Chef
Location
Peterborough, Ontario
Chef's Achievements
Eat, Live, Breath Subaru (5/11)
11
Hey there, I believe you were the one to first coach me on swapping out the air suspension a 1 and a half ago. Now it's my turn. I swapped mine out with parts from a 1990, springs, strut mounts, perches. I had the two used rear struts replaced with new ones for the 1992. The front struts were from a late 90s impreza. Basically, while the top mounts are different from 90-91 to 92-94, the only difference with the struts were the position of the lower spring perches - in other words, you most certainly can use the 92 struts with pre-92 pieces. It may adjust the ride height slightly, but that's it. But, I had ongoing problem with my suspension thereafter, but suspect the inner tie-rods/rack were going. I think though using the 1990 springs/mounts MAY have altered the overall suspension geometry though, and made for less than ideal handling. Long story short - you should have no problem using 92 parts, provided you use 92 top mounts in addition to springs and struts. Good luck! Chef
I assume you've checked all the plugs and wires to ensure they are firing. Could be a couple of faulty plugs. Also could be a misfiring coil pack. Or could be a timing belt off by a notch or two. It can still run, but very poorly. Make sure also the air box and the snorkus isn't clogged. If you can't get air, you can't burn fuel. Put a new fuel filter on it. If it is badly clogged, it may cause this kind of problem. I'd also check fuel pressure afterwards if this persists. Could be a faulty fuel pump too, either due to a clogged screen or the pump itself. Is it running rich? Do you smell gas form the engine bay? Black sooty pipes? Perhaps a problem with too much fuel, maybe even a very faulty engine coolant tmeperature sensor. Cheap and easy fix - yank one off a wreck, and swap it. See if there is any difference. Probably not the problem though. I'd check all vacuum lines, make sure they are leaking/disconnected. There is a trick involving the use of a flammable spray (e.g. wd-40 or brake cleaner) that when pulled into a vacuum leak changes the idle I think - I'd check on that though. I'd also check out the idle air control valve, I've heard of this causing similar issues (although to a lesser extent). Not sure how/why though. Thats all I can think of, but I'm hardly knowledgable in these matters. Good luck!
Ouch - it's a rare event a HG goes on a 2.2, but it can happen to any engine. PErhaps a previous owner had allowed it to overheat some time and it damaged the gasket. Will you have it fixed? If so, it's a good opportunity to do a lot more on it (e.g. timing belt, seals, tensioner, water pump, etc). Good luck
That looks awesome! Someday maybe... I'd consider keeping my legacy and rebuilding it (while driving my new focus), but the problem is that I don't have a garage to work in, finding used 1990-94 parts are a pain here, and I am writing my masters thesis part-time while working 55 hours per week (or trying to anyways). I would some day love to take on that kind of project, but I really can't right now. I figure I could probably fix the soob up for not too much money, but in the mean time I need a reliable car for my 180 km daily commutes!
All these repairs (engine aside) are completely normal for a car of this age and nothing to be concerned about. With the new 2.2 engine, I'd just drive it now and be happy knowing all those issues won't arise again after beign taken care of. Older cares need frequent repairs - it's just the way of it. It'll still be cheaper than something new.
sounds also liek you may have a somewhat clogged heater core and possibly radiator too - when the engine revs are up the water pump forces the water through bette, forcing it through instead of by-passing it. This cna happen after someone has used a stop-leak product, perhaps due to a leaky rad. I'd flush the entire system out well, and replace the thermostat. I'll bet your problem disappears. I've never once had the coolant temp needle exceed 1/2 way on my car, despite lots of driving.
I absolutely hate stop leak stuff, tends to clog heater cores and rads, making life frustrating. Maybe subaru's is bette, but even still... Well folks, you're going to be disappointed, but I bought a car and it isn't a subaru. I decided to go with a very mint 2001 Ford Focus Wagon. Jet black in colour, a rare 5 spd, 112 km on the odometer. PW, PL, AC, CD, fog lights, roof rack - looks very sexy. Comes with 4 brand new snow tires too! I know I chickened out, too scared of the head-gasket issue. But that wasn't the only reason. External leakage is more a PITA than a real problem. But I wanted something with a bit better mileage and cheaper replacement parts. It certainly isn't on par with subaru quality, but then again I didn't pay for a subaru. They'll be taking my soob away, probably to be fixed up and sold for nearly the price I bought it for it a bit over year ago. Well, that's if they decide it's worth fixing. Turns out the knocking noise I heard from my drivers wheel well during acceleration isn't a CV joint - replacing it yesterday made no difference, and the possiblities are not friendly. I will definitely frequent this place, and perhaps dispense the bits of wisdom I managed to absorb from this compendium of subaru ingenuity and knowledge. Thanks everyone for the invaluable advice, patience, and candour. You guys really do rock!
There is probably two bolts - one one the inside pull handle, and the other under the arm rest (or around there). You'll need to pop out the little trim piece covering them and unscrew them first. Then the panel should pop off easily. I'd take a flat-head screw driver and gently pull the edges off when it seems a little tight to pull. Be careful though, if you have power accessories in the door there will be short lengths of wire attached to them - just unclip the connectors. Good luck! Chef
