mka
    14
Everything posted by mka
  1. More steps forward today! I took the leap and pulled the front knuckles & lower control arms from the impreza. No going back now! One of my buddies gave me the great suggestion of putting the car on a pair of small Harbor Freight moving dollies, so $20 and a scrap 4x6 later and I'm still able to push the husk in and out of the shop after all of today's work - which is both great and not so great. Great in that I can keep my neighbors happy for a time longer - not so great in that it's still in my workspace every morning until I push it out of the way 😅. Enough about my neighbors though - onto the nuts and bolts of the matter! Jacked up the Impreza and got to disassembly. Not too hard, just took some time to keep nuts and bolts together with their constituent parts and assemblies as I removed things, moving one side of the car at a time. Starting on the drivers side I pulled the CV, knuckle/hub assembly, and lower control arm. The knuckles bolted right onto the new coilovers, however the stock cam bolts at the top from the Impreza don't fit the new coilovers - the holes are too small. Going to have to do a little figuring there but for now they're good enough to hold everything roughly in place. I'm going to have to go digging to see if they come with bolts when new or not. Minor problem. The lower control arms almost fit perfectly into the mounts on the original subframe. The distances are exactly the same and accomodate the width of the bushing like it was supposed to go in from the factory - only modification required here was opening up the holes a little bit. There's probably a metric equivalent but i took a pair of calipers to the bushing bolts and found that boring out the mount first to 15/32" and then only the front flange to 31/64" with a hand drill will accommodate the bolt with no play. Based on another build I've seen I will need to reinforce the front flange by welding in a thick washer later - suspension action has the potential to make this hole oblong over time. After that, just had to hook up the control arm and knuckle to get an idea of what this will look like. I loosely reattached the brake caliper bracketry, rotor, and a wheel to get an idea of how this'll sit and I'm pretty tickled with where it's at. I'm going to want to adjust the coilovers longer, these 15" wheels take up a lot of space in the wheel well in comparison to the old 13's. Now that that's done I'm going to have to mock up a template for the other mount on the control arm - likely will get something cut and bent like the transmission mount so I can just bolt it up and zap it in. I'll have a little peek around under the car tomorrow or early this week - maybe I'll get lucky with another choice bolt hole somewhere.
  2. Small tangential update... Firstly, got the slots on my camber plates adjusted to where i can install all the mounting hardware. Hooray! Secondly, and more importantly - I took a little side quest to investigate using similar coilovers as replacements on a more OEM setup using these camber plates. Seems to me one more part combined with a slight modification to the lower bracketry/threaded tube on the coilover would be all that's needed to fit these into the original knuckles. The lengths are nearly perfect, the coils would still have a decent amount of adjustment in them after, and I think this will allow for a very no-nonsense approach that gets a lot of older cars a much-needed suspension refresh up front. I'm going to get a draft done, once I have that and some initial parts turned out I can test fit them off the car myself, but I will need a brave volunteer to try the kit on an unmodified EA setup. Reach out if that sounds like you!
  3. It's been a busy couple weeks, and today was another rough Monday so again I stopped what I was doing to work on the Brat a little. Got the second attempt at the camber plates in for the front suspension late last week. They need one more revision (slight widening of the distance between the bolt slots, i overcorrected just barely from the first version. I'd make them again if I were putting together a kit for sale or if this were not my personal car but again, for my purposes, a little filing and these will do the job. Once I get the filing and all the bolts in their respective places I'll be putting in the front knuckles and figuring out the second mounting point for the lower control arms. As far as length and diameter goes, these coilovers look like they were made to fit this application now. Very excited.
  4. Well, I got the crossmember bolted in late yesterday afternoon/early evening. Looks like my measurements for the holes and slots were close enough to make it work - I did have to knock the passenger-side/right-side stud out of the stock rubber transmission mount to get things to bolt on properly. This is temporary, again due to the offset of the stud pattern on the mount. I'll most likely install a replacement stud in parallel with the existing one for this build, and if/when it comes time to put in a new mount i'll adjust the crossmember to suit. (The CAD file has already been updated to match so other future builds should be just bolt-on.) I'd be very interested to get in touch with one or two more individuals doing Gen 1 builds like this so that I can further beta-test this crossmember design. If you're looking to do similar, get at me! Once I've got the *new* new camber plates on hand it's going to be a hard charge forward to put the impreza suspension in and the front wheels back on the ground so I can start cutting out the impreza transmission tunnel, rear suspension, and anything else I might need so I can reclaim its current parking spot. Truckin' right along! Thanks for following!
