Everything posted by TomRhere
Abandoned Subaru in need of my help!...call 911
Not sure if it would work in this instance or not. But contact the Police Department that put the sticker on it. If it truly is an "Abandoned Vehicle" you just may be able to get it as a "parts vehicle". You may have to contact whatever entity it is that does the Registration/Plating of vehicles, also. Reason for saying that is, most PD's would have to have it towed to an impound lot, then hold onto it until their next auction, hoping to get enough money out of it to cover the cost of tow/storage. Doesn't always work, but I have picked up afew cars this way, and even managed to re-title a couple of them. Takes time, and there's a big paper chase involved, but it can be done, atleast here in Michigan.
Aftermarket Cat & Muffler EA81
discountconverter.com has lots of cats listed. If you look in the universal cat listing and scroll down to the 8XXX section, you'll find some with dual 2" in and out, also has one with O2 sensor fitting. Think it's 8012 and 8015 respectivly.
Strut spacer
Does one need this angle one both top and bottom of the part?
swap EA82 rear crossmember into brat?
I've repositioned the spring perches on solid axles so they'd fit under a different model vehicle than what the axle came out of. Fairly simple to do, just have to get the pinion angle right. So, I wonder if one could carefully cut the mount points off from the EA-82 suspension, then center the unit under the car, and re-weld the mout points where they need to be. This would give you a slightly wider track on the rear which would be a good thing on a lifted vehicle. Am I way out in left field on this????
vibrating/grinding...??? under acceleration in a left had turn
My '82 BRAT made a wierd noise when accelerating hard, or taking off from a stop while turning left. Seemed to come from the right hand side of the vehicle. It had new axles on both sides, along with new bearings and seals. I spent quite a bit of time trying to find where it was coming from, with not much luck. It still did it after I pulled the axles, and just had the outer stubs in the hubs, (needed axles for the Wife's '84). Upon pulling the engine and tranny out, I found the mounts to be bad for both the engine and the tranny. One engine mount actually feel apart while the engine was hanging on the hoist, definetly a bad mount there. So I would look at your mounts for signs of deterioration. I had atributed the noise to the fact that the EA-82 engine only cleared the framerails by about a 1/4", and it was just the engine rubbing the framerail during acceleration. I haven't found any sign of contact between the engine and framerail as of yet. Just thought of this, maybe it's the pitch stopper assembly making the noise???????? Could be worth a look.
Intermediate Windsreen Wippers
If I didn't have to do these 70+ hour work weeks, I'd have more time to look at things. This is what I have sofar after pulling a 12 hour shift Friday. Would have posted it sooner, but did a 18 hour shift Saturday. I'm a whooped puppy....... '82 BRAT GL with intermitant wipers..... Switch side - Vehicle harness side Blue/white - Blue/white Green - Green Yellow - Yellow Blue/red - Blue/red Red - Green/white (fuse box feed) Blue - Red As I was chasing the wires down thru the harness, my multimeter died on me, so I have to get my other one from work to go futher. Did find a squarish relay next to the fuse box that's tied into the wiper circuit. Could be the delay relay. Here's it's connector; Green/white Black White Blue If I can manage to sneek in/out of the shop to get my meter without being seen today, I'll do somemore tracing of the circuit. Don't want to be seen in the building, they'll want me to work. Then again, they could calll me in today also.....
Haven't forgot about you, just haven't had time to look yet. Sounds lame, I know, but it's just way hecktic at this end lately. Will try to do it after work tomorrow, and post back. Tom
I have the dash out of my '82 at the moment. I'll try to remember to take a look at things and post back a bit later with what I find.
my RWD test
You are turning more gears and such being in 4WD, so abit more drag is feasible. Drove my '82 around like that for a couple months, kinda liked it 'cept when trying to do a fast get out ahead of everyone pulling out of a gas station or simular place. Just a tad bit light on the rear for to much go pedal:burnout:
stupid question time
My '82 BRAT has those same conectors and solenoids, no clue as to what they are for though. The vacuum line to them was plugged by the person that put the EA-82 engine in, engine ran fine without them. Just for the record, it was originally a California BRAT, and had factory AC, even had an ECU under the dash.
is there anyone in maryland that could help me?
One wonders if this could be a FPCU related problem. It's a little box about the size of a deck of cards, locaed on the DS kick panel above and forward of the hood release handle. You may of caused the plug to loose contact while messing with the hood release. Just a thought is all, and I'm going from what I know on my BRATs. You should hear the pump run for a second or two when you turn the key to the "on" position, if not, that's the 1st thing I'd check.
Help!
http://www.nationalcarburetor.com/cat-subaru.html Sounds like a good price to me for a stock replacement. http://catalog.eautopartscatalog.com/tayco/wizard.jsp?partner=tayco&clientid=alloem&baseurl=http://www.alloemautoparts.com/&cookieid=1B813E7PQ&year=1984&make=SU&model=BRT-4WD-002&category=E&part=Fuel+Filter http://catalog.eautopartscatalog.com/tayco/wizard.jsp?partner=tayco&clientid=alloem&baseurl=http://www.alloemautoparts.com/&cookieid=1B813E7PQ&year=1984&make=SU&model=BRT-4WD-002&category=E&part=Fuel+Separator http://catalog.eautopartscatalog.com/tayco/wizard.jsp?partner=tayco&clientid=alloem&baseurl=http://www.alloemautoparts.com/&cookieid=1B813P05O&year=1984&make=SU&model=BRT-4WD-002&category=G&part=Radiator If those 3 links don't work for you, just go to here, www.alloemautoparts.com and put in the info on your vehicle.
