psv
Location
Norway
Vehicles
Subaru WRX STI V-Limited 555 1997
Recent Profile Visitors
psv's Achievements
Member (2/11)
3
Update: I did some tests around the coil, igniter and the wiring. And when checking continuity, I had connection from the coil to the igniter with the red wire and the yellow wire, so all checks out there. However the blue wire going from the coil to the igniter had no connection what so ever. So before I start tearing down the wiring harness, I want someone to confirm thats not how it's supposed to be, right? The test was done when the car was off, with no key in the ignition. Hope my description was understandable Picture below is the plug for the igniter, I forgot to take a picture of the plug for the coil.
Hey, i recently picked up my first Subaru, its a Subaru Impreza WRX STI V-Limited 555 1997. When I picked it up, it had been sitting for almost 2 years. When running, I hear a misfire and it smells of gas. When the engine is running, I can pull the back two coil wires from the coilpack and it has no effect on the engine. When I pull either front ones, the car eventually dies. Is this a common problem? Car has only done 50000km (Japan import). I've changed the coilpack, but the problem is still the same. I also have a code for TPS and O2 sensor if thats relevant.