  5. Well, parts arrived, and i have some iterating to do, but progress is progress. I made a slight mistake on my CAD draft of the camber plates 😕 The stud locations are dead nuts on, as is the center slot, but the slots for the plate-to-strut attachment screws don't line up. I'll have to get a second set made, oh well. I might hack up the original ones that came with the struts to get me by until they arrive but the turnaround time on these was so fast I just might not bother. Similar story for the trans crossmember but it's less serious there. I didn't design the slots in the middle quite far enough forward to accommodate the offset of the stud pattern on the transmission mount. From where I was measuring under the car on my back things seemed to be much more in line than they actually are. I'll be making the slot a little longer on my current build out, but the likelihood is high that I'll want to remake this part too later down the line as well. If anyone needs or wants one of these transmission crossmembers from me in the future I will have it fixed by that point. Photos in the car to come as soon as I'm able to spend some real time under there, maybe this evening, maybe tomorrow.
  6. Been on a bit of a stall since the last little update for some event travel, but over the last few days I got out the tape measure and CAD and have modeled up a new crossmember. Finally bit the bullet and had it sent out for CNC cutting, and bending this afternoon. Also have the camber plates for the new suspension included in this parts order - so hopefully I'll have a good bit of progress after those parts get in, probably a little over a week. This'll be done in 1/4 plate and the final piece has had a bit width removed for weight savings so I'm hoping I can get away with building this without too much additional fabricating. I suspect if anything I'll want to add in some gussets to the bend areas as a belt-and-suspenders approach. On the flipside I'm also hoping I don't get this thing in and say to myself "man I really overbuilt this thing" - aiming for the Goldilocks zone here, so to speak. If other folks have other Gen 1 cars of similar body style, I'd be interested to see if the crossmembers and bolt locations are the same across 79-81 and across the brat and wagon platforms. If they're the same or not too different I'd be able to put a more commerically-viable version of this together pretty quick with the right datasets and measurements.
  7. Small update from today - had a couple minutes to tinker at the end of the day (much better workday than Monday). Got the stock rubber transmission mount bolted to the transmission under the car and wouldn't you know it - the bolt holes for the original transmission crossmember are very very conveniently placed. Almost directly in line - should be able to build a very low profile replacement crossmember with little difficulty. I'm probably going to use some plate or chromoly tube for simplicity's sake. The great part about this is that much like the camber plates for the front suspension - I will readily be able to make these parts for someone doing the same or similar conversion, and I intend to do this pretty much anywhere and everywhere possible.
  8. ...Yesterday. Yesterday was a Monday. Benefit of self employment is that when you have a garbage day at work, often you can stop what you're doing and change gears when things aren't going well. So that's what I did. Shipping carriers made a mess of my Monday morning and so instead of snowballing that terrible feeling into the rest of my day, I decided to start plugging away at the engine/transmission mockup a little, just to take my mind off things and see where I got. Well, I hit a pretty good milestone without too much fuss. First photo may look familiar, but difference this time, is that i didn't just stab an engine in there - the engine and trans are both bolted up together, and the clearances are very good. Still tight at the valve covers, but that's no surprise. Plenty of room at the firewall and tunnel, and today after my lunch break here I might start taking a look at what I'll need to do fabrication wise to get the impreza transmission mount hooked up to the Brat chassis. Still have a little work to do to get the steering rack hooked up, this mockup is a great visual on the interference happening with the new transmission and the rag joint. I'd really like to avoid chopping up the bell housing to do this conversion. While i've seen it on almost every build I've been able to find, and while it's probably totally 1000% functional, it just doesn't feel the right way to approach the build If i can manage it any other way. With that in mind, first I'm going to try to open up the hole and play with the mounting bushings a little bit to see about getting the impreza rack to fit. I think with a little clever measuring of the Impreza crossmember, I should be able to figure a way to mount it up to its equivalent in the Brat without *too* much fuss. Absolute worst case I can chop the impreza crossmember up to shorten it to fit. There's some benefit there and I've seen it done on one build as well - the reason I haven't started with that first is more a logistical one because of my storage limitations - (see the "neighbor saga" above) If i need to use the impreza crossmember to get the steering to work it'll be a little bit of retreading ground, but once I have just the one car shell to work on I don't think I'll mind that too much. That's where it sits now. Engine and transmission are where they roughly need to be, and I can close the hood over all of it. Camber plates for the front struts are on the way too. I'm pretty close to ready to chop into the impreza for the front end suspension conversion - I can almost taste it.
