Location
Cincinnati
Vehicles
99 Leg GT wagon now, previous 90 Leg LS wagon, 87 GL 10
MDW25gt's Achievements
USMB is life! (4/11)
10
Frt Brakes
MDW25gt replied to nipper's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Kumho is Korean -
I suggest looking at both sides. The lowest level is correct. I would confirm if the oil is high. Three inchs is pretty high! If high, drain some to proper level. Dont mess with the mechanic. Just dont go back! Its a stretch to call someone a mechanic if they can't change the oil correctly. The brakes. Try the bed in procedure. Check the www.Stoptech.com site for the procedure.
Frt Brakes
I got the brembo oem's and also put on the Hawk HPS pad. I like! Hang in there! -
Engine Braking
MDW25gt replied to axgutt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
I agree! -
OK, here is what I needed. Center diff replaced, both front wheel bearings This took care of all of the symptoms I was having. Binding in turns, (center diff) roar when turning to the right on the highway above 40 mph. This also cured the whining I was getting in the tranny. I believe that the center diff was putting everything into a bind. i.e. causing the whine I was getting while rolling. Hats of to the great service I received from the service manager at Beechmont Subaru in Cincinnati. Scott Snyder and his technician took good care of me. I put 1700 miles on the car last week with no problems! Mike
This noise was there before the diff work. I thought it was to the right side at first, but after replacing the right bearings we check both sides and nothing from the right, then loaded the left side with the sensors. I could hear the noise from the left bearing hub, strut tower and tie rod sensors, but not at the level I would expect. The car is still in the shop. Monday morning I will go back and have them check the nut on the right side. We did have one sensor on the left ball joint and did not hear anything signficant. Guess I could check the right. Thanks
Thanks Gary, I have not replaced the tranny. They did replace the center diff. This is not a problem now. They also replaced the right side wheel bearing, and the noise is still there. After this, I drove the car with listening sensors at the left tie rod, bearing hub, and strut tower. (The sensors allow you to listen while driving, to the noise output at each location.) I never hear from the head phones the level of noise I would expect from the bearing. This is why I am thinking axles? But I guess it could still be the left bearings. Mike
