SHERRY ELGAN
Everything posted by SHERRY ELGAN
  1. Well, the air bag light is back on. I checked under the drivers seat to see if it had come loose slightly like before, but it's in tight. I even tried to pull the wiring under the seat (which is yellow parallel with a black wire) completely apart, but couldnt, very tight n ow. What would I be looking for behind the steering wheel , to find the "clock spring"? Can any adjustment be made, or do I have to go to a mechanic to replace it? Also this time the seat belt light came back on, there was also an ABS light on.
  2. Thanks, it was the wire connector under the drivers seat, found the yellow wire, and pushed it back . Air bag light went out!
  3. I had a lube and oil change, an air filter, and axle differential seals replaced.
  4. Just noticed after a regular service, that my "air bag light" is on. Is this serious?
