8
New Outback owner in AZ
Legacy777 replied to MTJack's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB! You may want to post in the new gen forum asking about the head gaskets. You may get more responses over there. -
EJ22T after swap problems. Fuel cut at 3 to 5 lbs of boost.
Legacy777 replied to Steve W.'s topic in Subaru Retrofitting
What size is the inlet piping you're using? -
Welcome to the USMB. Was the thermostat that you used a Subaru thermostat? If not, I'd suggest replacing it with a Subaru thermostat. If you did use a Subaru thermostat I'd say it kind of sounds like head gasket issues. The tester the previous mechanic used was called a hydrocarbon tester/sniffer. I have one and if the head gasket leak is pretty small it may put enough gasses in the coolant to register in the testing fluid. You may want to have it tested again for confirmation, but usually bubbles coming from the cooling system are an indicator of head gasket issues.
Steve, Regarding your idle switch issue. Are you throwing a code for that? -
New member from Grand Rapids MI here
Legacy777 replied to arod812's topic in Meet n' Greet. Your USMB Welcome Center
Welcome to the USMB! I don't know of any members in your area, but you may want to post in Off topic as well. -
All the aluminum body MAF sensors are the same. Yeah I don't know what to say about the MAF code still being there. If you've tried multiple MAF's & ECU's, all that's left is the wiring. -
Welcome to the USMB. I would suggest trying to keep the overall tire diameter the same. What size tires do you currently have on the car? You can use this tire calculator to input your old tire size and play around with new tire sizes that are close to the original size. http://www.miata.net/garage/tirecalc.html
Not sure if you already did this work, but I would recommend going with an OEM clutch & pressure plate setup. You will also need a throw out bearing and the clips that go with it. Assuming the flywheel is ok, and doesn't need to be resurfaced you should be good there. It's kind of up to you, depending on how many miles are on it, but replacing the pilot bearing on the flywheel might not be a bad idea. The other thing folks have suggested replacing is the actual clutch fork. It's stamped steel and has been known to wear out & crack, depending on use. I think you could get this done in a day especially with someone helping.
Well that ECU is definitely a turbo ECU. The aluminum body MAF's came on the 91-94 turbo legacies, but also came on the 90-91 MT only non-turbo legacy. So you could probably find an aluminum body MAF from a non-turbo car. -
All the turbo Legacy ECU's are interchangable. What is the part # on the ECU you're using? That's very strange....it seems like something just isn't right....wish I could go over it in person as it's probably something simple once you see it.
