3
Everything posted by jonas
My birthday present: 1984 Subaru GL
jonas replied to Walldo's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Gen 2 Brat doors will fit, just have to swap glass. Gen 2 brat and wagon fenders and doors, '82 thru '87 for Brat and '81? or '82 thru '84 for wagon will interchange. wagon doors will not swap. -
Height, Width, Length, Depth. Gen 1 and Gen 2. Looking to see if I can stuff a set and still keep my rollbar.
How long this been happening? Have you bled the system? Your MC could be leaking internally. If the brake pedal feels spongy, mushy, or has to be pumped a few times before any resistance is felt, air is in the system. If brake pedal feels solid, but goes to within 3 inches of the floor or so before any resistance is felt, brake pads/shoes aren't making contact as quickly as they should and probably need adjusting. This thread reminds me of an episode of House.
So how'd it go?
It's a lot easier than you think and well worth it. Plenty of info/help here.
- 7 replies
- Weber Carburetor
- EA81
(and 3 more)
Tagged with:
Do it dude.....
- 7 replies
- Weber Carburetor
- EA81
(and 3 more)
Tagged with:
'85 Brat, Too much brake travel
jonas replied to jonas's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Yup, rear brakes have been replaced and adjusted. Master cylinder is all i have left. Bled the system several times. not a terribly expensive part so we'll see what happens. -
So far all my research is pointing to a bad master cylinder. It's not leaking fluid but I don't have the pressure I should. I'll change that and see what happens. -
Bump for the evening crowd. -
Awesome dude.....
Ok, did the master vac check according to HTKYSA manual and it is working properly. -
Just did the brakes on my Brat. Definitely better! Completely bled the system and I'm sure there is no air in it. Not mushy or anything. Now here's the problem. When the car is not running the brakes are great, I barely have to press the pedal, minimal travel, and they grab great. When the car is running I get about half way down on pedal travel before brakes apply and it seems I have to apply more pressure than necessary. I don't have to stand on the pedal but I does seem like I have to apply more pressure than should be necessary. Ideas? I'm suspecting the Master Vac. P.S When I apply the brakes at idle I get a slight drop in rpm's.
Anyone ever attempted/done it? I've seen it in an auto Brat but not a stick. My only real concern is the 4wd lever. I have the 5spd swap so it's coming in at a different angle than stock. I'm considering giving it a shot.
Ea 81 exhaust, what you guys running?
yeah, that sounds (pun!) like what i'm after. NO FART CANS! -
honda boys talking smack. need motor ideas
jonas replied to drake13's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Your co-worker sounds like a douche. -
Need to put a new muffler on the Brat and was wondering what set-ups you guys are running. Don't want something terribly loud as in do a lot of highway driving. My '81 had a Cherry Bomb/ Glass pack (Disturbing the peace since 1968) on it and sounded pretty good place about half way thru the system.
'84 Brat Ignition Coil wiring
jonas replied to Harvester's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I have an '85 brat with only 5 wires. using your pis i have 2 solid yellow wires running to the right and the other 3 on the left. -
Radio Cutting in and Out Problems
jonas replied to tdodge41's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Just a loose wire, no. If you're crossing wires/connections somewhere and you have a newer unit then yes. It's a safety feature so you don't fry your unit or cause other damage. -
Were the speaker wires ran under the carpet? I have the same set-up, 2 boxes behind the seats. I ran my wires under the carpet but when I put the seats back in I bolted the drivers side on top of the wire, pinching it, making my speakers cut in and out. Took forever to find that out. It took awhile before the problem showed up. -
Gen 1 Subaru brat hot wheel
jonas replied to Pooparu's topic in Historic Subaru Forum: 50's thru 70's
got 'em!
