20
Everything posted by TomRhere
Well,, Durnit. Sorry R.W., I tried to help.
Squeaky Pass Wheel - New Axle
TomRhere replied to Tony Cortado's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Check the parking brake adjustment also. -
Do all EA81 bodied vehicles take the same seal?
Noise in left rear hub - brakes?
TomRhere replied to KiwiBrumby's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Adjust the rear brakes. -
Bringing the 82 BRAT Back To Life!
TomRhere replied to Sonicfrog's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Got a couple pics. PM me your email and I'll send them. -
Pretty sure I can match the PS one. Been a few since I've layed eyes on them, but the ones I have look familiar from memory. Do my best to remember to get them out of their hiding spot tomorrow (after work) and snap a pic or two for you. -
You need just the lens, or whole tail-light assembly? Have both. Should have ignition key lock assembly and door locks to keep it all one key. I'll check on that and post back. -
How Do I Adjust the Clutch Pedal
TomRhere replied to Enchurito's topic in Old Gen.: 80's GL/DL/XT/Loyales...
5 pedal boxes from EA82's, '86 thru '92, all have those pieces. Didn't look at the one on the BRAT. -
Still have the '82 BRAT. But when I'll ever have time to work on it is the question.
Sold it today.
EA82 HVAC Blower Works Only on Speed 3?
TomRhere replied to carfreak85's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The speed selector switch has failed. You are correct on the "High Only" if it was the resistor pack. -
If it's the front left one hanging up, it could be due to the Hill-Holder. Proper adjustment of it's cable would help there.
Thinking I could lend a hand or two myself. Would need a few days notice to make sure nothing else would be scheduled then, but could do a couple days at your place getting things done, or ready to be finished up aleast.
- 22 replies
- lifter tick
- 88 GL
(and 1 more)
Tagged with:
Agreed. Also may want to replace the water pump if money allows and you don't know it's age. Going to be right there next to it anyways. Seeing as yours doesn't have A/C, pulling the radiator AND the center of the grille, gives all kinds of; "I can see what I'm doing" room. I have used ATF/kerosene/fuel-oil/diesel along with the engine oil in the oil pan to try to clean the innards of an engine in the past. All will work, but I seem to like Seafoam more as of late.. ATF is high detergent, it do clean stuff well. Risleone (sp?) Engine Flush was another one I used in the past, but don't find it locally anymore. That stuff worked in my opinion, but it smelled just like kerosene to me. So why not use use kerosene instead was my thought, as I could buy a gallon of kerosene for the cost of the quart can of Risleone.
- 22 replies
- lifter tick
- 88 GL
(and 1 more)
Tagged with:
Yep. Just what you thought it to be. Noisy lifter. Referred on here as, "The Tic-of-Death" (TOD). But it's really not fatal to the engine. Annoying as all get out, definitely. Some Seafoam in the oil for a bit to maybe clean things, and a fresh oil change may help. But a reseal of the oil pump would really be best. edit; Didn't hear that when you were down here last Sunday.
- 22 replies
- 1
- lifter tick
- 88 GL
(and 1 more)
Tagged with:
Respect for the EA81 and performance mods!
TomRhere replied to RAD's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Some 8-10 years ago, there was a person on here that did the rant/rave about the EA series of engines. Refused to listen to what anyone else had to say about "What HE knew" of the greatness of them. He got banned finally. -
84 brat wiper motor park location
TomRhere replied to turfman454's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just looked at the wiper system of the '82 BRAT. In Parked position, the arm from motor to DS wiper is at the bottom of the motor pivot. -
Ea82 engine crossmember in ea81
TomRhere replied to kirzick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks skylar! Was thinking it was him, but wasn't sure. -
I've soaked them for a couple days in a bowl of Seafoam to clean them, then soaked them in a bowl of oil. Seemed to work good.
- 23 replies
- EA82 engine
- HLA
(and 1 more)
Tagged with:
Canopy Gasket Repair or Replacement?
TomRhere replied to dbenzmaine's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Try a place that sells truck caps, they may be able to find a match. Or, jcwhitney.com sells various shapes of weather stripping. Worth a look. -
Parts I can't find ANYWHERE
TomRhere replied to 83subaruGLchick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://car-part.com/ Another place to look. -
VERY short RAM on my 88 GL (with pictures)
TomRhere replied to YnotDIY's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yeah, those storms were intense to say the least. They sounded the warning sirens around 10 PM here. Not sure if was due to the storms, or if there actually was a tornado in the area.- 25 replies
