pvfahrer
Location
New York, NY
Vehicles
Legacy
pvfahrer's Achievements
Advanced Member (3/11)
Okay, so went back to the car, no error codes in the ECU, started the engine up, no knocking noise which is reassuring, however the engine stared to blow an impressive cloud of smoke, which it never did before.. i am wondering if this is still remnants of the sea foam treatment, but that's more than 100miles and an oil change ago..well compression test and oil change back to 10w30 next and then some more oraceling...
Here’s a weird one, I changed the oil in my ej251 vanagon conversion to 20W50 to see if the oil consumption is getting better. Engine ran fine before no unusual noises etc., earlier today I stopped at a street light when all of the sudden the engine started making a loud knocking noise, pulled over to check if anything came lose.. all tight, knocking sounded like rod knock.. I decided to baby the car home. After two minutes the knocking disappeared. Car stuttered two three times and was running as before… WTF?!? Can a rod knock be intermittent, did I lose the oil film for a moment? Is it the oils fault? I had 10w30 before, maybe I should go back to that?!? Head gaskets, timing belt, idler, tensioner and water pump are new. Any ideas here? I will drain the oil and replace it with 10W30 again, and see if there are any metal shavings in there. I will also check the timing belt tensioner, although it was new just 400mls back.
I did a bit more digging, apparently the pump i got from the junkyard with he small bolt patter was 90-92 and my engine is 93-94.. Would this make sense that the early engines have the smaller bolt pattern and the later ones have the larger one? Also would you folks in general recommend rebuilding the old pump or just go with a rebuild/new one?
Hi folks, My power steering pump started to make noises and i am finding metal shavings in the oil. I was trying swap the pump with another pump that I got from the junk yard, only to find that the bracket had a larger bolt pattern. Can anybody help me to identify the pump that I need? The bracket that I have has the larger bolt pattern it differs maybe 3/8 - 1/2inch from the other pump that I got from the junk yard. The engine is a ej22 obd1 with two large connectors, so probably 1993-1994. Thanks!
yeah i guess that would be option 1B, i have somebody who's selling a EJ22 long block local for $150... rings and new head gaskets and maybe some odds and ends are probably $200. So i could also go with the EJ25 for the same money. The engine that mooens offered is a DOHC out of a Forester no EGR, so this would mean i could take the entire engien and plug and play it right into the EJ22 OBD1 loom, guess i would habe to get the appropriate ECU then?
Okay i see there is more information needed here, sorry. I have an EJ22 Obd1, likely 93-95 (only two grey connectors), in a VW vanagon. This engine seeps oil (got a lot better after replacing numerous seals and gaskets) and uses a lot of oil (1qt on 250mls) on the highway. I am trying to see what my best options are here. Option (1) take a EJ2.5 engine and slap my EJ22 heads on and do straight replace. Problem here is that i don't know the condition of my heads and my oil consumption and uneven compression could be from bad heads as well. So i would end up having to get the heads rebuild which defeats the purpose financially. Option (2) take the entire DOHC EJ25 engine and replace the EJ22 OBD1 with it. Here i am trying to understand to what extend the wiring of the EJ22 OBD1 is going to be compatible with the 99 EJ25. An additional question would be, are the wiring looms and ECU of lets say a 99 DOHC and a 98 SOHC engine identical/compatible. This would be for the case i start searching for a loom. Option (3) find a Subaru H6 and do the 6 cylinder conversion i was always dreaming off.. but thats kind of a long-term thing Option (4) stop wasting my time and get a modern car... although that will most likely not happen because this would be dull. SO i guess the main question i am having is, what wiring and ECU are compatible between engines and years.
So, i am in touch with somebody here from the forum that has a decent recently re-sealed EJ25 engine for sale and i am trying to establish if this is a good choice for the Frankenmotor. The engine is a SOHC EJ25 apparently from a 2002 or 2003 Legacy GT with EGR. From what i can tell this should be an EJ251 or EJ252. From what i was able to get out of the information about the Frankenmotor, this would actually be a good candidate. @GeneralDisorder maybe you have a word to say on that?
