Skubaskott
Location
Nampa, Idaho
Vehicles
1983 Subaru Brat
Skubaskott's Achievements
Advanced Member (3/11)
2
Hey guys! You all have been super helpful throught out my swap.1990 Ej22 into a 82 brat Tonight I was finally able to attempt a start and low and behold it will start. The problem is it won't run for any amount of time after I let off the ignition. All the vacuum hoses are hooked up well. I'm thinking possibly my wiring still. Any other ideas??
Alright guys finally came back to the wiring harness as it is what is holding me back from the swap from ea to ej. No one mentioned the sensor that is not attached to the engine but to the body of the legacy. Any way more on that at a later post. Today my issue is trying to understand what to do with these two wire coming from the ecu saying they are the select monitor signal. B56 pin 8 and 7 what do I do with these!?!?!?!
Hey guys so the engine and tranny are finally in the brat. Ej22 Ea82 D/R 5 speed 4 inch lift. ADF adaptor plate. I am having a minor issue I could use guidance on. The tranny I got was minus a shift lever, and I'm unsure as to how it assembles and I cannot find a diagram. Also the same with the D/R selector. I figure once I see how it assembles I can figure out how to extend what I need to accommodate the lift. Help would be greatly appreciated.
Hey guys I am in the process of my build and I need to get bolts for the adaptor plate. Has anyone used an adf adapter plate. And if so what length bolts did you get?
Hey I know this is a zombie thread now but is pertinent to my predicament. I'm worried about how to properly ground my swap. I have cut out a lot of stuff and that included many wires I assume to be grounds. How can I be sure I properly ground this harness!?
Ej22 harness question for brat swap.
Skubaskott replied to Skubaskott's topic in Old Gen.: 80's GL/DL/XT/Loyales...
There is no connection between this shielded wire and the ecu. Even though the wire has a connector that connects to the harness running under the intake manifold -
Skubaskott posted a topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have my harness mostly stripped. But there is a wire that goes seemingly no where but is great shielded. Any idea what it is it runs from the smj to the harness that is attached to the engine. Smj pins: L6, L5, L4 -
EJ22 Brat Swap with 5spd dr questions
That's where my confusion was! -
Ok thank you for the clarification! -
MY? What are you talking about MY. -
I have an 82 brat. Originally I was going to swap the carb to fuel injected. I've done it and drove it round the block a few times. But now it won't start. Pretty sure its trouble with the disty. I have decided to scrap that. I just picked up a 90 legacy with 160000 on it for 400 bucks. It runs and drives fine but overheats I need to change the water pump. My goal is to strip the legacy of parts to swap into my brat. My brat will soon have a 4 inch lift kit. I would like to use a 5spd Dr in this swap, but I keep getting conflicting thoughts on this. I can get the adapter plate no problem. Questions: 1. What will I need to do, other than the adapter plate, to make the 5SPD DR work in the brat with the ej22. 2. How can I use the powersteering from the EJ. 3. What do I need to do to retain the AC from the EJ. The brat is ready equipped for ac but it was not installed. I know these things have been gone over and over. I have the write up for the EJ swap from @numbchux but I need more info and I want to help get updated info out there When I have all the parts together and I begin this process. I will be doing a write up and also possibly make a YouTube series on this process from start to finish. So any help would be appreciated so we can get the info out to people who are interested in doing this .
I am looking for this manual but I can't seem to find it. Anyone got a link???