  9. Thanks, moosens! I see the view count steadily climbing - This is really mostly a build log for me than anything else, a repository for the photos so folks doing similar might find something useful in it. Audience participation is not required 😅 That being said i have a pretty good update, so buckle in for some more photos! I'm going to split these into two posts to help manage my thoughts and keep things coherent. Last post I'd marked where I need to rough cut to get the 5 speed in under the car, so earlier last week I finally took the death wheel to the tunnel. I also needed to cut into little tiny bit of the firewall, but I've not started disassembling the dash or any of the guts under there. Luckily I'm not a huge dude so with no engine or trans in it I was able to jump in the engine bay and cut from the inside where i needed to (only the frontmost horizontal cut, really. The rest was accessible from inside.) Garden hose and fire extinguisher were at the ready in case I caught any old matting or something on fire under the console but no such emergency occured. I will need to get in there and remove the dash and underlying componentry to assess the condition of those parts - as evidenced by the clutter in the cab, I'm really leaning towards splicing a lot (if not all) of the impreza interior workings and trims into the cab. If I can restore the original dash I will do so, but at the moment I'm not sure how much hodgepodging is going to be necessary under there to keep everything working as it should, given that I have decided to do an entire wiring harness install from the Impreza - completely replacing the old crusty stuff in the Brat. But I digress - none of that can happen until I've built a roller of the brat again - so after the tunnel cut, I roughly placed the transmission where it will live by way of careful propping up on jackstands and the engine crossmember , and promptly left it there for a few days... until yesterday. Onto the next post!
  10. Spent a little more time on some further disassembly last night - got the control arms, sway bar, and transmission crossmember out without having to cut anything major - just one little bracket needed chopping to get the parking brake cable off - the bolt was so caked it was practically cemented on. I've also removed the steering rack so I can drop the engine and transmission on without running into the rag joint while I work out that problem. After reviewing some other builds again (there are only so many I've been able to find) I may end up switching tracks and modifying the impreza engine subframe to fit in the Brat for an easier time getting the steering rack clearances I need in order to avoid chopping up the transmission bell housing. For now, however, I'm going to push ahead using the modified Brat subframe so I can keep the impreza actually rollable for a little longer. I need to put together a couple dollies for the husk so I can keep workflow going in my shop during the day, and once i pull the control arms, knuckles, steering, and front suspension components that becomes much much more of a chore. I've got the camber plates sketched up and getting ready to be CNC'd - very excited for that part. I'd like to design an adapter to allow for the install of these coils into the original knuckles while I'm in here for the folks more committed to keeping the 4x140 bolt pattern than I am. In combination with the coilovers & camber plate adapters this may end up being a serviceable way to get new suspension on these old cars.
