Richardb1
  • Location
    Belgrade MT
  • Referral
    web search, speedometer repair..
  • Biography
    like to update and keep my 1999 sugary running
  • Vehicles
    1999 Subaru Legacy outback
Recent Profile Visitors
Richardb1's Achievements
Newbie
Newbie (1/11)
0
  1. I checked all belts ,and grounds are good. Battery was old and had damage to the positive terminal, cold MT mornings were a challenge to crank the car. New battery definitely helped the cold cranking but the issue is still there. Now I'm getting a charging indication on the dash when I let up on the gas. Getting alternator checked and will probably replace. Thanks for the suggestions.
  2. Thank you for your thoughts. I have checked all grounds. Confusing why lights would dim when engine is at higher rpm’s.
  3. My 1999 Subaru has starting to dim the headlights at night when accelerating at higher rpm's then act normal after the gear shift. The headlights will also go back to normal if I lift off the accelerator. Automatic transmission and a new battery. Any ideas???
