wirelessenabled
Everything posted by wirelessenabled
I guess I should modify my comment above. It's not like I put the car in neutral on the freeway. I go in to neutral at maybe 30-35 mph as I am nearing the stop sign/light. I got 170,000 miles on the first clutch in my 2000 Outback Wagon. Only changed the clutch then because, not knowing any better, I removed the transmission to replace the viscous coupler. Driven plate on that clutch still had plenty of material on it. Interestingly enough I replaced the original brake pads at the same time, ie 170,000 miles.
I have to laugh at this. Driving my 1961 Triumph Spitfire, a 1953 Ford 1 ton flatbed, and other early vehicles, I used to heel and toe for control. The brakes were so horrible that one had to use the engine braking. My 2014 Outback brakes are great. I shift in to neutral and use the brakes to slow down. As others have said, brake pads are way cheaper to replace than clutch discs. Of course who knows, why believe me? I only have certainly well over 1,000,000 miles driving a stick without an accident yet.
You might want to get on sourcing that OEM PCV valve. I went to my Subaru dealer and they don't even stock them. The parts guy wondered why I wanted a PCV valve.
- 7 replies
- high compression
- oil
(and 3 more)
Tagged with:
I can't speak about the Forester but for my 2014 Outback it would take less than 10 minutes to swap out identical head units. The trim just pulls out with a hand in the storage space, 4 screws to remove the HU, disconnect the 5? cables. Reverse to install. If Subaru used the same scheme for Foresters it is a simple job.
I have no desire to run a Subaru shop. Having said that I do own and run a business. We buy in bulk and get better prices that way. We also do not spend hours and hours buying a piece here and there. Most Subarus use the same parts and so it does not seem out of reason that shops that do lots of these jobs could get some pretty good deals if they buy more at one time. Should be able to easily get at least as good of prices as I did by shopping around. Of course you have to have some capital to do business that way. Maybe that is the barrier.
Hope the link is not stopped by this site. http://www.ebay.com/itm/MITSUBOSHI-Timing-Belt-KOYO-NSK-NTN-Tensioner-Idler-Kit-TKF007TBHTIK/122058842683?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 Price was about $10 cheaper at the start of the Summer. This is a quality kit, all OEM idlers/pulleys/tensioner, belt is a Mistsuboshi. I got most of the parts off Ebay but some from online dealers and even some from local dealers.
If I were to take it to a shop there is no question that I would pay the 20% more to a decent Subaru shop. Guess I was lucky and patient in gathering up the parts from online dealers and Ebay for these 2 jobs. All these parts were Subaru branded except the pulleys and T-belt which were OEM but not labeled Subaru. I paid $12.71 for the alternator belt and $12.36 for the a/c belt. $167.30 for the T-belt, NTN tensioner, and the 3 pulleys Koyo and NSK. $44.00 for the Aisin water pump and nearly $60 for the 2 gallons of Subaru long life green coolant. I would have been nearer $300 in parts than $400 if I had not used genuine Subaru coolant.
Why should a timing belt replacement be so expensive? I just did my daughter's 2002 Legacy sedan with 2.5 SOHC. Used all Koyo, NTN parts, Aisin water pump, Mitsuboshi belt. Replaced all coolant hoses, top, bottom and heater. New thermostat. Subaru OEM green coolant. New hose in overflow tank. All new clamps. New OEM alternator and a/c belts. I took the radiator out and flushed it out inside and outside. Took oil pump off, new seal and checked screws on the back. Reinstalled oil pump with Ultra Grey sealant. I also spent time cleaning all parts touched and the area I was working in. All of these parts were about $400 and the entire job took me about 4 hours. I have done 2 of these this year on family cars but I am not by any means a professional mechanic. So I get back to why should this job be $1200?
manuals have distinctly one quantitative advantage - can pop the clutch when the battery is dead. Interesting this!! I tow a 2000 OBW with a manual behind my motorhome. Going down to the Eclipse last month the towed braking system drained the battery. I thought no problem because it was hooked up to the coach. My friend jumped in the Subaru, made sure the key was on and I drove forward. He popped the clutch and the engine was turning over for about 1/4 mile. It did not start! Tried it again making sure the key was in the correct position and still no start. Finally I charged the battery some with my solar charger and the starter turned and the engine started right up. Who would have thunk?
Just to add to the institutional knowledge. My son had a broken stud on the drivers side front wheel. It was an easy job to remove the wheel, remove the caliper and disc brake bracket, and rotate the hub to the correct location that allowed room to pound out the stud with a 2# hammer. This car has a 6MT transmission so I only needed to lift the one wheel, put the transmission in neutral, and with some effort spin the hub. You will not be able to spin the hub by hand, you need to put a wrench on it. Automatic transmission cars may be different. Only bit of a problem was the sheet metal shield on the back (inner) side did not allow room to slide the new stud in. That was easily fixed by slightly bending that shield in the correct area. I then slid the new stud in place, sprayed it with some PB Blaster and pulled it in to the hub using a stack of washers and a lug nut. It was easy to get the head of the stud flush with the back of the hub. All said it was an easy job.
I bought a 2013 Outback that before I purchased it had oil consumption problems. When I got it there were 500 miles on a new short block put in by the local dealer. I have driven the car about 3000 miles and it has used less than 1/2 quart. I get 29 MPG on daily short trip driving and 31.5 MPG on the freeway at 74 MPH.
I am doing the 105,000 mile timing belt service on my son' s 2010 Outback. My question is about the water pump. The FSM says to remove the drivers side cam pulley and the back side of the that timing cover to remove the water pump. The setup looks exactly the same as the water pumps I have replaced on a couple of 2000 OBW with 2.5 SOHC. I just went ahead and unbolted the water pump and it came right out. I reinstalled a new Aisin one using the included metal gasket. Went back together fine with no problems or any weird glitches. Is there something I am missing by not following the FSM on this replacement? Thanks in advance.
GD, Thanks for all your good information on this forum! I and probably many others appreciate it!
- 33 replies
- 1
