Yukon Cornelius last won the day on June 28 2020
Yukon Cornelius had the most liked content!
Location
Georgia
Referral
Internet
Biography
20 Year Tech
Vehicles
1986 subaru brat
Recent Profile Visitors
Yukon Cornelius's Achievements
Advanced Member (3/11)
6
More on oil pressure woes.
Yukon Cornelius replied to Yukon Cornelius's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yup. Drove around for about 2hrs last night. It gets down the road alright for an old barn find. -
Cranks and wont start
Yukon Cornelius replied to Arthur Digby Sellers's topic in Old Gen.: 80's GL/DL/XT/Loyales...
So I've been having this issue as well. Try hammering on the distributor while some ones cranking. LOL. it seems to work for my Brat. Has a new ignitor and I still have this issue. Maybe I'll replace the distributor. -
Ending oil pressure is 12psi hot idle and 22 psi 2k rpm. Confirmed internal engine wear is the cause of low pressure. Just drive it till it quits -
Yeah, I couldn't find one for sell. Though the operating temp oil pressure was at minimum acceptable spec. I decided to inspect it anyways. Glad I did cause it looked terrible. I'm sure the internal engine clearance is worn as well and oil pressure is never gonna be high. But that pump was about to crap out and seize up. I'd hold on to that pump if I were you. They seem rare now. I'll post new pressure readings tonight. -
Sooo..... pump disassembled it looks like crap. Pump shaft is damaged and housing it done. Had a rough looking engine that came with the Brat. Removed it and it looks great. Even though the engine looks terrible. The pump is top notch. Will report new pressure readings when installed. -
Thanks Bud. It was leaking too. Sounds like a reseal and run it. It did look nasty in the oil pan. So I'm just gonna run it till it doesn't any more. -
So I've decided to rebuild an oil pump on my son's 86'Brat. Oil pressure is 45psi dead cold idle/ and 70psi on cold 2k rpm. Hot idle at 800rpm is 12psi and 20 psi at hot 2k rpm. I would just replace the pump or internals if I could find one. Anyone have any suggestions on parts location. Google has kinda failed me. On a side note the cheap oil pressure sender is correct and the gauge is showing about right. Just kinda low oil pressure. Oh yeah, I pulled the oil pan to replace the gasket and found nasty metal sludge in there. Dang!
Meh, cleaned the contacts and reassembled. Still does the same thing. Not one of the more pressing issues with the vehicle as its charging 14v during operation. And the list of issues is long. I'll come back to it and report a repair when I find it. It's most likely just diode issues. But, not bad enough to fail the diode test on my tester. Moving on to rear brake hardware and fuel level sensor
- 9 replies
- alternator
- regulator
(and 1 more)
Tagged with:
- 9 replies
- alternator
- regulator
(and 1 more)
Tagged with:
- 9 replies
- alternator
- regulator
(and 1 more)
Tagged with:
