20
Everything posted by TomRhere
Bubbles/Foam in Power steering????why!?
TomRhere replied to Ratty2Austin's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yep, what he said. May take a bit for all of the air to be purged out of the system. Keep an eye on the level for a few days after you do the bleed. -
Miles: Was just going to email Jim about that myself. But seeing as your there, tell him. Dadeeo: I've seen this XT-4. It is a sweet looking car. Real shame Jim can't get a title for it. They're in the process of parting it out, but the shell will still be there, as they're not doing any sheetmetal removal that I know of. Jim's handle here on the board is 86subaru, send him an email, or a Private Message. Click on the members button at the top of the main page, this forum. You'll find him listed in there.
No hard feelings at all. Okay, maybe a little. It was mine:boohoo: :boohoo: :boohoo: :boohoo:
Had an AMC Eagle 4WD. Outer boot was gone on the DS front. Was driving home from work, turned a corner, and the wheels wouldn't straighten back up. WTF?!?!?!? Luckly, I wasn't going to fast, and was able to not go to far into the woods. Got to looking around as to the cause of the problem. Found a nice sized stone had wedged itself in the outer-joint. Real fun digging that out of there with no tools handy. New axle went in the next day.
PM box is still full up. Won't let me send you any more. Hit the delete buttom a couple of times.
Do believe that .050 over is as big as you can go on pistons. Someone stated that here on the board. Would tend to believe that if the sleeve spun in the bore during a re-bore, the machine shop operator was trying to make to much of a cut at one time. I've had sleeved engines re-bored before, with no problems. As to your tranny problem. One wonders if maybe your shifter would be more at fault than the tranny. These things tend to get sloppy shifters with higher mileage.
Gotta empty the mail box, it be full up
http://catalog.thepartsbin.com/?year=1988&make=SU&imageField.x=26&imageField.y=16
strange thing happened pullin my ea81
TomRhere replied to Meeky Moose's topic in Old Gen.: 80's GL/DL/XT/Loyales...
You going to share any of those drugs you're on? JK -
This is important, please give input!
TomRhere replied to WJM's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Oneway to check the tranny/front diff/rear diff: Pull your spark plugs, raise all the wheels of the ground, mark tires and body with chalk, tape, whatever, place tranny in gear lock the center diff, turn engine over by hand and check your alignment marks. All should lign back up, or atleast I'm thinking so. -
I know the EA-81's are gear drive on the cam, but makes me wonder if it somehow hasn't jumped timing a tooth or two. Would account for the lack of power, and burning all of that oil. IE: intake valve not opening at right time, causing oil to be pulled past the rings. Or the cam lobes have rounded off, giving you the same results. But to have two lobes go at the same time would be way far fetched, as far as the odds go. If HG's are good, and valve seals are good, Turbo isn't leaking oil, PCV system isn't at fault, and the Modulator valve on the trans isn't at fault, the piston rings aren't at fault. Doesn't leave to much more to be at fault. Just some thoughts on it.
Yep. 2 bearings, 2 seals, each side of the vehicle. Same same, inner outer.
Im new and wanted to say HI!
TomRhere replied to $J-MoNeY-$'s topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welcome to the board. You are in the right place to find solutions to your problem(s). Many knowledgable people here. The more details you can give them, the easier it is for them to give good advice. Sorry I can't help you, I'm totally lost on Turboed engine systems. Never owned or worked on one. But I'm a looking. -
When I did the ones in the '86, I used a press at work. 1st time doing that on a Subaru. When I did the ones in the '82, the first time, I used a press at work. When one of the seals went bad and ruined a bearing on the '82. I did it in the garage with a 10" long drift punch and whammer. Biggest problem using punch and hammer method, is keeping the dadburned knuckle from moving across the floor when you whack the punch. Although, using a press to do it isn't much easier, do to having to find the right pieces of metal spacers to hold the knuckle level. It be a pain. Personnal preferance now is to use the punch and hammer method. I got a chunk of aluminum round stock, slightly smaller than the OD of the bearing to tap it in with. Above all.... Don't be a dummy like me, and forget to put the spacer in between the bearings. Called myself all kinds of names over that one. Doesn't pay to get in a hurry!!!!
I'd be interestd in atleast two.
Just checked out the pics. Awesome!! Any idea if the Gen 1 master cylinder would fit a Gen 2? Disty is really tight to the MC in my '82. Guess I really should ask if the Gen 1's are a dual system or not. So are they?
Vicky; the rims were painted by the youngin I bought the BRAT from. He had the idea of painting it with a Black and Yellow theme. The rims were all he got done, took him over a year to do those. That's when his Step-Dad decided that the kid just wasn't that interested in it, and told him to sell it. Was bought by the S-D as a project vehicle for them. And yes, the rims will be re-painted. The Wife has decreed so. Miles; I was wanting another hood to do the hood scoop on. That way, ifin I mess it up, I ain't ruining my good hood on the '82. Yeah, ain't a bad pic of the '86, you can't see all of the rust in that shot. Kinda blends into the paint color and the shadows.
Sounds like a mean one. Guess I'll have to throw a turbo on mine, now. Definetly want to see pictures of it.
tried the atf flush on my hatch
Use the Dextron II, it's better for the engine or trans, or diffs for that matter. DO NOT, use the Type F stuff. It can, and more than likely will, hurt whatever you put it in. It has a grittier type of blend to it, or so I've been told. And yes, ATF is an excelant hand cleaner. Does wonders for oxidized paint on a car too. -
Dooo-kay. 'Parently i done did something wrong in there, but now they're there. I even edited in the link to them in the opening post
Finally, (after many headaches, and quite a few tries to get them up-loaded), I now have pics of my BRATs in the photo section. http://usmb.net/gallery/albuo81
Could be a bad wheel bearing also. My '86 had thumping type noise on PS front, new it needed new axle, and hoped that was it. After axle change it was okay for a few miles, then started up again. At a slow crawl, it would actually move the steering wheel. Replaced front bearings, all better now. Found a bad spot in the inner bearing when I cleaned the old grease out of it, just to see what was what.
front end problems, need some help/ideas...
TomRhere replied to theDirtyRue's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Possible things that were bent; Lower control arm, Strut tube, Front uni-body area. I know that last one doesn't sound to good. But seeing as you say the hood won't close right, that is a possibility. If you decide to repair this car, I strongly urge you to replace the lower ball-joint also, as it could have stress fractures in it.
