SiriusBlack
SiriusBlack last won the day on December 3 2020
SiriusBlack had the most liked content!
Gender
Male
Location
Crete Nebraska
Vehicles
86 BRAT GL, 87 XT Turbo GL-10, 05 WRX STI
Recent Profile Visitors
SiriusBlack's Achievements
USMB is life! (4/11)
15
Hey all, my 05 STi has a seemingly random intermittent no start issue. I originally thought it was the battery or starter, but I have replaced both and run all new and upsized cable. Thinking now that it's something with the immobilizer. The cycle the key 3 times reset doesn't seem to affect it. It has full power, but will not crank when this occurs. I was wondering if a new key with a new chip could fix it? I don't know if the chips can become corrupted like a thumb drive? Or if I need a whole new ignition cylinder, which seem to be rather difficult to find. Any help would be greatly appreciated, it's very nearly left me stranded several times now. Thanks in advance.
@GeneralDisorder I have my engine mostly back together. However I have found a hose barb that appears to have been welded or brazed to the back of the drivers side valve cover. It had a hose from the bottom of the AOS I removed, going to it. From all the pictures I've seen of this engine, I assume that barb is not factory? Thanks in advance.
I wasn't worried about doing the test in my driveway, I was worried about replacing the pistons in my driveway should the ringlands be cracked. I'll be doing the compression test soon. @1 Lucky Texan I already installed a killer bee pickup in it awhile back.
I was thinking about that. I don't think they are, as it ran completely fine besides the oil leak. I just pray they haven't cracked. My shop setup is non-existent, I've been doing repairs in my driveway all these years.
Done. I got stainless steel braided oil lines installed. Now I'm in the process of putting the PCV system back to stock. Looks like they deleted my PCV valve when they installed the AOS.
Alright, I just finished pulling the car apart. The turbo is PRISTINE. No residue, no shaft slop, nothing. There is oil all over the turbo oil drain hose and the gasket for the metal hose barb, where it bolts to the bottom of the turbo doesn't look very good. So I'm going to replace that gasket and others while I have it out. I will also replace the small rubber oil drain hose, and look into deleting the AOS the previous owner installed. Currently we're working under the hypothesis that the PCV system over pressurized and blew the excess pressure out that drain line, since it's the path of least resistance.
Reasonably sure. It sure as hell looked like engine oil, but by that same token it was dark out. So I'm not 100% sure.
Hey all, got a bit of a problem. I have an 05 WRX STI that I got used with 70,000 miles on it. Owner said the engine had been swapped with a 20,000 mile unit. I have owned the car almost a year now. Mods it came with: Invidia cat back exhaust. Cobb intake Grimspeed turbo solenoid AOS of unknown brand Aluminum mishimoto radiator Cobb accessport running stage 1 tune of unknown origin. Mods I installed: Killerbee oil pickup Prosport oil pressure and voltage gauges. I run Castrol 5W30 premium full synthetic. Now on to the problem. I was driving home one night, about 12 miles. I was driving spiritedly, but definitely not thrashing it. I pull into a gas station at the edge of the town I live in and notice smoke from under the hood. There is oil all over the passenger side strut tower and on the turbo and down pipe. I check the oil level, and it's right on the money. I decide to drive it the 8 blocks home and keep a close eye on the oil pressure. Oil pressure is fine all the way home, I open the hood and check again. There doesn't appear to be any additional oil on the strut tower or surrounding area. I have thought for awhile that it gets hotter under the hood than it ought to, but my temp gauge never climbs past the third mark up that's before the red zone. I have yet to pull it apart and look in depth, in the meantime anyone have any ideas as to what may have happened? My current theory is that the banjo bolt for the oil line on top of the turbo went bad. As always, thanks in advance.
Hey all. I just got done replacing both O2 sensors on my 05 WRX STI. It was throwing a running rich code, and getting abysmal fuel mileage, hence the sensor replacement. Now after the sensor swap, it hasn't thrown the rich mixture code with a 5 mile test drive. Now however it has a wandering idle. If you disengage the clutch and let it drop to idle, it will either drop so low it actually dies, or it will drop to around 200 RPM before climbing back to 800. It will also occasionally speed up the idle to 1000 RPM. It had this wandering issue before the sensor swap, but it was never bad enough to kill the car and generally wandered up instead of down. I have only had this car a few months and the previous owner tuned it. How is the idle controlled on this car? Is it all ECU controlled? Or is there something I can adjust? Do I just need to give the ECU time figure out it has new sensors? Thanks in advance.
