8
Legacy777 last won the day on February 5 2020
Legacy777 had the most liked content!
About Legacy777
- Birthday July 11
Contact Methods
AIM
JColombo7
Website URL
http://www.surrealmirage.com/subaru
Gender
Male
Location
Houston, Tx
Occupation
Engineer
Vehicles
90 Legacy - AWD 6MT EJ22T
Recent Profile Visitors
Legacy777's Achievements
Elite Master of the Subaru (11/11)
144
Kia Sephia Sporty
Legacy777 replied to Loyale 2.7 Turbo's topic in Non Soob Cars and Bikes Discussion
Jes, Sorry to hear about your father, but glad to hear he instilled you with the enthusiasm and guts to do this job! :) -
Kia Sephia Sporty
Jes, Thanks for sharing these photos and story! I had a transgo kit installed in my Legacy back 2002 when it was automatic. It did help the shifting issues similar to what you described but maybe not as pronounced. -
Legacy777 started following Transfer Clutch Solenoid Replacement
Kia Sephia Sporty
Good to hear the new oil is working well with the AC system! -
Without doing some more troubleshooting I'm not sure I could pin point it to one of those things. Have you tried what you described with the gear selector in the 1 or 2 position? Supposedly there are different shift maps when the gear selector is in those positions vs. drive. If you wanted to do some testing and try applying 12v to the duty c solenoid so you have 50/50 torque split all the time that may be able to help point to a duty c solenoid or not. It has it's own issues testing that way though and would require doing some wiring. I wish I had some more concrete information for you.
Kia Sephia Sporty
As I mentioned I think you should be good. If it's blowing cold and working well, that's good to hear. -
Kia Sephia Sporty
I think you should be ok. Has your AC been working ok or do you not have the work completed yet? -
Kia Sephia Sporty
Ok, well you've got to use what you have available. I'm sure it will work ok. The main issue I had with plain ester oil was it didn't lubricate as well and I believe lead to compressor failures. If the ICE 32 is supposed to help lubrication hopefully that well alleviate some of the issues I may have had. There appears to be different kinds of the Daphne Hermetic Oil, did the compressor say what viscosity/type? https://www.ilacorp.com/products/industrial-lubricants/refrigeration-compressor-oils.html -
Kia Sephia Sporty
Jes, Does the manual state to use ester oil vs. PAG oil? I've found ester oil doesn't work as well as PAG oil with r134a. I believe I've had compressor failures in the past due to insufficient lubrication. -
Kia Sephia Sporty
Great work Jes! Glad extending the pedal has helped. You also get some additional leverage on the brake pedal with the added length which translates to more force being input to the brake master cylinder with the same foot/leg force exerted on the brake pedal. -
New guy trying to help a friend
Legacy777 replied to McCulloch610's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB, and yeah post in the New gen forum. You'll be able to get some more feedback there. -
Welcome to the USMB! Sorry to hear about the accident, but glad to hear you're ok and getting an Outback.
