Cormfra
Location
Arlington washington
Referral
Looking for information on my loyale
Biography
i have a 1990 white Subaru loyale with an ignition problem I snowboard and mountain bike
Vehicles
1990 Subaru loyale
Recent Profile Visitors
Cormfra's Achievements
Advanced Member (3/11)
It’s all the main radio wires I don’t remember off hand but I’ll look
- 27 replies
- loyale
- subaru loyale
(and 8 more)
Tagged with:
Back ground Got it to be a daily drive I drove it for about a month then my friend tired to put a radio in he didn’t discount the batter and shocked him self. After this it didn’t start no spark I checked fusible links, relays, fuses, new spark plug, new distributor cap does spin when cranking, new coil, new coil bracket made sure it’s wired right, spark plug wires are good
- 27 replies
- 1
- loyale
- subaru loyale
(and 8 more)
Tagged with:
Sorry I’ve been really busy lately. There are no blinks I also could not find the heavy eyelet on the wiring harness I did make sure the brakes are good and tight and test for ground just in the out side of the ecu
- 27 replies
- loyale
- subaru loyale
(and 8 more)
Tagged with:
To the ecu? So ether a ground or bad connection
- 27 replies
- loyale
- subaru loyale
(and 8 more)
Tagged with:
That wasn’t it if I got a new Ecu would that fix the ignition pause
- 27 replies
- loyale
- subaru loyale
(and 8 more)
Tagged with:
Fusible links Questions
Cormfra replied to Naked Buell's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Okay thank you -
Okay thank you I’ll try tomorrow if it’s not that any ideas on what it would be
- 27 replies
- loyale
- subaru loyale
(and 8 more)
Tagged with:
I tested the corrent on each side of the links all reads about 12.8 to see if the current was making it threw and I also tested the amps and there all .30 of my thing is set right I’m pretty new on this stuff
- 27 replies
- loyale
- subaru loyale
(and 8 more)
Tagged with:
Not sure if this feed is still active but is there any test I can do to test a fusible link and if so how do I do them I have a no start no spark -
Thank you so much. So this would also case it not to start
- 27 replies
- loyale
- subaru loyale
(and 8 more)
Tagged with:
