espey_16
Everything posted by espey_16
Ok, pic won't upload. Gotta figure that out real quick.
Hey guys. I pulled y driver side kick panel so I could run some wire for a pair of fog lights, and I came across these 2 things. One is a little button on a white and black set of wires, and the other is a little black box with a red and green light. Any ideas?
Rough idle, & check engine light.
espey_16 replied to espey_16's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just have to be mean to it I guess till the cat gets fixed. Good thing it's not a daily driver. -
Sweet thanks. The car would only run while I was pumping the gas, then it would bog down if I gave it too much. I pounded on the cat with a piece of pipe from up top and it started smoking, but after a short drive the smoke went away and it still idled good. I just got ack from another drive and now the car is running like poo again, wanting to die and sounds like it's missing. -
The car is running well, still a little hesitation around 2500-3500 rpms. But it's an improvement for sure. I just need to go to an exhaust shop now, then I can really get it dialed in. -
I think I figured it out. The cat might be clogged. I banged on it a few times and now the car will idle. I'm about to take it for a quick drive and I'll report my findings. -
Bump -
I took the car for a drive the other day, and it started cutting out while driving, and dieing when I stop. I have to pump the gas pedal to keep it running. Im not sure what's going on. -
Ok, I'm gonna try this out this weekend. Thank you. -
Hey guys, last weekend I bought an 89 gl 5 speed d/r. The check engine light was on when it, and when it was cold it didn't want to idle. Warmed up it ran fine. This weekend I put an air filter, fuel filter, plugs, wires, cap, rotor, pcv valve in it and changed the oil. I filled the tank and put a can of seafoam in it too. I drove it to my dad's house yesterday and on the way home it started to studder while driving. Today it is idling really rough, and when I tap the gas it dies. I checked the dtc's and I'm getting a core 34, 35, and 51. I'm not sure, but would any of those cause the car to idle rough like that?
Change 86 gl 5sp 4WD hi/low clutch
espey_16 replied to 1cor6.9-11's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The 24 spline is the one you want. I'd have the flywheel resurfaced. Mabey change out the rear main seal while you're in there. Pull the engine to do the job. -
Hey guys, I'm about to pick up an 89 wagon to swap my parts to from my 86. I have a weber 32/36 dgev carb on the 86, and I know the 89 is fuel injected. I'm not sure if it's spfi or mpfi, if that matters. I'm just wondering if I should leave it fuel injected or put the carb and intake from the 86 on. Right now I'm running 235/75/15 tires and I don't know which setup would turn them better.
Carry some wd40 with you too.
Perfect, thank you.
Hi guys. My clutch just went out in my 86 ea82 dr. Looking on Orielys Web site there's 3 different clutches for an 86 ea82. Obviously I don't need the one for a 2wd, but the other 2 have me stumped. The first one says the disk is 8 7/8" diameter, 21 spline, with a 7/8" input shaft. The second one says the disk is 8 7/8" diameter, 24 spline, with a 1" input shaft. I haven't torn the car apart yet or else I'd be able to tell.
world record attempt?
espey_16 replied to espey_16's topic in Meet n' Greet. Your USMB Welcome Center
Ok cool. I might renegade Earl to it and have the girlfriend drive the new suby (just bought a 2011 forester). -
Hey guys I guess there's a Guinness world record attempt for the longest parade of subaru cars on the 8th at 10 am in Tenino wa. Anyone else know anything about this?
Yeah, that's kinda what I was thinking too. If I pulled something or backed into something I don't want the plates trying to rip through the body.
I'm pretty good at breaking and bending stuff.
Ok. I was thinking about putting a 1/4" plate of steel in the middle hatch, and another on the bottom of the car, and bolting those together. The bottom plate will be welded to the bumper. I would think with 6-8 bolts in the plates in the hatch, I'd have more strength than the original mounting points.
I was adding some tube to my rear bumper this weekend and noticed it was a little loose. I pulled the plugs in the hatch so I could tighten it up and saw that the driver side mounting holes are ripped on the body. What would be the best plan of attack for repairing this problem?
