Everything posted by TomRhere
Club Torn-Boot, '84 GL now a member
I've fashioned a few heatshields out of aluminum roof flashing. Small roll of it is fairly cheap, and it's easy to work with. Comes in assorted widths. Gloves are sorta needed, but some tinsnips and a couple wormscrew type hose clamps and you're in business. Cut it longer than you think you need, then cut some slits in it, bend those to make your stand-offs, attach to pipe(s) with the clamps.
Hill Holder into Gen1 Brat??
It can be mounted anywhere the cable will reach to. That is the only limiting factor. New brake lines can be ran to it's location, and you'll have to re-do the lines anyways to install it on your 1st Gen. Stock plumbed to the LF-RR brakes, but you can re-route as you wish. It's basically a check-valve, works off of the angle of the vehicle and is adjustable as to what angle it functions at. Just add shim under front or rear mounting point to change angle. Can't say off the top of my head what the "stock" angle is but in stock form it's mounted directly to the frame rail. It is a nice feature, but can be a pain if you need to roll backwards a bit on a hill. With you doing the D/R-5speed swap, the cable for it will fit right where it should on the clutchfork of the trans. May have to custom mount the bracket that holds it at the clutch end doing the EJ swap, can't say one way or the other on that myself.
quick engine pulling question
Yeah, on the wrecked one. Pull the headlight assemblies from the radiator support, then cut down thru those over to the radiator area. Should give you plenty of room to pull everything on a basically flat pull to the front. You'll be able to see what needs to be removed just looking at it from the front. 2WD drive definetly makes it easier.
No free-play allowed, period.
Just changed disty in the '85 BRAT. Been acting up last few days, at idle speeds, tach will read upto 4G's. Can feel roughness of the engine thru the shifter. It's only -10 to -15 outside right now, depending on wind speed. Hands are way cold.... Can't wrench on things with gloves on, just can't. Wife won't let me warm them up either.
Yes it is. Drain the tranny 1st or you'll dump the fluid from it all over the ground. If you're talking of the engine/trans from your wrecked one, just cut the radiator support out of the way and you won't have to tip the assembly backwards as far.
the possible death of the sedan
Definetly was a hard hit. But I think it's fixable. Granted, I'm not there to see it in person, but it does look fixable to me. And I don't think you'd need to put it on a frame machine either. You'd be surprized at what one can do with some chain, come-along, block & tackle, and a porta-power.
Brat wrecked....totaled?
PM sent.
81 passing lamp...
Had same issue with the '82. Pulled the unit and looked at the solder joints. Quite obvious that those were the problem on mine. Quick re-solder of joints and she works like a charm.
Weird Heating Issue
I was thinking wrong rotation on either the blower motor or the squirrel cage, but didn't think it was possible on Subarus so I didn't say it. Do know it's possible on "other" makes/models. Learned something....
32/36 Adapter Gaskets for EA81?
^^ I've done that countless times. The gasket set they sent you is for the EA-82 2-piece adapter.
It finally goes
Nice work. Great looking Brumby!!!!
jumping into 4wd
It's just left of center where the engine/trans bolts together and runs back under the spare tire mount.
jumping into 4wd
My guess would be bad motor and tranny mounts. Those would let things flop around enough to pop it into to 4WD. Just my .02
Untrustworthy spark = untrustworthy car :(
I would suspect a bad connection for the pickup module in the disty, or a bad module itself. Also, I had an issue of "no spark" in my '85 BRAT awhile back. After a bit of checking things out. I found that the magnet under the "C" shaped piece in the disty had broken into quite a few pieces. Swapped in another magnet from a junk disty and she's been running fine ever since. Had simular issue then. It started, ran for a few minutes, then died and wouldn't re-start. After a few minutes, it did start back up. But I wasn't willing to attempt the 32 mile drive home with it. Left it at the shop and caught a ride with my Son. Made repairs the next day during lunch.
fuel smell
The top half of your tank has probally developed a few pinholes. I've replaced the tanks under 2 BRATs because of the same thing you're going thru. A temporary fix, until you can source a replacement tank, is to use some Seals All. Drop your tank, (fun job), clean the area of leakage, coat it with the Seals All, re-install tank. Seals All will stop a flowing leak in a gas tank up to an 1/8" diameter hole. One can use something for a plug for larger holes. Good stuff to have on hand when you're off-roading. I have had the need of using it, many times. Should be able to find it anywhere they sell stuff like RTV, and simular products. My local parts store has it, WalMart carries it in the automotive department.
