turbodog
    6
Everything posted by turbodog
  1. i just installed a standalone ecu, so thats why i was saying ecu wouldnt be a problem, i literally would just have to plug the ea81 in and it would work
  2. less power but more reliable right? should i do this? we doin this?!!? hahhaha. ive got an ea81 turbo collecting corrosion, and if I dont try to save it now it might be lost to time... so, ECU isnt a problem. this is tempting.
  3. lol, well, ive got a nice tig, so i may weld up that crack they love to get, but everything else is new... so hopefully hg's keep it goin for a while. i may be in the market for an adapter plate *sigh* ive got an ej25 with a set of ej20 turbo heads... but that's another recipe for head gaskets.... hmmm Honda J series lol
  4. i need a new headgasket, is fel-pro the go 2? has anyone had good luck with others?
  5. yay bad headgasket! woo i love ea82's
  6. got a new coil, and was able to set the trigger offset!
  7. aww man, my coil died! and so did my distributor rotor, the metal fell off! :O also, danget! i wish i could be driving it in this right now
  8. yeah, but its just inexperience that's causing me some issues here.. i may have figured it out last night. im gonna see what results i come up with.. its somewhat reading, but i found out that i wasn't gettting 12v to the dizzy's power so the voltages in the sensors aren't quite right (supposed to be 5V)
  9. So far ive gotten the fuel pump to turn on in test mode, same goes for the coil, boost solenoid, all 4 injectors and anything else i can test... i've got what looks to be the right signals now... but i cant find out how to make the whole thing " do the thing" lol.
  10. oh its getting so close i can feel it... lol
  11. cleaned and re wrapped the power in wires heres the new ecu wired up to the existing harness , will get buttoned up once im sure all the parameters are reading correctly and i know i dont need to add any more connections. (yeah i see the connector that's not shrank yet, lol) aaand thats about it for now..
  12. allrighty, sorry for the long wait, I've been hard at the wiring! and i think im done! woo this next post is gonna be a long one, ill try to explain whats i did so, the injectors are paired in a way, where #1 & #2 are paired and #3 & #4 are aswell, they are located about a foot past the big grommet hole. lots of connection checking, re taping and tracing done, finally time to wrap it all up! side note: there are only 4 grounds for the ENTIRE HARNESS AND BODY all of them need to be perfect, as each has about 10-15 wires per bolted on connection point. trimmed, cleaned up and re wraped the engine harness. the most important ground is located on the end with the most wires ending up there. (about 15 splitting to another dozen) The upper most wire is using some existing wires on the harness and its nowwired into the intake air temp sensor.
  13. oh yeah your right, what about somthing that replace the top part of the center glove box
  14. yes! i would love the print file! maybe design one that uses the ash tray too?
  15. so installing a new ECU, and one of the tasks at hand was to find the 4 injector wires that go from 4 wires, to 2 , and back to 4 (so dumb, lol) had to take the fender off and take the loom apart.. yay. lucklly i found it, also found the resistors for the injectors
  16. what i did with my old webber setup was cut a peice of sheet metal into the oval shape the factory air cleaner has and welded on a couple bolts where the top screws on, gave it a nice stock ish look and i kept the oem filter
  17. I agree with the Weber, you will get better millage and more power, on a lifted wagon I managed to get 42mpg following a trailer with a bunch of fence... I miss that one
  18. i 3d printed center caps for my 8spokes,
  19. also, ive undid all the "mods" you said were dumb, if you didnt notice, its reverted to 100% stock as im diagnosing it
  20. so, my dislexia strikes again, and i got the fire order wrong, though it didnt solve the whole issue, it ran great for a minute with the mass air plugged in... then it died again, and wont run with it plugged in. CEL says code 22 and that says knock control circuit?
  21. yep, i know this engine is trash. the ecu is trash. but the money i spent was just in hoses, so... show me a standalone thats under $140
  22. thanks, ill look into it some more, this is frustrating, ive never came across this kinda problem before
  23. rumaging threw the forum i seen that someone said ea81T injectors are identical, so i grabbed a pair off of my turbo coupe, im going to clean them up and install them tomorrow
  24. compression isnt the best, but ironicly the ones with the best are not poping, 150 psi in #2 and 130psi in #4 yeah i did the cam timing, at least i remembered how to do that, lol
