8
ok....I do have a question about the sealant of the oil pump. I've been trying to get my hands on the three bond or whatever subaru uses. I don't think the ultra grey stuff is anerobic. I have some stuff that is.....but I'm not sure if it's exactly what I want. The damn sealant is holding me up from doing the t-belt.
I needed the caliper brackets, caliper, rotors, & brakes from the WRX. The stock proportioning valve is not adjustable, and most if not all aftermarket valves will not work because subaru uses a diagonal braking circuit for redundancy. What I did was use the prop valve for a legacy wagon. It bumped the split point about 100 psi, which gave me slightly more rear brake torque when at or above the split point. I personally wouldn't recommend you mess with the proportioning valve, since some of the other subaru valves have completely different split points and reducing ratios......which could cause some serious braking problems. The MC I am using is a 1 1/16" bore 4-port MC from a non-abs SVX. The 1" bore MC had too much pedal travel due to the increase in volume needed by the larger calipers. Pretty much all ABS equipped legacies have a 1 1/16" bore MC. It is however a 2-port vs. 4-port MC since the lines branch off at the abs pump.
i've got wrx front brakes on my 90 legacy, so you will not have any issues with fitment. The only thing that can arise is that your brake bias will be messed with a little. For the WRX guys the most common upgrade is the H6 rear rotor upgrade which shifts brake bias to the rear to help the nose dive affect. I had some pretty severe issues when i swapped the WRX front brakes on my car. I've since messed with master cylinders and proportioning valves, but am going to be getting some B4/GT-B rear brakes. They have the same diameter rotor as the H6 rear brakes, however are vented.
http://www.main.experiencetherave.com:8080/subaru_manual_scans direct links http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/ECU_I-O_page1.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/ECU_I-O_page2.jpg http://www.main.experiencetherave.com:8080/subaru_manual_scans/FSM_Scans/ECU_I-O_page3.jpg
