SiriusBlack
Everything posted by SiriusBlack
Need 1987+ EA82T Knock Sensor
SiriusBlack replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I need a new knock sensor connector for my 87 XT. Does anyone know where i can get a new plug or harness? As far as I know the sensor itself is fine, I just need the connector. -
87 XT idle issues. Dies when in gear.
SiriusBlack replied to SiriusBlack's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Well, I put the car in D mode today. With the green jumper connected. I followed the instructions in my shop manual step by step. As far as the ECU is concerned the car is fine. The diagnostic covers the TPS so apparently it's fine. I suspect it may be my knock sensor, the wires are very frayed and that sensor controls ignition timing. Anyone know where i can get a new connector or whole new harness? Otherwise I'm still at a loss. Any other suggestions?- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
On the XT the ECU is mounted in the trunk, just forward of the trunk lid. I will definitely check my TPS, as I recall mine has a rectangle connector, that probably goes into the wiring harness with the 2 large round connectors.- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
I'll be sure to check that too. Also, it was suggested that I see if I can get the car to tell me what's wrong with the diagnostic codes. It doesn't have the ECS light on the dash lit up, but how do I get the ECU to spit out codes?- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
My coolant temp sensor appears to be fine. It was the knock sensor that has frayed wires. I replaced the PCV valve and cleaned the egr valve. Double checked my vacuum lines again. Still no luck. I'm going to put a fuel pressure gauge on next and check that. In the meantime any other suggestions would be great.- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
I am still running tests. I finished cleaning the egr valve, but haven't run it yet. I still need to block the PCV valve and test. The plug that runs to my coolant temperature activated sensor behind the intake manifold has its wires frayed right next to the plug. Does anyone know if I can acquire a new plug for that anywhere? Also will it hurt anything to just delete the egr solenoid valve that's under the intake plenum?- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
@Step-a-toe in order to be sure I have the right part this time, where is the PCV valve?- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
It now has a new fuel pump and new damper. I also removed and thoroughly cleaned the injectors.- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
Warm to operating temp in park. Put foot on brake, no change just wanders the 200rpm like in park. I shift to drive or reverse, engine immediately begins to struggle then dies without throttle added. If I add throttle it runs as it should. If it needs to idle while in gear, like at a stop light the engine struggles then dies.- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
@Ionstorm66 As far as I can tell, there is no oil in the intake. It does die when warmed up, stays fairly steady in RPMs but struggles and dies the moment you put it in gear.- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
I am trying to fix an insanely irritating idle problem on my 87 XT. EA82T engine MPFI. Its the one that sat for 17 after my dad fixed the heads and I recently got running. When it idles it wanders by about 200 RPM either way. The main big issue is that when it is in gear (Auto Tranny) it dies if you don't feather the throttle, as you can imagine that would make in town driving a pain. I have checked all the vacuum lines to the best of my knowledge. Scoured the shop manuals i have for the 86 year. Cleaned the idle air screw and the EGR air bypass solenoid as I originally thought it was the IAC valve. I have tested and replaced the vac line to the tranny from the intake manifold. And replaced the vac hoses from the pressure ports on the front of the throttle body. I cleaned the main throttle butterfly as it was suggested that that being dirty could cause this issue. I have triple checked the timing both valve and ignition. The only other thing i can think of it might be is the Aux Air Valve on top of the thermostat housing. I had pulled the electrical plug from it when it was idleing cold and it made no difference. It was my under standing that if you do that when its idling cold there is supposed to be a major idle change? I sort of suspect that it has to be a vac leak somewhere, because the engine gets kinda hot despite an upgraded cooling system and new thermostat. I have been beating my head against the wall about this problem for almost a month. If any of you can help me I would be forever grateful.
- 82 replies
- idle issues
- 87
(and 2 more)
Tagged with:
what makes a ea82t engine die?