Remove crankshaft sprocket???
Same problem here when I did the re-seal on my EA-82. Those things were staying put...... But I put up a good fight, and finally managed to get them off by using a flat prybar in behind them. A little carefull persuasion, while properly talking to them, and they finally came off. I did have to coax them all of the way though. A bit of Anti-Sieze on the crank before re-assembly is advised.
New CV still a problem
1st thing to try is to re-tighten the axle nut. Can't explain why, but I've had them "loosen up" after a few miles of driving, after an axle swap. Maybe it's just everything settling in, don't know. Ifin that don't get rid of the noise and vibration, then it's the wheel bearings.
EA81 Cruise Control problem
In my experience of working on "other makes" of vehicles, a vacuum leak would be the 1st thing to rule out. Any leak would basically keep it from working, and for sure wouldn't cause it to be so erratic. Best guess would be something amiss in the control switch and/or it's wiring, as in a shorting of juice across the circuits there in. Would look there first, then start checking the rest of the system out. The speed sensor could be culprit, but they usually just plain die. No clue as to locale of control unit really, but thinking it's under the dash to the right of the steering column, above where the ECU is/would be. Think I read that somewhere.
Simple project what could go wrong?
You may want to pull the fuseable link box loose from the inner-fender and actually check the connections underneath it. I had one break off on my '86. To look at it, looked ok, but it had serious corrosion problems there, and one feed had broke.
Control arm elimination!-progress update!!
Okay, I got you BB. I hear you on the headache part............... Think I need another beer now. Ifin my set-up works out, I sure will post on it so others can atleast look it over.
Suspension set up basics...
NASCAR is doing Watkins Glen this weekend, Road course action. I loves it, wish they did more. So now they do have to do the right turn stuff. And still, it's loose here, tight there, pushing here. On another note.... I used to do some road coursing myself many moons ago when I was a much younger puppy. Always the family ride that Dad had at the time, but I could drive it, good. Never gave any thought to different tire pressures or spring rates, front-end geometry, what not. Just a stock car, doing the Esses.............. Have I kinda Jacked this post? Ifso, I appologize......................................
Okay, just so we're talking the same terminology here. You're talking about the rod that goes from the lower arm, back towards the tranny mount right? Ifso, thats more commonly known as a reaction rod, but has many names too. The arm from the engine c'member out to the ball-joint is the control arm. It would be an "A"-arm, or wishbone if it had 2 inner mount points instead of one. We on the same plane of thought here now??? I'm deep into thoughts and design of eliminating the strut itself, and going with an "A"-arm on the top, with a coil-over shock setup. Just don't like the idea of fabbing a bracket for the strut to keep proper camber angles while going with a 10" or more lift. But that's just me..., and I'm doing the same thing you are, or simular to it. Nissan T-case, 10"-12" lift, Yota 6-lug rims, ER-27 W/DR-5spd, 4.11 Diffs at both ends. The Mods list keeps growing as things become, "available", to me. Think I'm calling it quits at a 31" tall tire though..................
This is where I get all cornfuzed. Just never got a "grip" on set-up of a vehicle. Really get confused watching the NASCAR races. "I'm tight in, and loose off". But the anouncer says just the opposite of what I'm thinking the driver is saying. Always think of being tight is; the car wants to turn to quickly, and loose as the back end wants to lead the car around the corner. Then they throw in the pushing bit, ??!?. Is that the understeer part? And tight being the oversteer part? Then they throw in the 1/2 pound of air in this tire, and raise/lower the track bar, do something with the "wedge"??!?, what ever that is, ... I'm lost.....
custom Y pipe layout pics.
Looking good! I here you on the, "harder to do than one thinks" part. Took me most of a day to lay-out and fit my duals under the '82, and they are straight pipes for the most part. Of course, it would of been easier, ifin I had a chop-saw and welder here, instead of trips to work to cut/tack weld. On the O2 fitting, try a muffler shop, they have them, but not sure if they'd have any SS ones.
Idea for the T-Case lifted folks....
Wouldn't you need to "lock" one of the stubs motionless in order for power to be transmitted to the other one? Seems like you would have to, as the front diff is an open unit. But it is a good idea, using the front stub as a power take-off drive. Only other thing to consider is, when in 4WD mode, you're still driving the front stub axle. So it would have to be a unit that would handle sustained power applied to it. Just tought on that for a second. An air-operated clutch pack would work. Used them at the last job I had to bring in secondary functions on some of the machines we built. Air pressure applied, clutch engaged; air off, clutch free-wheels. Hmmmm, more ideas floating thru the brain now.
Just curious is all. Why the "V" bend? Wouldn't it be better to have it straighter behind the "Y", than that bend?
Oil Cooler adapters,permanent avalibility!
COOL! Oil that is. Black Gold, Texas Tea.
Just sent you money via pay-pal.
