probably helped). I am looking at another part from a auto wrecker in MI. See what happens. LarryK
I have tried changing fluid by draining the pan, refill, drain, refill, about four times. Fluid looks good. No dents in pan. I have found that driving in the Sport mode reduces/eliminates the slipping. Is there a filter inside the transmission? If there is, I am considering having a shop pull the pan, change the filter and perform a complete fluid change. The suggestion of the valve body replacement (which I know nothing about at this time) might be a good idea. I will talk to the shop. I am currently keeping an eye open for a 31000AH310 TV1B8MFEBA from a low mileage car that was well taken care of. With low miles (80K to 90K). If I find one at a good price I might just buy it "just in case". LarryK
I have been told that only the dealer can rebuild this type of transmission, maybe because of the VDC. Is this true? I want to drive this car for another 150K miles, so I try to get ahead of problems. I believe that I have a ACT4, part number 31000AH310, the tag says TV1B8MFEBA, 959763, U5U6, it has SportShift. Will other transmissions work? I have found units where only the last three digits of the part number are different. LarryK
I appreciate it and am tempted to buy the scanner. The fact that moving the seat, stopping and starting the car makes the light go out every time makes me wonder. I had the flashing climate control lights and was being pointed to solder joints but just pulled the front cover off, sanded the four spots where the spring clamps touched, covered with dielectric grease and the problem was solved.
Hello Everyone I have read older posts about this issue but I am wondering if there is some new information to fix this. Occasionally the airbag light comes on. I move the passenger seat a little, turn ignition off, turn it on and the light is out. I know that there are connectors under the seat. Do I need to replace the connectors? Before I pull the seat and start messing with it, Is there an easy fix? LarryK