  11. Annnnnd we're back from the holidays! Thanks to my storage solution for the Impreza husk I'm pretty motivated to get that disassembly completed enough to be able to get the shell out of my shop, and in order to do that I've determined I need to be able to mount and store the engine and transmission in their proper places in the brat before I can start installing and adapting the steering and suspension components in around that. First go at the transmission mockup was yesterday, but I didn't bother taking photos - it was a hassle to say the least, but i did learn some things. The transmission doesn't just 'drop in'. Not even close. Kinda expected this, but I'd still hoped for a little miracle. It's a difficult install without coming in from the bottom - next time I'm going to try to block the body up taller and lift it in from below with a HF special transmission jack. As mentioned in the last post, I'll need to modify the steering setup, either by installing the impreza rack, or somehow shifting the existing one without inducing any gnarly bumpsteer. Any suggestions there would be awesome. I've since been in touch with a guy who built a similar '79 wagon and his solution was to chop up the bell housing. I'm not really willing to go and do that (yet.). Lastly I'll need to modify both the trans tunnel and the crossmember. On newer builds there's enough room to stab the EJ transmission in just weld in an extra plate to relocate the mount holes to match. My particular car does not appear to have the clearance to do this, and I'm hoping not to put in a body lift so I will likely be adapting the EJ crossmember to fit in some way. If this proves to be fruitless or too complex I may explore the body lift at a later time. I'm planning on cutting the tunnel out just enough to get the transmission IN the car on its own, then I'll trim away as needed and splice the impreza tunnel in to get the bolt holes and mounting points I need. These new tidbits of knowledge in hand, I got to some more fruitful work today disassembling and disconnecting the front suspension so I can remove the Brat's transmission crossmember. Dirty work, and so many of these bolts were caked in 30 years worth of oil/dust/dirt crud mix it was hard to determine where they all were and bolt sizes. To be expected there were some siezed threads. I almost decided to just whip out the death wheel and start cutting, but I came to my senses when I remembered how hard parts are to find for these things so I'm going to do my best to affect a non-destructive disassembly where possible in the off chance someone needs some of the parts. Lastly the other day I also scored a deal on some inexpensive coilovers - almost no miles on them as the guy bought them to keep his "good ones" dust free while getting bodywork. Lucky me, as I don't need fancy or clean at this stage. The stock impreza suspension was giving me a headache on how to install them and were really going to be tight because of the spring diameter, but these have a much thinner spring and some really simple camber plates - something I'm very very able to make in order to fit the stock brat towers.
  12. A little more progress this week, but alas I won't be able to turn a wrench or start working on the next phase of the thing for a while, so next update will be in the new year. Looks like every time i make a step forward, a corresponding step backward shows up in the form of another problem to solve. Firstly - the step forward: Successfully got the frame rails notched out - handily this exploratory cutting revealed that the extra crossmember hole is already reinforced inside and as such will not require me to sleeve it in order to move the mounting bolts out of the way for the frame work. it also appears that widening the mounting slots also did the trick and with the transmission removed and out of the way, the new EJ22 drops right in where it needs to be, plenty of room, way more than i was expecting to end up with. Just have to hit it with some rust converter and weld-through primer and box it back in now. Secondly, the step backward - The original steering rack is now (just barely) interfering with one of the lower studs that mount the transmission to the engine block, so now I have to figure out a way to get that clearance back, none of the other builds I've followed mention this as an issue - either that or I just wasn't paying enough attention. . Options I've come up with so far are: A) shift the original rack to the driver side of the slightly or maybe extend the shaft so the soft, disc-shaped connection (not sure what that part is called) doesn't interfere with the stud or transmission case. B ) Transplant the power steering rack from the Impreza, which doesn't use this same connection to the steering column and thus should clear. I'd planned on doing this anyway though I'd hoped to get the rest of the transplant done first for logistical reasons (It's easier to move two cars around when they both have working steering for as long as possible) which If any 2nd- gen swap guys have run into similar issues, I'm all ears - So far most of the stuff required for the swap into this earlier Gen 1 seems to be very similar to the later Gen 2's, just with less room to work. Hoping maybe one of y'all have a good suggestion. I'm debating at least for the mockup phase for the transmission, its requisite mounts, and the transmission tunnel modifications to maybe just remove that stud and see if I get lucky with the clearance on the transmission case. Anyways, that's a wrap til 2025 - In broad strokes, once I've got the engine and transmission mounted and located, it's on to front suspension transplant, then stripping the rear suspension off the Impreza shell and scrapping that to get the space back to fabricate on the rear end of the brat.
