4Flats
Location
Pnw
Vehicles
05 Forester 18 Outback
Recent Profile Visitors
4Flats's Achievements
Member (2/11)
Thanks again for all the help. I wish I'd have found this forum sooner. I blew $100 on trans filters and fluid looking for a quick fix that wasn't there. Went shopping and found 2 used transmissions locally one $225 with 205k on it on the shelf ready to go and one for $250 with 119k on it. I've got an oil leak from the passenger side head so that's on the list. End of the day I've got a clean 2005 forester with no corrosion or rust, straight body but a trans issue and an oil leak. as it sits it is worth something and fixed it is worth a bit more. 4th down and 10 to go. Punt or slap and transmission in and pull the heads. This would be easier if I had a lift. I bet I could drop the eng trans and front end all at once...
It is probably worn out but (EDIT) 3 oddball issues: I dropped the pan and did a full service, spin on filter and screen. The fluid was nasty and the filter had been on there a while. But It still seems to shift fine. The filter screen was a 3 bolt but the Napa computer and the O'Rileys computer said the transmission should have the 16 bolt (or so) screen. Is is it possible this transmission in incorrect for the vehicle? How do I identify the transmission type? The other odd ball thing, could worn front tires cause this? The fronts are out of line and bald on the inside. Rears look pretty good. There is an oil cooler above the filter, from my other post that is odd for a NA motor in the US?
