bk2
Location
okanagan valley BC
bk2's Achievements
Advanced Member (3/11)
10
Thanks Torxxx, I will try to get a compression tester...and do it... so if the compression test is good.....what is the next step? thanks
Okay, so if I do a compression test.....what psi should i have in all the cylinders? and if they are all the same? also, if it is the intake manifold gaskets.....are there any pics of it....and what is the procedure for doing the operation.... thanks
What are all the problems that could gas burning of antifreeze? I would like to make sure that it is not just a simple gasket or other problem. Steps to take. thanks
1985 subaru would not turn over...clunk..
bk2 replied to bk2's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It does not seem to be blowing the coolant......which I always thought it would....it drinks it....or burns it.....comes out the join in my exhaust and tail pipe...... now would I end up in the middle of nowhere with a major tow bill???? I would imagine that could possibly happen.... -
Closing in on my first older Soob
bk2 replied to kdixey's topic in Old Gen.: 80's GL/DL/XT/Loyales...
To tell you the truth I do believe you might be starting off with a headache. Personally, 4+ years ago....(4 years ago) bought a 1985 Subaru GL wagon 5 speed for 420 bucks......120,000km on it...rusty but I drove it for 70,000 +km.....of course I put 400 bucks into it......but now it is a diminishing return... unless some of the guys on here can figure it all out... This is in Canada....British Columbia.....where everything is expensive.... Karinvail....has the right idea.....go for the dream machine...not the sweat-it machine...... Good luck.... hope you find one that rules..... -
yes, when I turn the key....you can feel a jerk....and as explained...hydrolock does fit the bill....if this makes sense -I sort of figured that was happening and lifted the hood.....then grabbed the belt....of course with everything turned off....and tugged many times on the belt until is turned a bit.....then went into the car...and it started.... yes, it did have a tendency to want to run towards the red on two hills....but did not touch.....the red. yes, there is loss of power.....the car since I bought it had no balls.....I drove it like an old lady at the 50mph....and took it easy up the hills....lots of yoil changes...etc....I babies it for 70,000 km....I gave this girl a slick 50 treatment too.....that is 70,000km ago.... what you are saying about the gaskets....could you explain more please that is interesting..... now can you explain the differents costs between a bad intake gasket leaking water from the coolant passage into the intake tract.....things are starting to be recalled -when I initially bought the vehicle the guy told me he never had the proper antifreeze in his car one winter......and when he took his cap off.....it spoooed out slush.....he said it happened going down the highway.....when it was 25 belown out......it was good for 20 below he said... I would imagine frost plugs would of worked if it did freeze.....he said other than that it worked great.....reason for selling was the rust... so as they say every vehicle has a story......if you could explain what you think would put my mind to rest.....I know you know your stuff.....as it does fit in.... thanks.. -
where do you live????? bring her over I will swap....
Thank you very much .... I do believe it is the HG and this vehicle is not worth fixing as the unibody you can push a screwdriver through it....but the good thing is I think I got my money out of her.....400 dollars for 70,000km.. I do not even know the cost up here in Canada..... I am sad these eropean 4x4 ing tires will not be turning too much more.... Now a man that knows it all told me......to loosen my rad cap....drain the antifreeze and put straight water in it....and run it..... what does everyone think of that idea.....? I have it parked in the garage where it belongs.....now is that a better idea??? I would imagine another beater is in order.... -
Happy 5th Zap....congratulations....! So with your 5 years on this board.....what am I suppose to do in my situation???? my thread is subaru that goes clunk....just recent....and also the overheating stuff....under bk2.... I have to see my kids today ..... and I am wondering if my vehicle is even safe to drive???????? I might be best just to park it????? Thanks Bryan
Yes it does run rough for a short time -then after a minute is runs great. Yes, today I had to put in 2 cups full of fluid. The smoke is rather whitish to whitish blue -many men are color blind in some sense so??? I am not certain...a person told me rings....I feel personally it is antifreeze....I am not a pro at the different smells -smelling sweet, candy floss,...or whatever it is suppose to smell like... on the first join on my exhaust....there was a little puddle of water....a couple tablespoons or so.....no antifreeze smell.....condensation??? As with my other thread subaru overheating......I had an issue with the temp guage climbing up two hills...just below the red.....I used the heater fan etc to keep it down.....so it was not cooling properly.......now there is no overheating problem....with the flushing, new thermostats, and fan on all the time...... So back to the prob....could a conditioner help for the time being....??? those that repair a small HG or cracked head...... Are there any cheap ways to check for these problems.....I just wished there was someone in the Kelowna, Vernon, Winfield area that could tell me what is up..... And lastly....the vehicle is probably worth 400 bucks -I do not want to sink anymore money into a dying old motor that has probably had irriversible probs with internal engine components.... I am really up against the wall here.... -
snowman you are great...thanks..... I have some new terms to throw at my 70+ old mechanical coffee buddy...lol.... if I get this subi....fixed up I might treat her to some mystery oil....
