573417h
573417h last won the day on October 17 2024
573417h had the most liked content!
  • Location
    New Zealand
  • Referral
    Watched lifted leones from Washington many moons ago and wanted to fix sloppy shifter...
  • Biography
    Passionate about old subarus for a long time. Finally purchased on as a project and have been tinkering since
  • Vehicles
    84 Leone wagon
Recent Profile Visitors
573417h's Achievements
Advanced Member
Advanced Member (3/11)
26
  1. Leone’s 1979 Subaru Leone wagon discussion - Project Discussion - oldschool.co.nz Here is a thread of where im at, it's pretty slow going right now, so much rust to cutout and replace, and as i haven't done a build quite like it I'm taking my time, Have a professional panel beater on hand for the tricky stuff so no I'm mainly drilling spot welds and attempting some fabrication of patches and panels (that wont be seen)
  2. hi MKA, is a car cover an option, as this will get around the "being in the open" part, i suspect your neighbour doesn't appreciate the current eyesore lol -regardless of what it might turn into.
  3. i would check the cam angle sensor just to make sure its doesn't have an injector plug on it... and vice versa, if it doesn't then sort the cam belt..
  4. Hi, I suspect a sensor could be incorrect, IE injector plug on CAS or similar. however, since you have indicated fuel I'd start there: - Ensure there is enough petrol and if in doubt put another 20L into it... then check to see if petrol is getting to the rail/front filter, if it is you can assume its not petrol related If its not... then hardwire the pump at the plug to a battery to see if its pumping etc, then you can start eliminating things that make the pump run ie wiring/relays. If it has fuel getting all the way to the rail/filter, then id check if it has spark, if it doesn't have spark then you can start trying to figure that why. If it has spark and fuel, then id compression test it and go from there....
  5. Yea im building this one properly as it might be the only one in NZ.... Im also doing an ea81 wagon (Not sure what series these are called) but its more of fix the rust every 6 months to keep it on the road. I have it documented on another local site if anyone wants a link - not sure about forum etiquette around cross posting.
  6. Once it comes back from the sandblasters i will take a heap of photos and share them here. Ill also document all the repairs i suspect this will take me a few years to complete.
  7. Once its back from the blaster ill know more, but initial inspections show rust requiring repairs: -top of front right wing (where the guard bolts too) - both water drains under the scuttle panel into the guard are fully gone - front firewall flat panel, around where the fuel line comes thru,and one the front right part of the firewall where the brake master sits - Front/mid floor pan already has patches done and we will unstitch the entire floor and rebuild - as chassis rails has some dints requiring removal - rear wagon floor near end /latch is looking pretty thin and likely need replacement - very minor (at this stage) in the gutters on the right side. A couple of pics from earlier in the piece:
  8. Car has been fully stripped and is now at the sandblaster, can't wait to get it back and get a plan in place for all the repairs
  9. Hi Bennie, Haven't tried cleaning it yet, might give it a whirl to see how bad it is, it will likely be much cheaper to grab a 2.0 block and build something from there. Cheers
  10. Spoke to the guy this AM, he doesn't want it back and we have come to an arrangement on price, i doubt this block is savable, but id be keen to hear any (even rough barstar* type) fixes
  11. I haven't pulled the head off the other side yet, and don't think I'm going to, guy wants the motor back to give me a full refund and then he is going to dump it which is sort of annoying as i need the heads and intake as i could just slap them onto another EJx motor, but at the end of the day if that's what gets my money back I'm ok with that. I'm based in New Zealand, so these motors are kind of a rarity, but finding a dohc turbo EJ is dime a dozen. Shame our govt rules on modding a chassis is a lot harsher than putting a late model motor in. I'll keep my eyes out as i was quite excited about getting this one in the engine bay etc.
  12. after sleeping on it i decided to put a magnet into the bore and some rusty stuff came out of one of the spark plug holes, so whipped that head off... its not great news.. its locking on a thick layer of rust, guess im getting a refund.
  13. Hey team, Got a motor 2nd hand Ej22 engine from a reputable source who drove the car before it was stored (this person will refund me should the engine be toast) and the engine is locking up when you turn it over, have pulled timing cover/belt/plugs and it spins freely for a bit then it hits a dead stop. My immediate thought was it skipped a tooth on the timing belt and it's locking up on a valve but since taking the timing belt off and turning the cams, however when the motor is in the locked position they still spin freely. Engine is sitting on the mounts, no gearbox etc to rule out anything with the clutch. Any other ideas where else i can check without pulling the engine to bits? - i thought maybe a bolt in the bore, although that is maybe a long stretch? Thanks in advance.
