20
Everything posted by TomRhere
Faces out.
1990 loyale check engine light
TomRhere replied to SUBEA82's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Welcome to the Board. Here's a link for the ECU codes. http://www.ultimatesubaru.org/forum/topic/47526-subaru-ecu-codes-for-1983-1988/ Even though it doesn't list your cars year, it will work. All SPFI use same codes. -
crank pulley / harmonic balancer EA82 stuff
TomRhere replied to jono's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Would it be whether the engine has a standard intake manifold vs. a Spider intake manifold? Only ask due to only seeing one EA82T engine myself, but have seen a N/A EA82 engine with Spider intake what had the harmonic balancer crank pulley on it. Timing belt cover had the timing marks on it also. Just like the ER27 6 cylinder engines do in the XT6's. I can definitely see how the Spider intake would obscure viewing the flywheel timing marks with how the air intake snorkel is routed. Therefore, Subaru put the timing marks on the crank pulley. Now as to the why of the damper in the crank pulley between the intake types is still up for debate. -
Wont start after jacking drivers rear wheel?
TomRhere replied to Norcalbratcap's topic in Old Gen.: 80's GL/DL/XT/Loyales...
That seal is to help keep moisture out of the cap. Not a real need it item unless you're driving thru unplowed deep snow, as I attempted to do once. Kept a can of wire dry spray in the BRAT after that. The fact that it won't start unless the choke is held shut = a fuel delivery issue in the carb itself. I would suspect the float, needle valve and seat being main issue(s). -
( This vehicle equiped for optional ac)
TomRhere replied to Downwash77's topic in Old Gen.: 80's GL/DL/XT/Loyales...
All the decal means is that the main wiring harness and the heater controls are A/C ready. You need the compressor, it's mount bracket, drive belt, condenser, evaporator, drier, all of the lines, relays, another electric fan. You will need to pull the dash unit loose to install the evaporator housing. There's a flex tube between blower housing and heater core housing. That comes out and evaporator unit goes in it's place. -
If you have the cork gasket already, coat it with Permatex Ultra Black and let it cure before you install the pan and gasket. You're basically turning the cork gasket into a rubber gasket, so to speak. Also allows one to remove the pan if need be, without damaging the gasket. And it can be reinstalled with another smear of the goo.
1986 EA82 Wagon runs out of fuel at 1/4 tank!
TomRhere replied to firehawk618's topic in Old Gen.: 80's GL/DL/XT/Loyales...
A mirror small enough to fit thru the access hole may be of help. -
I'm the one what sent him the files he used to adjust the valve lash for the Hydro engine. Info is straight out of the FSM files. He disturbed the Factory settings, and now has to "play around" with the adjustments. If you replace heads, have them milled, what have you,,, you need to adjust the hydro lifters.
Really don't have much to offer as far as "do this" goes. Only had the files I sent you due to swapping heads on one of my BRATs and figured I needed to do a valve adjustment. Asked for and received the files I sent you. Thinking though, that I would let it idle for a bit, then repeat the procedure. Possibly do a "repeat as needed" thing to quite the one(s) that still want to sound off. Thinking I had to do that due to one still wanting to rattle a bit. Been a few years, so really not sure on that.
Last 3 hoses/lines and AC delete questions
TomRhere replied to andrsn's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yellow marked items can be removed, as well both items the Pink traced hose connects to. All part of AC system. Red traced hose needs to stay. It supplies vacuum to the mode selector of the heater system. Defrost/Heat/Vent settings. -
Valve stem seals can be installed on the exhaust valves with no issues. Those should have a Black spring on them vs. the Silver spring for the intake ones. I would lay money down on the oil rings being seized up, as to cause of smoke-screen. Tore down a few engines here lately, in search of some good pistons. All had seized oil rings.
What's That Noise? With Video! (83 GL Turbo Wagon)
TomRhere replied to Kristina's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would check the motor and trans mounts. -
I can so relate to that!!
I would do the dye anyways. You have it already, so it's not an extra cost.
The drip-points shown are just the lowest spot that coolant will run to before it grips off. I don't recall the name of the stuff at the moment, but there's a dye you can put in the cooling system that shows up under a Black Light.
http://www.ultimatesubaru.org/forum/topic/141568-iding-ea82-blocks/ Go to post 30 in that thread. GLoyale posted some interesting info in there.
Charcoal Canister for EJ Swap
TomRhere replied to jread's topic in Old Gen.: 80's GL/DL/XT/Loyales...
http://www.ultimatesubaru.org/forum/topic/158145-gas-tank-pressurizing-after-charcoal-cannister-removal-ea82t/ That thread has diagram of the SPFI/Turbo evap canister plumbing. Don't know EJ swap stuff, but you should be able to hook it up to the EJ's purge solenoid. -
I squished my 87 Gl-10 :(
TomRhere replied to fuentemoon's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Do you know what the system was recharged with, R12 or R184a? I haven't done a conversion on an AC system yet, so can't tell you what to look for. Do know the schrader valves for filling are different. Also, with the damage to the condenser, it may have vented itself. -
Drilled through stuck intake bolt... and head bolt.
TomRhere replied to Corvid's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Did same on my 1st ever "drill out the broken intake bolt" on a Subaru engine. I'd replace the bolt. You have removed a good portion of it's meat so to speak. -
The headlight assemblies all physically fit between body styles. But there is a difference in location of the horizontal adjustment screw. Not really a big issue though. One would have to remove the grille piece to access the adjuster is all.
