espey_16
1 Follower
About espey_16
  • Birthday 07/09/1986
  • Gender
    Not Telling
  • Location
    Tenino Wa
  • Interests
    wheelin my sub
  • Vehicles
    86 4x4 wagon
Recent Profile Visitors
1699 profile views
espey_16's Achievements
Eat, Live, Breath Subaru
Eat, Live, Breath Subaru (5/11)
39
  1. Well I went to 7 junk yards yesterday and didn't fine anything. So I'm gonna buy some solenoids new.
  2. Cleaned the MAF, and car is running at the moment. Code is still there along with egr/purge solenoids. Now I'm getting a 31 throttle sensor code.
  3. Air flow meter = MAF I'm assuming. The coils or whatever they are, are a little dirty so I'm gonna spray some MAF cleaner on it and see if that works.
  4. Ok, previous post was with green connectors hooked up. Unhooked I'm still getting 34 and 35, but now 23 comes up as well. I'm about to go to the junk yard and get a couple solenoids for 34 and 35, but I need to look up how to fix 23. I'll report back when I'm done.
  5. I just tried to check my codes again, and the only thing it's doing is blinking 5 times fast indicating a code 5. I looked up the codes but there is no code 5. The car still won't run with the green test mode connectors hooked up also. It'll fire up then die even if I pump the gas.
  6. Car won't respond to the gas pedal when the test wires are connected at all. Not sure what's going on.
  7. I guess I'll have a friend keep the car running while the green wires are connected and I'll recheck the timing this weekend, and if it's that bad pull the disty and set it properly.
  8. It was 7 months before I bought the car that the belts were replaced. What could cause the car to die when I plug the green connectors together?
  9. Shortly after I bought the car I thought the belts might be off a tooth or two but I checked and they're right on. The previous owner also had them replaced right before I bought it.
  10. I'm not sure if the individual lines are 1 or 2 degree increments, but I've got it 2 lines before 20* BTDC and there's no change. The shudder is better than before, but not gone. The disty is maxed out on adjustment also, so I'm curious if the previous owner had it pulled for whatever reason.
  11. I adjusted it down to 20* BTDC and it seems to be ok for the most part. I didn't have to pump the gas just to leave from a stop, and it only shuddered a couple times on my test drive. When it does what it does, the gas pedal becomes in responsive and I have to push in the clutch and pump the gas to get the car back to normal. Much improved though since I adjusted the timing. I'm gonna go a little more and take another drive and report my findings.
  12. I see the timing marks now, they're not coming all the way out to the pointer on the bell housing if that makes any sense. They are in the passenger side of the bell housing. Is it safe to adjust the disty without the green wires connected? I read in another post 20* BTDC, is this correct?