SiriusBlack replied to subiemech85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have triple checked my timing, both valve and ignition. I will double check my disty. I also talked to someone that suggested that if my main throttle butterfly is dirty, it can mess with how it closes. I'll try cleaning it thoroughly and see if that helps. -
I'm thinking it's most likely the Idle Air Control valve that's causing my problem. Can anyone tell me where it is? I know where the EGR solenoid valve, the Aux air valve on top of the thermostat housing and the fast idle solenoid for the AC is. I just can't seem to find the IAC valve, only post i found that came close to telling me said it was under the power steering resevoir and difficult to get to. However i looked and there doesn't appear to be anything resembling a valve there. Please help, this is driving me nuts! lol -
Well, I just got done fiddling with it some more. I tested both of those air valves for leaks and they didn't have any. I tested and replaced the vac line from the manifold to the tranny, with no result. I noticed that if I turned the air valve screw on the turbo side in increments of quarter turns it made small changes to the idle speed. I got it to idle a bit longer when in gear, but the moment I put it in gear the engine struggles for probably 30 seconds then dies without increasing the throttle. I also removed and cleaned the turbo side screw and cleaned it. So once again I'm out of ideas, it's truly baffling. Some research I've done seems to suggest it could be a dirty or faulty IAC valve. Anyone know if that might be my problem? Also I have a general idea, but where is it located? Any other suggestions would be great. -
Well, I tested the air valve. Blocked both sides off and ran it, didn't make a lick of difference. I thought that it might have a bad brake booster that was causing a vacuum leak, since the engine seemed to struggle when the brakes are applied. I tested that too though and it passed, not to mention I was fiddling with it today and as long as the car was in park applying the brakes didn't make it die. Putting it in gear (auto transmission) made it die without pressing on the throttle. It also gets kinda hot sometimes despite an upgraded cooling system, which makes me suspect a vacuum leak as well. Now that I eliminated both the booster and the valve I'm really rather stumped. Any help would be greatly appreciated. PS my digital fuel gauge doesn't work either, it says the tank is empty all the time. -
@Step-a-toe when you break it down like that, it makes sense. I still need to test it and see if the air control valve is actually bad, then I'll go from there. -
Can you tell me exactly what that air control valve was originally for? You said yours runs great with the one line to the intake plenum pulled and plugged. -
Alright I'll check that. I also had to replace the fuel pump and the new one lacks the fuel damper. Can you tell me if that would cause my idle issues? I have to suspect that it would since without the damper the fuel flow would be less smooth. -
By device I assume you mean the actual air control valve on top of thermostat housing? -
The rubber line from the air control valve on top of the thermostat housing is brand new. The one that runs to the barb on the underside of the turbo intake plenum. No clamps though... -
@Step-a-toe yeah I did dig deep again. I got my EA82T running like a dream today except for the idle. It wanders when idling and in gear, if I put it in park it stays solidly at 900 rpm. Main issue is it likes to die occasionally as it wanders. I was digging around for a solution. -
From all the research I've done, these engines wind up getting killed due to the owner trying to squeeze more power out of it by simply increasing the boost pressure. This generally results in blowing the head gaskets which overheats the engine. Biggest thing about these engines is that they overheat, if you want to prevent this I highly recommend installing a dual core radiator, oil cooler and an air charge cooler. If you have an auto tranny give it a separate cooler as well, so the radiator doesn't have to deal with the heat. Apparently the dual core radiators for a modern BRZ will fit these with minor modification. Also keep up the regular maintenance on the cooling system, run some radiator flush every other year to clean the radiator and coolant passages. As for the getting more power, it can be done but don't just crank up the boost. If you can, just leave the boost at the stock 7psi. Injectors from a Nissan 280ZX are direct bolt in with double the flow capacity vs the stock injectors. Hook them to a megasquirt ECU for better tuning. Change the air filter housing for better breathability. Some people have said that advancing the ignition timing to 28 degrees was good for adding power too. All the little mods add up. I'd bet you could get this engine up to 150hp without ever touching the boost. Hope some of this info helps, best of luck. -
I have a digital dash in my 87 XT turbo, and it seems really dim and hard to read in the sun. The dimmer switch only affects how bright it is when the headlights are on. Does anyone know how to make the Digi dash brighter when the lights are off? I'd really like them to be easier to read in the daylight. Thanks in advance.
EA82T XT 4SPD auto.
@Rampage the number I got off the housing is, TX86K362FC-TW. That's on an automatic with part time on demand push button 4 wheel drive. -
EA82T XT 4SPD auto.
@Rampage I got that part number off the bell housing, where do I go to decode it into the actual part?
