Zeky
Everything posted by Zeky
New Roo in April
Zeky replied to Lukas's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Please please, have no idea what DUAL RANGE mean..... -
Oh yeah,Thanks guys u are right and the picture clear it all up.But i knew where the sensor is but didnt knew there are two..... So if i unplug the 2wired one no fans start up.Just engine change RPM fluctuating for a while but then stabilize.If connected back do the same.This means that sensor is working i guess.So i am going to study wires diagram and find the right damm wire.By the way where is ECU located. PS.A/C turns both fans on?My do.
Well what u wannt to do is called "transmission power flush" and in the shop is about 90 buck's.The way u wanna do it by your selfits the good way and synthetick is definetely best choice.But Do it like this: Find two(2) budgets big enough to hold all tranny fluid ,then fill one up with new fluid(find yourself how much your tranny need). Then unhook both hoses from radiator and place the one which is sucking the fluid from radiator to budget with new fluid. And the other one to the second empty budget then start engine and wait until clear red fluid start comming out .... Connect all back ,clean the mess and u are done.. Later i will post a link to better directions from other forum ..(now is not accessible)
Air condition
Zeky replied to Zeky's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Yeah ,thats what i am thinking about.And by the way i am now living in US :cool: And just share your pain and tell us what u did with your A/C :banana: :banana: :banana: love this smile ...banile? -
Hi guys, my 92 Legacy main fan wont start so car is overheating.I checked the fan end is OK.I try bypass the main fan relay and it works. If i connect pins 3 and 4 (the pic)fan starts rights up - thats normal. But if i bypass minus right from battery to pin 1 (or 2 not shure right now) the fan starts too.... so is that normal? What is switching relay to ON ?The coolant temperature sensor?But the temp gauge in dash works fine.... Any diagrams of it?Eny experience? Thanks in advance....
timing belt
Zeky replied to timintc's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
They should change water pump ,timing belt tensioner end at least check all pulleys if neded change them also.Some people sey crankschaft seal to....l -
Air condition
OK , so filled up and here we go its running strong Just need to know if i should put some oil in -
Air condition
This is what i have ,so it has been converted but still doesnt work :-\ Later today or tommorow i will try to fill it to top and let you know... THX -
Air condition
Consider fan is running ,but i think it may be already converted... BUT HOW TO KNOW http://www.ultimatesubaru.org/forum/showthread.php?t=33889 I appreciate your help -
Axle stub play?
Zeky replied to kidwired's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX
Well, i think in/out play may be ok cose the stubs are removable.If its free side to side then may be a problem with differential bearings.But i am not sure about this.May be someone else will tell u ...... -
Hi i got the sam eproblem "how to know if it been converted" And i dont understand clearly what u mind by this: EDIT: Well, may be i figured out i got this recharge kit(pic) for my other car and it wouldn't probably fit to R-12 right?And it fit to thicker hose(blue cap) the thiner one got a little bit bigger valve with black cap.
Air condition
1.clutch is engaging when the A/C switch is pressed 2.System is R12 3.Evaporator fan is running 4.Pressure on the thinner hose is little bit under "FILLED" mark.I got only Gauge A/C filling set and it shows only LOW-FILLED-OVER FILLED Thanks for your help -
Axle stub play?
Hi, some free play is ok .Depends if its in/out or side to side.Take a look at http://www.ultimatesubaru.org/forum/showthread.php?t=33362
