My buddy Eric1111 has been working on my car. I cant sign into his account for some reason to post this so I made my own account to post for him.
(Loyale 1990 with weber conversion)
Eric says--
I've just finished replacing the clutch components and was to the point of trying to start the engine. It turned over nice, sounded good, good battery, but I hadn't hooked up the throttle. Next try, turns over nicely, timing's off, shut off the key, adjust timing. Try again, turns over, but timings wrong. Shut it off, adjust timing. Turn the key and nothing happens.
Now the horn works, the emergency blinkers work. The chime that tells me my hand is on the key works, but I can't find anything else that does work.
All the fuses look good. The fused links look like they did before, and I switched them around,looking for some change.
The battery reads 12.48V, (It was 12.49 before I jumped the starter, which turned the engine over easily), but at the ignition switch,the hot wire reads 11.82V, with the key in the off position. Is the 1 volt loss an issue?
I thought I had it narrowed down to the ignition switch. Replaced that to find zero change. Been workin on this car all day with Adam Sandler's POS car tune going in my head. Any thoughts on what the issue is?
