20
Everything posted by TomRhere
And yeah, I'm of the same mind-set. Don't tell me "I can't" cause "I will". One way or the other, just to prove "someone" wrong.............. (being nice guy with that, "someone" part).
Breather top looks good. I may have some better looking wingnuts for you. Have to dig around out in the garage some. But really thinking I have some in better shape/condition. Not sure if you would find them in stainless, but it is possible....
I have 3 engines here that are dripping oil. 1-EA81, 2 ER27's,, none of which have ran in the past 5 years. And "they",,,, drip oil..... 'Tis apparent to me that since they once had oil leaks, they shall continue to leak oil...... Regardless.....
SE WI, Milwaukee Regional/Subaru Alliance
TomRhere replied to MilesFox's topic in Meet n' Greet. Your USMB Welcome Center
So Tom, you going to need that alt bracket sooner than your July trip over here? I can send it your way. -
The Crazyman is back!
TomRhere replied to crazyman03's topic in Meet n' Greet. Your USMB Welcome Center
Welcome back ! -
EA81 Rear Fuel Line Routing (Need pics)
TomRhere replied to TheLoyale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Glad to help. -
New adjusting screw and plastic nut can be found in the "Help" section of your parts store. The 3/8ths square are the ones you want, need 4 packs to do all the lights. The valve in the fuel/vent lines is the 2-way vent for the tank. It has to be installed correctly for it to work. Look in the files I sent you, you'll find it.
Oil pressure reading at or near "0", warm engine idle, is normal for the stock gauge setup. Even says that in the Owners Manual. A mechanical gauge would give you a more proper reading. Check the connectors for the sending unit on the gas tank. Corrosion has been my issue with those. All 5 of the BRATs I've had here varied where the fan would come on in relation to temp gauge reading. Again, stock gauges aren't all that acurate. The White '86 never went over the 1/2 mark, while the '85 runs at or just above the 1/2 mark. Both had all new cooling system parts installed.
Ok. Scrapping a '92 Loyale Wagon. Would like to keep the back windows, both the rear side ones and the rear hatch/door/tailgate one. How/where do I start to work the seals out? Seals are still plyable, and I have worked my fingers all around them, both pulling them loose from the glass and from the body. Just not real sure where to start to work the seal out of the body opening. I have installed windows before, just never had to actually remove a "good pane". Pointers are really needed here.
Finally! Back in a Subaru.
TomRhere replied to Mechanical_misfit's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Haven't really figured mileage in a bit, but I'm around the 26-27 range. 5 gallons of gas will get me 2-1/2 round trips to work/home, a tick over 64 miles per round trip. My tank has decided to leak if I do more than 1/2 tank, so I just do 5 gallons at a time, waiting for the "low fuel" light to come on before I stop for more. I did, (but not by choice), do 157 miles on something between 5-6 gallons. Can't say for sure what was in the tank, but I put 5.2 gallons in, reset tripmeter. Low fuel light came on with some 28 miles to go to get home. Only station between there and the house was closed. Was already showing some 130 miles driven since last gas. -
Wiring changes, '88 GL to '92 Loyale
TomRhere replied to TomRhere's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Thanks to both of you for the info. Was really hoping I didn't have to swap dash wiring over. Only noticable difference between the two so-far.... Is steeringwheel slipring. The '88 has provision for in-wheel CC controls,(not equipped though), the '92 doesn't. No biggie there, I can swap that stuff easily... I will be swapping the '88s cluster over though, just to keep mileage correct. -
Curious as to how much changed (if any) between them. Have the '88 GL slated as my next DD. The '92 Loyale is parts donor, engine/trans, interior, power locks/windows type stuff. Body is toast. Will I be able to just do a Plug-N-Play with things like the engine, dash as a whole assembly, heater and A/C parts? Or,,, am I going to need to swap my dash wiring/cluster over to the '92 dash? engine wiring different enough to warrant swapping harness and ECU? Interior of the '92 is in way better shape than the '88 is. Wanting to swap most of it over. Not going to use the auto seatbelts though.
Spent the weekend stripping the '92 Loyale down. Engine out, front is tore down to unibody, doors off, 45% of interior is out. Basically anything that could be removed without it being off the tires yet. Need to get someone over here to evacuate the R-12 in the A/C system, and that will be coming out next. Was real surprized with a lot of the bolts actually breaking loose/turning out instead of just breaking off. But I ain't complaining any....
Many eons have passed since I've been there... Spark knock is most likely the vac advance isn't working. -
anti freeze leak from a bolt on the head
TomRhere replied to old sub freak's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Try the "Help" displays at a few of your local parts stores. You may find one there. If the counterperson is any good, they could find one for you. Most have a "small parts" area with drawers full of different items. Atleast a few of the "been here forever" stores that are around me do. Hardware store is another place to check. Can't recall having any issue with that drain plug leaking on any of mine. And I have pulled/installed them many times. -
Grottos 1st Subaru: 92 Loyale 4WD Wagon
TomRhere replied to grotto's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Nice Wagon... There's a wiring connector under the driver seat. You could try un-plugging/re-connecting it to clear the seatbelt light. Could be just a dirty/corroded connection. Other causes are possible, but that's an easy "try". Issue with powerwindows could be lack of lubricant in the tracts. Diligent applicantion of some White Lithium spray may help there. -
First time for everything.... rockauto
TomRhere replied to Idasho's topic in Old Gen.: 80's GL/DL/XT/Loyales...
To solve the cross-over issue, go with the '84 Model for parts ordering. A lot of Supplier's have inaccurate info for the years that the EA81 and EA82 ran together. No major changes were done to the EA81 engine/body during that time frame, so all gaskets, and what have you, fit properlly -
Is this the END for my 86 Subaru XT????
TomRhere replied to zooeyhall's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The FSM calls it out as "The rear crossmember". Atleast the FSM for '88 XT6 does. -
She do look good.......... Have to give the rear doors of the '92 a good look over. They may be salvageable, but I really haven't paid attention to them.
I would go with different hood. Not easy to get the framework out of one with all of the bonding goo that's used. I have attempted that, once... Nice work done to it sofar though....
Mag lugs require a rim depth of atleast 1/2" as they have a shank area to center the rim to the lug, VS the chamfer of a standard lug. Clamp force is from the shoulder below the nut-hex
Strong, the Force is in this one. Yes!!! -
Iff your rear tire looks like this, on either side. It be the crosstube failed. Link didn't work, so we do the direct approach..... http://www.ultimatesubaru.org/forum/album.php?albumid=324&pictureid=3608 -
Some pics of the parts wagon, http://s29.beta.photobucket.com/user/TomRhere/library/88%20GL%20Wagon#/user/TomRhere/library/92%20Loyale%20Wagon?&_suid=1361172922590027077789581999484
Atlast,,, we have pics. http://s29.beta.photobucket.com/user/TomRhere/library/88%20GL%20Wagon#/user/TomRhere/library/88%20GL%20Wagon?&_suid=1361172922590027077789581999484