  13. A little more progress today - got the old 4 speed out. The mounts were so tired from being out in the elements that i didn't even have to disconnect the fron suspension fully to disconnect the inner CV joints. Other than the thirty years of grime and the mounts though, it's in really good shape. All gears turn smooth and 4wd engages/disengages like it should. I'm more than slightly bummed to be ditching the selectable 4wd, but this thing will definitely not hold up to what I'm doing long term. It would be really cool if there were a retrofit or modification for these transmissions to get that to be a feature again but all research I've done seems to point to that being a very expensive proposition at best so AWD it is. The trans case sizes are definitely different, and like everything else on this thing I have some fabricating to do to get the linkage to land where I want it in the cab. Having them sitting next to each other on the ground like this gives me some ideas - I think I might be able to just shorten the linkage or even get rid of it altogether to put the shift lever on the EJ transmission closer to the stock position of the EA71? I'll have to sit with it and have a think. Also got the engine bay lightly powerwashed, then extended the slots for the engine mounts on the original crossmember in prep for the next engine test fitting. During the last test I measured from end to end of the mounting studs and found that the Impreza slots are only about an inch wider than the brat. (15.5" on the Impreza, 14.5 on the brat) The angle of the landing pads are similar enough to where I don't think those will need any shimming or major adjusting, so it's a matter of taking a step bit and an angle grinder to add the extra clearance at the ends. I'll be going back at it with a dremel later to tidy up the work. If you have a die grinder (which i should own but don't) this would be an even easier approach to this. Gonna try to hold myself to a higher than normal standard on this one, and I'll be cleaning up things as I go back through it during the project to clean up little things like the scoring visible from the angle grinder in these photos. Probably going to try to sneak out of the house a little tomorrow on Christmas Day after the morning festivities and get a jump on the notching, maybe try for another test fit before I'm off the project until the New Year. I found out yesterday while I was staring around dissociating in the empty engine bay that there is an extra hole (second photo on the last post) that goes all the way through the frame and crossmember. This would be ripe to sleeve and move that front mounting bolt backward far enough to get as much clearance as possible if I either find i want more than the current configuration allows, or the more likely possibility that i f*** up on cutting into the frame and hit the existing bolt hole/channel by accident. Once engine and trans are rough fit into the Brat it'll be on to front suspension transplant, and then I'm going to try to strip every other suspension part I'll need from the impreza in one mad scramble so I can scrap the husk and get my full garage footprint back. It's really tight in there and it's kiiiiilllling me. Somewhere in that kerfuffle I'll also be listing the EA block and trans for sale so if you're looking for one of those, hit me up or keep an eye out then.
  14. Code compliance issue is no longer - gave the compliance officer a call and he was extremely easy to work with. Donor husk is in the garage for the time being, but apparently a car cover will suffice if I need to move it back out into the drive. That out of the way, we got the first test fitting of the EJ out of the way yesterday. It would appear that with only a slight extension of the mounting slots on the original crossmember, the new engine should drop right into it, but as expected the fit is very, very tight. It could (by my measurements anyway) be done without notching the frame, however that would leave mere millimeters of clearance at the back of the valve covers. It will still be a much tighter fit than its original chassis even with notching, so like past builders I will also be notching the frame. (Noted where I'm notching things out in blue sharpie in the photo.) I should have about a half inch of clearance on either side when that's complete unless I find a way to relocate that forward mounting bolt for the subframe - in which case I can probably get a little more. I also have 99% of the original wiring harness out of the donor now, and I'm pretty decided on attempting a full retrofit of most of the newer components into the old car, including the HVAC system. By my eye everything *should* fit, but it will be extremely tight. Since I'm also going as far as installing pretty much everything else of note from the impreza, I'm also considering either adapting the power steering rack to fit the old Brat crossmember, or adapting the Impreza crossmember to fit the Brat, although I suspect the simplest route would be to ditch the power steering in its entirety and just use the original Brat steering gear. My only concern there would be replacement of components on the steering gear down the line - I hate having to track down parts for weeks or months at a time. These next few days I'll be pulling the old 4 speed from the Brat and starting on the frame notching job. Somewhere in there I'm also going to do a refresh on the EJ while it's accessible. Oil pump, rear main seal, timing kit, that kind of thing, but that will likely be after the new year holiday, especially since I forsee a lot of removal and reinstall of the new engine and transmission while i do the fabrication on the crossmember, firewall, and transmission tunnel to get those to fit where they need to be. PS - as i build on this I'll be putting the parts and pieces I no longer need up for sale, including the complete but now partially disassembled EA71 engine. Maybe someone with more patience or skill can get that head free and give this thing a new life. Same goes with the transmission and other miscellaneous components as I go.
