Jacob 2002
  • Location
    snead AL.
  • Vehicles
    1991 Loyale
Recent Profile Visitors
Jacob 2002's Achievements
Newbie
Newbie (1/11)
0
  1. uh I dont have a test light but i have a multi meter,I also just noticed that when i leave the switch on the coil gets hot is that normal or do i have a short?
  2. yea i meant the fusible links, and yes i know they are a hazzard, it was just a quick way to make sure i had connection i didnt realize my battery had got that low i will charge it and see if that fixes it.
  3. the battery voltage is 12.1 (a little low now that you mention it) and i replaced all the links with 14g wire to make sure they werent the problem.
  4. Ok guys so i have a 91 loyale that has no spark. I have checked coil,fuses,relay, and made sure the bracket was grounded. i have no spark at the coil so i know its not the wires of distributer. i have power across the coil terminals,but only 8.55 volts. does anybody have any suggestions on what i should do to fix it? its a 1.8 spfi front wheel drive(if that makes a difference?) any help is appreciated.
