Everything posted by SiriusBlack
86 BRAT weak/no spark
I have been using the caps that were on the distys I pulled. The new disty has the old cap from the last parts disty.
@Dee2 When we ground the neg contact on the coil, the ground wire we're using sparks strong. If we hold the new coil wire to a ground and ground the neg post we get a weak little spark from the coil wire. Replacing the distys usually fixed the the issue. I assume we went through 2 because they were used ones we pulled off parts vehicles.
Hey all, I have a 1986 BRAT that has had disty trouble most of its life it seems. It original disty went bad an a different one was swapped in from a parts wagon. Then that one went bad and it got the disty from another parts car. This third disty was from an older model and had some sort of complicated ignition module bolted to the top of the coil. Now I was finally able to track down a cardon rebuilt disty, I installed the new disty, new accel coil, new premium blue NGK plug wires and new NGK plugs. I put all of it in and it won't start. No spark from coil. There is 12 volts at pos and neg. We get a weak spark if we ground the coil neg to a body ground. Otherwise no spark at all. Any help would be appreciated Thanks in advance.
Europeon EA82T/XT
I recently replaced the injectors in my 87 EA82T. The old o0nes are green colored. The part numbers are illegible.
87 XT door innards, window motor.
I have the regulator from an 87.5 parts XT. It's not good either, the cable is all kinds of mangled. Anyone know of a gear/linkage type that will fit instead? Not a big fan of the cable types.
3AT tranny speed max out.
I guess I'm wondering about the final gear's ratio. At what point does adding power not contribute to the top speed. What is the realistic top speed for the final gear's ratio?
Europeon EA82T/XT
I've read in several places that the XT coupes that were sold in Europe were more powerful. They had 136HP to the 115 we got in the US. Anyone know what the differences were between the cars/motors they got over the ones we received in the US?
I have an 87 XT turbo coupe. As far as I know it has the 3AT, I've heard the 3AT can handle a fair amount of power increase. What I'm wondering is how much power I can add to my EA82T before it becomes too much for the tranny. I'm also curious, if I reach my goal of getting my EA82T to 150-160 HP, how much more top speed and how much shorter 0~60 time will I end up with using the stock 3AT tranny? I have dug up various articles on the XT, back in 87 it was rated for 115 top speed and a 0~60 time of about 9 seconds. I don't know if those numbers were with the auto or the manual, but i would like to know what kind of improvement I might see with the 30 extra HP. Thanks in advance.
- 87 XT intercooler. Water vs air.
I have an 87 XT coupe, with the EA82T engine. I want to install a top mount intercooler and can't decide which one. An air to air is more reliable, but probably doesn't cool as much. An air to water however has the possibility of leaking and getting coolant down the intake. So I'm looking for advice on this. Keep in mind the cooler will be getting it's airflow from the factory hood scoop. Thanks in advance.
- 87 XT idle issues. Dies when in gear.
In summary, it was 20 or more degrees off in its ignition timing. Due to the fact that I was timing it with the ECU in normal operation mode, and it thus trying to adjust the timing while I was trying to adjust it. If you connect the green jump connector and put the ECU in test mode, it isn't trying to adjust the timing at the same time you are and you can time it properly.
Well, finally some progress. We redid and checked the ignition timing like 4 times. This final time we timed it with the green jump connector hooked up and thus the ECU in test mode. The timing was probably 20 degrees off, so we fixed it and it runs great now. The tach and fuel gauge (Digi dash) still aren't accurate, but otherwise it works. We'll see how it goes from here. Thanks to all of you for your help and suggestions thus far.
The shaft has no play at all. We are looking at replacing all the electrical bits in the top half now. If anyone can get a new one of the right type it's like 600, so we are going to try to fix the faulty parts in the original. We think it is the electrical parts that are causing the faulty tach readings.
Upon further testing, we believe the problem is caused by something in the electrical system. More specifically the ignition pulse. My tachometer goes up and down all over the place without the engine speed actually changing. The ECU receives info from the tach and adjusts the engine from that info among other things. We hope that if we can fix the tach, it might help the idle. Any info you all might have on the digital tach, ignition system and ignition pulse specifically would be a big help. Thanks in advance.
Sadly I've failed again. I got it all put back together with the new injectors and that vac line fixed. It still has the same issues. I'm going to try and get a video of it running, which I will then post on the Facebook USMB counterpart. Hopefully that can give you guys some more info. In the meantime I'm pretty much back to square one and would appreciate any other suggestions. Here is the link to the videos. https://www.facebook.com/groups/UltimateSubaruMessageBoard/permalink/3525592547503216/
Tore it apart now to install new injectors. When tearing it apart I found a rock hard and busted vac line with an orifice behind the power steering pump. I replaced that, but will go ahead with cleaning the fuel rails and installing the new injectors since I have it apart anyway. I suspect that line could have been the issue, it would have created a vac leak.
EA81 and EA82 Engine swap to EE20 Diesel
I'm not looking for more torque necessarily. Diesel engines are generally more fuel efficient and more flexible in what fuels they use. But your saying I'd have to get a different clutch to handle it? What about the torque converter in the automatic transmission? Would it have to be changed as well?
I have an 87 XT and an 86 BRAT with an EA82T and an EA81 respectively. If either of those motors dies on me catastrophically I'll have to do an engine swap. I know most people seem to like dropping EJ engines into these cars, but I would like to make them both diesel with subaru's EE20 diesel engine if I can. I know that its physical dimensions will work as it is slightly smaller than an EJ22. I was curious if anyone knows what kinda of transmission mods I'd have to perform?
It wanders when in idle and in P or N. Wanders up or down about 200 rpm. If I put it in gear without feathering the throttle it struggles then dies. If I double pedal it I can keep it running while in gear. If I hold the brake and throttle it up, then throw it into gear the engine is fine. It spins the wheels then goes just fine. I've never gotten it up to highway speeds as it isn't licenced, I've gotten it up to 30 MPH on my own land. No studder or backfire when I throw it into gear with the engine throttled up and I release the brake. As far as we can tell there is absolutely nothing wrong other than the idle. We believe that the fact that it dies when put into gear, is simply the engine being unable to handle the load of the transmission due to the crummy idle.
