3
Everything posted by jonas
Year? Have you changed the fuel filter(s)? Check all your vacuum lines and carb mounting, lack of power and erratic idle sounds like a vacuum issue. Gloyale is spot on about the gurgle. Timing for a Weber can be tricky. Keep bumping it around till you find your sweet spot. I've done the Weber swap on 2 EA81's and each was a bit different on the timing.
- 5 replies
- Carb problems
- vaccum leak
(and 3 more)
Tagged with:
Replacement Carburetor for EA81?
jonas replied to Bratmobile's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Dude, srsly, go Weber. I've done it twice. Easy to do and well worth it. Plenty of info on this site to get it done. -
No headlights or dash lights, '85 Brat
jonas replied to jonas's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Ok, pulled the switch and the male/female connector from the switch into the harness is absolutely FRIED! Peeled back about 4 inches of the harness casing and all the wires look fine. Looks like a trip to the boneyard for new switch and connector is in order. Last time I was there all they had was an '80's hatch. Hope it's still there. -
thanks guys. will be checking the switch in a few min. where are those grounds located? -
Replaced a blown fuse and still nothing. They were working just fine. Everything else works. Checked the 3 links in the grey plastic cover on the passenger side, all good. was thinking bad light switch but all my other lights work just fine. *scratches head*
Gen 1 Subaru brat hot wheel
jonas replied to Pooparu's topic in Historic Subaru Forum: 50's thru 70's
That always sounds sooo ominous to me. Haven't had the courage to open mine. May have get another set to play with. -
Ea 81 exhaust, what you guys running?
Hey, from what i see your wagon looks nice! -
thanks guys. I had a Cherry Bomb on my '81 Brat and i liked it. Leaning back that way........ -
jonas replied to 6 Star's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's from the How To Keep Your Subaru Alive '72 Thru 84 edition, chapter 17. The artist is Joe Leahy -
Stuck in 3rd Gear ! help - its finals week!
jonas replied to Kroaker23's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I would get a used one. Cheaper that going rebuild and generally a safe bet. -
Try going into neutral while in motion. Mine will sometimes get stuck in 4th if I come to a stop while in gear with clutch pedal pressed. Come to a stop in neutral. -
I'm thinking remove the bar, install the seat frame, drop bar back in, then put the seats in. Probably have to move the seats a little closer together. There's about a 2 inch gap between the bar and the bed.
http--,,--// One more.......
http--,,--// http--,,--// Looks do-able. Tight fit but do-able. They wouldn't be for riding in anyways...
Cool, thanks. I'll get some pics up tomorrow. My tubes are fatter and it's a gen 2 which I believe is a bit wider than the Gen 1's but it's looking like I can make a set fit with little to no modding.
Thanks. If someone could post some really close-up shots that would help.
http--,,--// I believe It's off of a ford ranger trimmed up to fit Brat. Seems a little tight where the jumpseats would go. I'm thinking I may have to trim up the seat frame a bit, if possible, to make it fit. I hope not.
My birthday present: 1984 Subaru GL
jonas replied to Walldo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Looks like a nice car, minus damage, for a NY car. If you're patient and keep your eyes open, something will come along, otherwise you're gonna have to take Mykeys advice.
