cspurli2
Everything posted by cspurli2
So I was jacking my car up last oil change and heard a thud, I look over and it was where my jack stands were sitting so I quickly jacked it up and stopped the procedure. I then took it to an oil change place to get it done and paid 70 bucks, I wouldn’t have gone there if I had known that but it’s besides the point. If I don’t feel safe putting the stands where they normally go, where should I put them? I would attach pictures if the file size wasn’t too big. It also happened in the rear. Forgot to mention I have a 2011 outback sport
Had a somewhat loud squeek coming from what I thought was the power steering pulley. It also had the low drone on start up so that's another reason I thought my power steering pump was shot. I replaced the whole assembly with a rebuilt one from oriellys. Now, the squeek is extremely loud when I turn the wheel all the way to one side or the other, and it shakes the wheel as well. Anyone know what my problem is now? I tried bleeding it by removing the resivoir lid, and turning the wheel back and forth with the front end of the car jacked up. Thanks in advance.
Nothing that seems out of the ordinary to me. Someone as I said the exhaust note will be alot louder when accelerating than what I think it should be. Thanks, that's basically what I was thinking. Also do any of you know if the plastic covers under the car are necessary? I find It a pain in the rump roast to take them on and off. But if they are I will leave them on.
It depends, sometimes it will rev up very loud and then shift hard, but then other times it will kind of slip-catch-slip-catch with very little acceleration. I've noticed that it does it more if I either drive like a grandma meaning very slow on the revs, or if I mash it it will also slip more. But when I hold it at about 2700-3300 rpms it will do the slip catch thing and accelerate decently. I guess I'm just gonna have to ride it until it dies if I can't find what's wrong with your guys help. I appreciate it alot
No engine lights, although it did have one for a vacuum leak when I got it but I cleared it when I got it and it hasn't come back. I'll check the tranny pan when I get home. The car does have a rebuilt title, I'm not sure the exact location not I do know it was at least somewhere up front because the paint on the bumper and one of the side fenders is slightly off. I'll try adding some and oil but there 1st time I changed out the fluid I put Lucas stop slip in it and the most recent time I tried trans x to no avail. Also this was the last year from my knowledge it was non cvt. Alright. How do I verify that they are ok. Last time I checked they weren't leaking and the boots looked okay.
My vehicle is a 2011 Subaru Impreza outback sport with 99k miles. I have owned it since December and put ~5k miles on it. The transmission feels like it is slipping, but there is no rhyme or reason to when it does it. Sometimes on my way to work it will slip alot, as in 3 out of the 5 gears (or 4 not sure how many my vehicle has) and other times it won't slip at all. I've changed the fluid and put stop slip in it. I took it to a transmission specialist mechanic and they said they couldn't feel it slip when they test drove it. Just wondering if theres something I can do or wait until the tranny blows and change it.
Thanks everyone. I was worried the timing was wrong but I got it figured out and put back together. My next problem was it was overheating, but I just kept driving around and coming it up with coolant. I would let it cool down before starting it up again once it got hot and it seemed to fix it, as I drive around once fully filled with coolant for 20 minutes and no warning light came on. Thanks for all the help!
Was taking apart my timing belt and got the cover off. While in compressing the piston to make sure no air is in it, my friend is taking off the pulleys. I didn't know he hadn't lined up the timing marks. Is the drivers side pulley supposed to be harder to spin than the passenger side? Also how do I know where to line the cams up. Thanks.
