Debbie Norred
  • Location
    Aztec, NM
  • Vehicles
    1982 Subaru GL 1.8L
Debbie Norred's Achievements
Member
Member (2/11)
  1. I thought maybe a locksmith. I will look to see if I can find a lock cylinder. IDK what the problem can be other than the switch. Makes sense to me. I will try to see if I can find out if it's getting power.
  2. The ignition switch I bought has no key. None of them do. Any ideas on what to do with it when I do get the part?
  3. EA81. Got all of that apart from the car. I originally already paid someone to repair that when I got the car, cuz there was a screwdriver as the key, lol. It doesn't look like a car part at all. There are 5 wires but it's attached to the ignition switch by only 4. The guy that fixes it said he couldn't find one for this car cuz it's so old. I ordered a new one and the Chilton's book. I am crossing my fingers that this works. I am So mad that I already paid someone else to do it, to find out after the car has been sitting there for a yr. And was told I needed a new distributor and that it would cost me $1000 to fix. I bought a refurbished distributor from rock auto for only $125. I am starting to hate people.
  4. Yes there is tilt in the steering wheel. I will have someone look here in a minute and get back to you on the electronic parts. I am not good with electrical stuff.i did check the positive side of the coil and no power. Distributor was replaced because a shop told me that was what was wrong with it when I broke down.
  5. 82 Subaru GL. I checked fusible links, they have power. And the coil to starter is good. How do you check the ignition switch?
  6. I am in the process of checking everything. All the fuses are good. Not sure how to check a relay?
  7. I have replaced my distributor and set the tdc but I have no power to my ignition coil. There is power to the starter. And the distributor works. IDK why I have no power. Please help.