Blizzard of the Century
Heard tell that we had about 3" of snow before it switched over to rain early yesterday morning, turning it all into so much slush.. Do know the '85 BRAT did not like that slushy crap one bit!!!! Even in 4WD, it was all over the place. If I got out of the tire tracks of other vehicles, she would dance all over the place. Those tire tracks were down the center of the road, so I had to get into the actual lane when there was on-coming traffic. Made it out of the driveway with no problem in 2WD, but when I got onto the pavement with the slush, she didn't want to move very good. OK... 4WD it is... Felt like shifting it into 4WD dropped out the front and just drove the rears she was so squirrly. Reminded me of the '68 Chevy 1/2T 2WD I had many years ago. Got good tires, but I guess they are not for slushy conditions. Had them on the '86 BRAT last winter, and they did good in the snows we got then. So I don't know.... Maybe a frontend issue I haven't found yet. Didn't drive it in any snowy conditions last year. Really not wanting to do it this year either, but I have no choice right now. Took an hour and 10 minutes to make the drive into work. Usually about a 40 - 45 minute drive. 8 miles of that slush crap before I got to a plowed road, and couldn't go faster than 25 MPH. Trip to work is a little over 32 miles oneway. Really wasn't wanting to have to drive the whole way in that...
Drizzle rain this morning has turned what snow we did get into slush. Hard to tell what we did get amount wise. I know the wind was kicking pretty good lastnight when I was climbing into bed. Nieghbor's pine trees were singing pretty good. Sortta calm out right now. So much for the "Major Winter Storm" they we ranting about yesterday....
Light dusting of snow, just starting to cover things. Rain is on it's way though. Really not wanting bad road conditions just yet. Need some new tires for the Wife's HHR. Pricey buggers.....
Weird Heating Issue
The resistor block gives the blower speeds, depending on switch settings. You can loose one or two speeds due to bad resistor block, but still should have airflow. Really sounds like you have something in the system blocking the airflow. Maybe from a PO's forray into the system to repair some other problem. Only items in there that could block flow are the AC coil and heater core themselves., and or debris getting trapped against them.
Weird Heating Issue
Remembered this thread while I was out in the garage today, so I looked over the units I have here out of an '86 Sedan and an '88 XT6. They were identical except for the Xt6 has electric servos, vs vacuum on the '86. Only doors found are cabin/outside air, defrost/vents/floor. Nothing found that would restrict airflow thru the system. Outside air intake for the blower motor is under the wiper cowl on the passenger side, just off to the side of the area that the removable cowl grille meets the stationary part. Basically directly above the blower motor itself.
Sticky Throttle
Going thru the same thing with my '85 BRAT. Swapped in a new cable a couple months ago as the old one broke. Worked fine for a couple months, now it's wanting to hang up. Thought it might have been due to the new shoes I recently bought. Slight heel on them, and thought maybe heel was getting caught under the pedal and basically jamming it when I lifted my foot. I tested that theory by placing the shoe on the pedal, and it is possible. I made consious effort to re-position my foot while driving after that. But,, I have had it hang a few more times, and totally moved my foot away from the pedal, and it still did the "high rev" thing. ???? I have removed the cable from the carb, and it moves freely in the housing with no resistance felt at all. With the cable attached to the carb, it runs straight from the mount bracket to the carb. No strange angles or anything like that. So now, I'm thinking either weak return spring, or the throttleshaft is hanging up in the carb base. I need to look into that later today. Just may swap the intake and Weber over to it from the '86...
Can I buy new DOJ cups by themselves?
http://www.rockforddriveline.com
What kind of gas milage do you get?
'86 BRAT, EA-82 intake W/Weber, solid lifter EA-81 engine got high 28's low 29's consistantly. Could get as low as 24 if I beat on it alot. Haven't really checked the '85 BRAT yet. It's bone stock basically. Seems to do fairly good on gas. Thinking about 26 mpg.
Did some work, same problems.
quote; all these problems remained the same before and after i replaced the cap and rotor. And werent a problem when i changed the plugs and wires. end quote; Check that the plug wires are correctly positioned on the cap following the firing order, and that they are one the correct plug also. Flipping 2 wires around can cause the symptoms you're having. my .02