  15. Good suggestion - I'm ahead of you with the car cover and had it purchased the day I brought the donor home. It is now underneath said cover and I'll be turning it around to face the house so the missing hood isn't so apparent. I'm in full agreement that it's an eyesore, I'm just surprised at the quickness of the neighbor though perhaps I shouldn't be, our municipality provides a live app to report with now. Whether it is enough to satisfy the city, well, we will see. I suspect between the cover and having one of these in the shop at most times should be sufficient to keep everyone off my case long enough to cut what I need off the donor husk and send it to scrap. Regardless, I've got inflated roller tires on both vehicles and the cover on the donor now. Going to clear some space in the garage/shop to push things in and out so I can start fabricating. Picked up the final major piece to the puzzle for a while yesterday as well - a relatively fresh 5 speed cable transmission - the only major part the donor didn't have.
  16. Small hiccup, probably the first of many. I've got a neighbor who has appointed themselves the code compliance patrol and as a result a letter from the city regarding the new donor husk. Vehicles in the open need to be registered and "Appear operable." Gotta give the neighbor credit, they work fast. Brought the donor home on the 11th, and the report is dated the 12th. Not even a full 24 hours. Some people, am I right? Operation "put good roller tires on the brat" is the new name of the game, and operation "fast track the impreza stripdown" is shortly behind it. With rollers on the brat I should be able to rearrange the shop a little to let me push it in and out as I work on it. Gonna need to get it in there anyways at some point to start the fabrication work, so silver linings I guess.
  17. Got the main bulk of the wiring harness pulled out this afternoon - It's pretty freeing to be able to just yank stuff out without worrying about "will it go back in where it came from and look good." (after labelling connections, anyway) Still finalizing exactly what I'm going to keep vs what I'm going to abandon - but right now planning on transplanting most of the Impreza harness into the Brat body and adapting at the terminations where needed, especially since I'm not sure of the condition of the original wiring. I'm also even more heavily leaning toward retrofitting in the impreza HVAC unit and lower center console trims. Taking a good imaginative sit in the gutted cab of the Brat holding the trims and HVAC parts up to the available space has me nearly convinced this is possible, especially since I also plan on transplanting the trans tunnel from the Impreza where that console and handbrake mounts up. So far so good. Still a scary prospect of a project but even only at this point, I'm still learning a lot.
  18. Hey all - my last old project subie didn't work out so hot for me, ended up having to sell due to various circumstances after getting her running again - lost steam when she needed an AC repair that was just a pain to chase. Recently though I've jumped back in with both feet (up to my neck, it would seem) and I bought a '79 Brat with the original intent of breathing life back into the EA71 that was in it, however that would appear not to be in the cards for me. The freeze plugs popped when the little truck was parked (probably back in 1997), and with the water in the heads and valve gallery the studs have all but rusted the heads to the block permanently (as far as I can manage, anyway. I've included a photo of my skookum in this regard - someone may have some tricks and better luck pulling her apart and rebuilding than I but after a week of every penetrating oil mix, mallet, block of wood, and sledgehammer in my garage I have put that aside.) During my initial attempt to revive the old car I also found how hard it was to get critical components like front strut assemblies, 4x140 wheels, etc. It seems these parts are just getting harder and harder to source, and the ones I found on the used market were a bit of a gamble at best, so I Bought a '97 Impreza OBS with an EJ22 and 5 speed to swap in. I'm hoping this build thread will help keep me somewhat accountable and also give me some motivation to document what I'm doing. I've always been in awe of folks who can put together a build thread or repair thread start to finish and have found a number of them extremely helpful in the past on other projects - perhaps if I detail what I'm doing here it'll keep me on track and give back in a way, as what I have in mind is no small task. I've only seen it done one or two other places that still have the photos and details available, and not in detail on this particular vintage of subaru, at least not to completion. Anyways, enough blabbing on from me and onto the broad strokes of the project: Take my 1979 Brat husk, and replace as much as is possible of the underlying driveline with