732002
Location
PDX
732002's Achievements
Member (2/11)
10
Roof Racks WRX
732002 replied to NAYRB's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yakima should have what you need. On my OBW their racks mount to the stock subaru rack. Don't go too long on the bar or you will hit your head on it. Edit: I missed that you need the bars farther apart not wider. Sorry I have no idea. -
It could also be the valve guide seals. Were these replaced when the head gaskets were done? When you down shift the engine vacuum tries to pull oil past piston rings and valve guide seals. Then when you get back on the throttle you see a puff of smoke. Compression test would help to rule out rings.
I took a look under the car. The front cover (not sure if that is what it is called) looked damp on both sides. This could be from cam seals and or crank seal. Valve covers did not seem that bad. Could be oil blowing back from from front cover? I think the water pump is recomended because they will be there and 128K miles. Thanks
I noticed a little oil on the driveway and asked the mechanic to look. They say leaks from cam seals,oil pump O rings, and crankshaft seal and that oil on the timing belt can cause the belt to break. Is this true? They say it should be fixed in several months. For $800 they will fix the seals,change timing belt,waterpump and valve cover gaskets. for $1200-$1500 the Head gaskets could be done plus all the other work. I bought the car at 96K and now has 128K I don't know if the head gaskets had been replaced before I bought. What would you do? Thanks
