8
Welcome to the USMB!
The cycling of the radiator fan is typically a result of a set of diagnostic connectors being connected. They should not be connected under normal circumstances. The connector is a green T shaped connector. They look like the green connectors in this picture. http://www.main.experiencetherave.com/subaru/images/ecuhide.jpg I'm not sure whether the connector is up under the dash on the driver's side or on the passenger side. I'd check on the driver's side first.
Welcome to the USMB. I'm going to move your thread to the Old Gen forum where it will get more attention.
Good Morning Subaru folks
Legacy777 replied to davavd's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB! There's a lot of useful info and helpful folks here. If you have any specific questions, try searching or post a new thread. -
Welcome to the USMB, and glad you registered!
okamikai desu, yoroshiku onegai shimasu :D
Legacy777 replied to okamikai's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB! -
The other thing to keep in mind is that the base piece that the speedo cable connects to for the automatic transmissions is a common failure point. the shaft inside that piece breaks. It's pretty inexpensive to get a new one, and easy to change. Here's a pic of the base piece. There is a bottom washer and rubber piece that sometimes gets stuck in the hole, so you need to make sure and dig that out when removing the old pieces. http://www.main.experiencetherave.com/subaru/images/speedocablebase.jpg
The round silver & copper thing is the reed switch, which is the VSS. http://www.main.experiencetherave.com/subaru/images/combmeter/images/IMG_5856.JPG I honestly don't remember if you can replace just the rear section with the reed switch or if you have to replace the entire speedometer section....or just the entire gauge cluster.
EJ22T after swap problems. Fuel cut at 3 to 5 lbs of boost.
Legacy777 replied to Steve W.'s topic in Subaru Retrofitting
Assuming the narrow band output is setup and working correctly, it should be fine to provide the correct info to the ECU. I ran my Legacy like that for a while before I put in my stand alone EM. Regarding the 12v vs. 5v on the idle switch. What is your other car's idle switch voltage? In looking at this diagram, it shows Battery voltage going to the idle switch. http://www.main.experiencetherave.com/subaru_manual_scans/FSM_Scans/TPS_wiring_diag.jpg I agree, it may be time to swap ECU's to see if that changes anything. -
First Subaru 2003 Forester X 82,000 Miles
Legacy777 replied to bptwvpaulw's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB! Yeah I'm sure the Subie will serve your grand daughter well. I had mine all through college and still have it 12 years later. -
New Subaru Engined VW T3 owner
Legacy777 replied to tttulio's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB! Nice VW, and hopefully we can help with any issues you may have. -
Steve, Does your Innovative WB have a narrow band simulator output that you have wired up to the ECU? If not, you essentially do not have an O2 sensor going to the ECU. A wideband signal won't work with the stock ECU. Just for clarity's sake, the proper pin location/id of the idle switch at the ECU is connector B56, pin 6. The FSM abbreviates connector B56 as "c". Also, from what I can tell, it should be putting out voltage around what the battery is putting out. So if you have 10 v at the ECU, that's ok. -
Yeah I think the piping size sounds ok.