the components out of the 1997 Impreza wagon while keeping the outward aesthetic of the old truck. I've seen swaps like this completed on Gen 2 Brats, both with the entire driveline swap and just an EJ swap with an adapter plate. I intend to follow the former path as the original EA71 transmission would be short lived with the new engine, and since i'll be replacing a lot of the suspension components matching things up I would imagine will be easier. Current state as of this intial post - Brat: interior is mostly gutted, still need to remove and recondition the dash and get a sense of the condition of the underlying components. Engine is out, but still need to pull the transmission and test fit the EJ. Expecting based on all the other Gen 1 swap documentation I've got my hands on to have to notch the frame pretty good to get clearance, and probably some significant transmission tunnel work too. Impreza: Interior is also mostly gutted, ECU is removed and in safe storage inside. Removed the dashboard, heater box and AC componentry. One good more push and I should be able to have the EJ wiring harness out to begin thinning that out. I'm considering attempting to retrofit the OBS A/C system into the Brat, but I have to look at the mechanics of how that might work and whether or not I'll have the real estate. Anyways, wish me luck - I really hope I don't make an rump roast of myself with this one 😅
  19. Having just gone through an EA82 rebuild myself (the cause of which was mostly valve-related), i would highly recommend you make sure that valve is not bent, sticking, or mis-seated. There's a chance that can start a cascade of pretty gnarly failures. Easy enough to take the springs and keepers off to see how the valve moves in its bore. That being my $0.02, i'd also wait for someone with more than one rebuild under their belt to chime in.
  20. Those part numbers appear to be what i'm looking for, thanks freddo! Tried emissions with the drip, no one said a word. Any chance that this is something I can do without yanking the trans or engine? I literally JUST put everything back together . It looks like i can just put her up on stands, pop the driveshaft and exhaust out of the way and pull the seals in question.
  21. Hi Folks - you've all been stellar helping out with my '87 rebuild. Good news in she's running again, like a sewing machine compared to the last go around. Bad news is that now that I've been able to get things moving again, i've found an oil leak out of the rear transmission seals. (All of them.) My question however, is this - It appears there two shift shaft seals on the dual-range 5MT transmission (one for the gears, another for the 4wd, i presume). Are their respective seals the same part numbers? (Cruising RockAuto and hoping I can just grab two of them from there, but they don't have a distinction between the seals). The output seal seems okay-ish but what I assume to be the shift seals are dripping wet and sit straight over my exhaust. They're leaking so constantly I'm wondering if i'll pass emissions this way.
  22. Scratch the last post - answered my own question. It's labeled. The good news is the valve wasn't bent. The bad news is that it was completely snapped, and has been rattling around the cylinder for quite a long time judging by the carbon buildup on it. Also the previous owner had installed a spark plug about a half inch too long, which i think might have been my precipitating problem: Long spark plug -> Stuck open/broken valve -> dropped rocker -> disintegrated lifter. Surprised it was still running when i pulled the engine out.
  23. Update to this project - Got my new cam, lifter, and some other misc. bits. assembly lubed and reassembled everything. I did the timing (not in the car thankfully) and when giving hte engine the cursory check of turning it over a few turns by hand, i heard the now-distinct click-clack-clunk of the rocker falling off the valve again. Cracked the cover back open and the same valve is sticking. I think this may have been the ultimate root cause. Sticking valve due to sitting for who knows how long-> running like a dog on a dropped rocker for who knows how long -> mangled lifter in my oil pan for you guessed it, who knows how long. Here's hoping there's no major cylinder damage. As a semi-sidebar, the frontmost valve on the right-hand side (US passenger's side) of the engine - is it an intake or exhaust valve? Chances are i'll need a new one.
  24. From what I understand it's with the cam roll pin at 12 o'clock. I figure I'll find that out when I get to it. It's a bit late for me to get the pair, the other is already on the way. If it runs oddly I'll swap out the other side but at this moment I don't see a pressing reason to do so (best practices aside).
  25. Will do, thanks to the both of you. I poked around and looked at how the other lifters sit. I'll do the bare minimum to get the lifter to fit back in nicely but otherwise leave it be.
